    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 525.9k Views 102 Watching
    • fredo6F Offline
      @vicente122334 said:
      Hey Fredo6!
      So, I was messing around with Thrupaint trying to texture a curved and "Z axis" road and when I tried to texture it, The section where the road is straight and curved is just diferent (deformed) like in the image I just sent...
      Is there any way I can solve this? I've been searching for almost a week, thanks!
      Difficult to tell without the model.
      In general, you should do all the segments of the road in one go.
        dedmin
        Hey Fredo6!
        • V Offline
          Vicente122334
          Hey Fredo6!
          Hello! Thank you so much for replying!
          I actually manage to find the solution, I just had to triangulate and I also did what you said in your post, I did all the road together. I actually have another issue but I don't think this one is solvable, I don't know... when the curve starts in my road, the part of the texture on the left side scales up way more than the one on the right side. Is it possible to keep both at the same scale?
          Thanks for reading! I will also send the sketch file this time.
          Untitled14.skp
          • fredo6F Offline
            Stretching of the texture is inevitable in the rounding with the way Sketchup handles texture adjustment. There is nothing you can really do about it, even if you manage it manually with the pins.
              Ahmed0007
              Complete Tutorial of Fredo ThruPaint
              https://youtu.be/db3KAv0-ATI
              • fredo6F Offline
                Thank you very much. Very complete and didactic. Congratulations.
                I inserted the video in the main post of this thread.
                Fred
                PS: You should post on SketchUp Forum too.
                  Ahmed0007
                  Fred
                  Thank you so much πŸ˜„
                  • summerson1990S Offline
                    summerson1990
                    Hi! Can ThruPaint snap to guidelines or geometry when working in visual edition mode to align texture perfectly as native texture position tool does it? Look my screenshot
                    • fredo6F Offline
                      Not obvious, but probably feasible.
                        summerson1990
                        So could you please say how to make it possible to snap? Sometimes it seems like something close to snapping is working but I didn't realized yet in what cases and how exactly it does. Thanks!
                        • fredo6F Offline
                          I just say that this is not supported in the current version. So I would need to make the change.
                            summerson1990
                            Ok, as you will do it it will be very useful. Thank you!
                              modavi
                              Hi Fredo, thanks for the amazing plugins! They're indispensable!
                              I am running into an issue exporting a mesh textured with ThruPaint to OBJ or FBX. Neither format preserves the UVs I've generated.
                              Mesh in sketchup
                              After exporting the above mesh to obj or fbx format, and then import it into another program (I've tried both maya and unity) the UVs seem to have reverted to a basic planar projection.
                              Unity mesh
                              Is there anything required to "bake" the UVs into the mesh before they can be exported successfully by the built in sketchup exporters? I've tried enabling triangulation in the export options, but that does not fix the issue.
                              It's worth noting I'm using Sketchup 19.3.252 on OSX.
                                rv1974
                                Fredo, would it be possible to add 'triangulate quads* on painting option to ThruPaint?
                                *- analogous to TT's Quadface Tools?
                                • fredo6F Offline
                                  What do you mean?
                                  In QuadMesh mode, ThruPaint works whether the quads are true quads or are triangulated.
                                  Do you want to force triangulation?
                                    rv1974
                                    Yes I mean 'force triangulation' option (I hope we are talking about the same things πŸ˜„
                                    You see, if I'd export some perverted mesh (with QuadMesh UV applied) as foreign format (3ds, fbx, obj etc) I'd get tons of independent 'materials'- (one mat for every single face). The only wayI know to avoid this plague is triangulation. TT's Triangulate command works perfectly,
                                    The only inconvenience it's an extra procedure. Simultaneous painting + triangulation would be just perfect.
                                    • fredo6F Offline
                                      OK. But then, why don't you do the triangulation once, and then call ThruPaint after.
                                      My problem is more to see how to fit the option in an already crowded GUI, and also keeping ThruPaint doing what it is paid for, that is, apply colors and textures, not alter the geometry.
                                        rv1974
                                        Quite often I have to deal with truly complex files (say +100k objects, +1.5M faces).
                                        It's simply inevitable to skip some objects (that must be triangulated).
                                        For instance, Profile Builder allows instant multiple paths profile creation. I suggested Whaat to add 'triangulate upon creation' option But it wasn't addressed unfortunately. And then when the moment of export comes... Houston we have a problem 😲
                                        Anyways.. I don't think one tiny 3x3mm Ξ” button will mess up the palette. Per contra, the benefit would be inexpressible.
                                          Bandika
                                          My favourite tool! Though now I have problems in SU2019.
                                          A tiny little surface, such as a chair seat lasted 1,5 hour to paint. Earlier it was cca. 5 seconds.
                                          Every little surface is 1 hour to do.
                                          What could happen? I am going crazy...
                                          • fredo6F Offline
                                            That's not normal.
                                            Could you post or PM me the model.
                                            • 16
                                            • 17
                                            • 2 / 17
