    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 634.0k Views 102 Watching
    • C
      chaosaic
      @fredo6 said:
      @chaosaic,
      Difficult to tell what is the problem.
      Could you indicate which UV mode you use (Natural, Projection, QuadMesh) and if you have a problem of performance in all modes.
      Also, what kind of texture do you use? Is it a heavy image?
      after few days of searching and testing , I believe I have found the problem.
      at least the huge one of them.
      when outliner tray is expanded , if the file contains high poly geometry , whether its hidden or not (but geometry in invisible layer not in this case),
      painting UV and using of visual mode will be extremly lag(I'm not sure if this happen in my PC only).
      anyway , really appreciate that you take your time to answer my question patiently.
      and again , great plug-in.
      • fredo6F
        For info, I made a change in FredoTools 3.4a to keep performance OK when outliner is open.
        So if you wish to test if it works in your case...
        Fred0
        • C
          chaosaic
          Fred0
          I have just test ThruPaint in FredoTools 3.4a.
          When outliner tray is opened , painting and adjusting speed is almost the same as its not open.
          Outliner problem just like mystery to me and you just solve it πŸ˜†
          As a newbie I want to ask if there's a way to export a 3dsmax model's UV to sketchup?
          I hvae a 3dsmax model already has it's own UV map, then I export it as .obj, import to WrapR check its the same as 3dsmax model, then import UV.obj by SketchUV tools, but not working.
          • V
            Vicente122334
            Hey Fredo6!
            So, I was messing around with Thrupaint trying to texture a curved and "Z axis" road and when I tried to texture it, The section where the road is straight and curved is just diferent (deformed) like in the image I just sent...
            Is there any way I can solve this? I've been searching for almost a week, thanks!
            • fredo6F
              @vicente122334 said:
              Hey Fredo6!
              Difficult to tell without the model.
              In general, you should do all the segments of the road in one go.
                dedmin
                Hey Fredo6!
                • V
                  Vicente122334
                  Hey Fredo6!
                  Hello! Thank you so much for replying!
                  I actually manage to find the solution, I just had to triangulate and I also did what you said in your post, I did all the road together. I actually have another issue but I don't think this one is solvable, I don't know... when the curve starts in my road, the part of the texture on the left side scales up way more than the one on the right side. Is it possible to keep both at the same scale?
                  Thanks for reading! I will also send the sketch file this time.
                  Untitled14.skp
                  • fredo6F
                    Stretching of the texture is inevitable in the rounding with the way Sketchup handles texture adjustment. There is nothing you can really do about it, even if you manage it manually with the pins.
                      Ahmed0007
                      Complete Tutorial of Fredo ThruPaint
                      https://youtu.be/db3KAv0-ATI
                      • fredo6F
                        Thank you very much. Very complete and didactic. Congratulations.
                        I inserted the video in the main post of this thread.
                        Fred
                        PS: You should post on SketchUp Forum too.
                          Ahmed0007
                          Fred
                          Thank you so much πŸ˜„
                          • summerson1990S
                            summerson1990
                            Hi! Can ThruPaint snap to guidelines or geometry when working in visual edition mode to align texture perfectly as native texture position tool does it? Look my screenshot
                            • fredo6F
                              Not obvious, but probably feasible.
                              • summerson1990S
                                summerson1990
                                So could you please say how to make it possible to snap? Sometimes it seems like something close to snapping is working but I didn't realized yet in what cases and how exactly it does. Thanks!
                                • fredo6F
                                  I just say that this is not supported in the current version. So I would need to make the change.
                                  • summerson1990S
                                    summerson1990
                                    Ok, as you will do it it will be very useful. Thank you!
                                      modavi
                                      Hi Fredo, thanks for the amazing plugins! They're indispensable!
                                      I am running into an issue exporting a mesh textured with ThruPaint to OBJ or FBX. Neither format preserves the UVs I've generated.
                                      Mesh in sketchup
                                      After exporting the above mesh to obj or fbx format, and then import it into another program (I've tried both maya and unity) the UVs seem to have reverted to a basic planar projection.
                                      Unity mesh
                                      Is there anything required to "bake" the UVs into the mesh before they can be exported successfully by the built in sketchup exporters? I've tried enabling triangulation in the export options, but that does not fix the issue.
                                      It's worth noting I'm using Sketchup 19.3.252 on OSX.
                                        rv1974
                                        Fredo, would it be possible to add 'triangulate quads* on painting option to ThruPaint?
                                        *- analogous to TT's Quadface Tools?
                                        • fredo6F
                                          What do you mean?
                                          In QuadMesh mode, ThruPaint works whether the quads are true quads or are triangulated.
                                          Do you want to force triangulation?
                                            rv1974
                                            Yes I mean 'force triangulation' option (I hope we are talking about the same things πŸ˜„
                                            You see, if I'd export some perverted mesh (with QuadMesh UV applied) as foreign format (3ds, fbx, obj etc) I'd get tons of independent 'materials'- (one mat for every single face). The only wayI know to avoid this plague is triangulation. TT's Triangulate command works perfectly,
                                            The only inconvenience it's an extra procedure. Simultaneous painting + triangulation would be just perfect.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
