    Follow me into different radius
    30 Posts 4 Posters 6.7k Views 4 Watching
    • L
      Leggy
      here you are
      curviloft test.skp
        Does the white one look more like what you want?
        curviloft test.skp
        • L
          Leggy
          exactly, is it to do with the order you pick the lines?
            No. The bottom arc has 24 segments so I divided the straight lines on the sides and top so there is a total of 24 segments up each side (including the segments in the arcs at the top.
            • L
              Leggy
              how did you do that?
                Do what? Divide the edges? I right clicked on an edge, selected Divide and then entered the correct number.
                • L
                  Leggy
                  Clever , the problem with the video is the curser leaves the screen so you can’t see what he clicked
                    Which video are you referring to?
                    • L
                      Leggy
                      The one from box
                      • L
                        Leggy
                        The one from box
                          The only things I saw where the cursor wasn't visible was when he made a group after context clicking on the selected geometry and then when he moved the cursor to bring the Entity Info panel up to show that it's a solid group.
                          • 2 / 2
