    Follow me into different radius
    30 Posts 4 Posters 6.7k Views 4 Watching
    • L
      Leggy
      hi I followed your example and got this, any ideas
      thanks so much for your time
        Why don't you upload the SKP file so we can see what you started with?
        • L
          Leggy
          here you are
          curviloft test.skp
            Does the white one look more like what you want?
            curviloft test.skp
            • L
              Leggy
              exactly, is it to do with the order you pick the lines?
                No. The bottom arc has 24 segments so I divided the straight lines on the sides and top so there is a total of 24 segments up each side (including the segments in the arcs at the top.
                • L
                  Leggy
                  how did you do that?
                    Do what? Divide the edges? I right clicked on an edge, selected Divide and then entered the correct number.
                    • L
                      Leggy
                      Clever , the problem with the video is the curser leaves the screen so you can’t see what he clicked
                        Which video are you referring to?
                        • L
                          Leggy
                          The one from box
                          • L
                            Leggy
                            The one from box
                              The only things I saw where the cursor wasn't visible was when he made a group after context clicking on the selected geometry and then when he moved the cursor to bring the Entity Info panel up to show that it's a solid group.
                              • 2 / 2
