    [Plugin] Import OBJ with Materials v2.1 20131118
    279 Posts 87 Posters 434.3k Views 87 Watching
    • TIGT Online
      I suspect this is an issue with the encoding of the text in .OBJ file itself.
      The importer needs to read in the lines of the file to process the data into SketchUp geometry.
      More recent SketchUp versions can often force text encoding to be Ruby compatible.
      This plugin is nine years old and hasn't been changed for five !
      So it doesn't do any fancy re-encoding...
      You can try the following manual fixes on copies of the .OBJ and .MTL files...
      Use a plain-text editor like Notepad++.exe to edit the files
      If you don't already have it, you can get a free installer - google it for the download...
      In the editors menu, under Encoding, check that it's set to Encode UFT-8, if not then use Convert to UTF-8.
      Ruby needs that encoding.
      Check that the text is not unexpectedly changed [e.g. weird name-changes] and that any materials in the .MTL file still reference existing image files - e.g. a jpg name containing an umlaut might need to be changed so that the file-name and .MTL entry match...
      Save the files.
      Try re-importing it and feedback...
      • romboutR Offline
        rombout
        I got one more question about this version. On one of my mac it was working fine, sadly that one broke down. Now im back to my old macbook mid 2010. When i try the latest version the same model i tried earlier shows the quads half flipped faces. I had an altered version on the other mac, mac didnt seem to have an proper backup of that one.
        When i check the main plugin info, it says there was an update "feature proof";
        2.2 20131228 Future proofed.
        Yet in the addon when added it doesnt state that. There its says this as last update;
        2.1 20131118 Import of OBJ files using a -ve counter for f vertices within
        sub-groups fixed. View now refreshes with each group completion.
        • TIGT Online
          Don't worry about the version text in the RB file itself.
          It's no longer updated.
          The Rev notes in the PluginStore page are correct.
          The v2.2 was stated as 'future proofed'.
          That was back when SketchUp was about to migrate to some new API methods and a newer Ruby version in v2014.
          Just prior to that version's release, major developers were given some confidential prior knowledge, to let them get their scripts ready for those changes, but they couldn't expand much on what had been changed 'under-the-hood' without revealing what was impending in the SketchUp release... hence 'future proofed'...
          It is an old script and has not been changed in about five and a half years !
          However, it should still work on older and of course the newer SketchUp versions.
          Install the latest version [v2.2] from the PluginStore...
          • romboutR Offline
            rombout
            Okay, thanks for answering. I found it weird that the same models now seems to have flipped quades (normals inside-out). I tried the OBJ importer from quad tools, never new this had one as well. Seems much faster and imported perfect. Just like OBJ importer did on my other machine with the exact same model. So i really dont understand why on this machine with the same plugin it acts different.
              V2.2
              I export my objects in OBJ format from MagicaVoxel a terrific Voxel prog! (free) ๐Ÿ˜Ž
              Reload works fine in Wings 3D (free)
              No color inside SU or special result! ๐Ÿ˜ฒ
              Glitch ? ...
              Its the same if export the objects from Wings 3D result! ๐Ÿ˜ฎ
              or that!
              Glitch_obj_import.zip
              • romboutR Offline
                rombout
                @pilou said:
                V2.2
                Glitch ? ...
                [attachment=1:2i3yc27k]<!-- ia1 -->glitch_obj_import.jpg<!-- ia1 -->[/attachment:2i3yc27k]
                or that!
                [attachment=0:2i3yc27k]<!-- ia0 -->glitch.jpg<!-- ia0 -->[/attachment:2i3yc27k]
                I dont think mesh color is supported, only textures. Try using the scale or import option and use bigger scale. That sometimes seems to fix the uvs. You can also try the OBJ import with quad tools
                • romboutR Offline
                  rombout
                  PS i did a quick check with Blender. These cubes dont have a proper UV map. The texture is super wide as well.
                  EDIT
                  here's is that same scene and model, now it imports just fine
                  Fixed files
                  Fixed UVs
                    Drachenbauer
                    Hello
                    If i try to import a .obj-file, that is made with blender, it does not get itยดs textures.
                    In blender tihs model has got 192 vertices and 225 faces.
                    https://sketchfab.com/3d-models/hotairballoon-stella-huge-size-676170222a2e4b9e9fd6bf10594dc1af
                    Is it too complex for this plugin?
                    • TIGT Online
                      I'm no buying it !
                      It doesn't look complex at all...
                      So does it come with both OBJ and MTL files ?
                      Is the MTL file properly named in the OBJ file, i.e. relative to it ?
                      Is there a subfolder of material files ?
                      In the MTL file is the path to that material subfolder properly named, i.e. relative to it.
                      Show us a screenshot of your folder set up etc...
                      And perhaps an extract from the start of the OBJ and MTL files showing file/folder details...
                        Drachenbauer
                        It has .obj and .mtl and there is a folder with the material-texture.
                        the texture includes all parts of the model, that it looks a bit like a papercraft-template.
                        In the first try it appeared white, and in all followinf tries it had my default outside-color (my default material is outside yellow, inside white).
                        • TIGT Online
                          Sadly you did not answer my entire question.
                          Is there a subfolder of material files ? [YES]
                          Also note that there are several options regarding the importation - so ensure you choose the 'with textures' option...
                          • sketchartist023S Offline
                            sketchartist023
                            I export a blender mesh with vertex painting texture, and use this but nothing shows up at all. Its blank. ๐Ÿ˜ž The blender export is both .obj and .mtl files but Ill double check their validity through other software also just in case its an export issue, but any thoughts? Not even mesh shows up ๐Ÿ˜› Thank you for your time and patience!
                            USING: SU8FREE(or as they say pre 2017) windows 10 64 bit and noting the mesh is over 300K+ lines ๐Ÿ˜›
                            • TIGT Online
                              If you have the Ruby Console open when trying this are there any error messages ?
                              Have you tried a much simpler Blender OBJ with textures ? How'd that do ??
                                aviagg Newcomers
                                This plugin spoils the entire mesh while importing
                                • TIGT Online
                                  Why not try something newer, like Universal Importer ?
                                  https://sketchucation.com/pluginstore?pln=universal_importer
                                  • 11
                                  • 12
                                  • 13
                                  • 14
                                  • 14 / 14
