    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 625.0k Views 102 Watching
    • fredo6F
      Stretching of the texture is inevitable in the rounding with the way Sketchup handles texture adjustment. There is nothing you can really do about it, even if you manage it manually with the pins.
        Ahmed0007
        Complete Tutorial of Fredo ThruPaint
        https://youtu.be/db3KAv0-ATI
        • fredo6F
          Thank you very much. Very complete and didactic. Congratulations.
          I inserted the video in the main post of this thread.
          Fred
          PS: You should post on SketchUp Forum too.
            Ahmed0007
            Fred
            Thank you so much πŸ˜„
            • summerson1990S
              summerson1990
              Hi! Can ThruPaint snap to guidelines or geometry when working in visual edition mode to align texture perfectly as native texture position tool does it? Look my screenshot
              • fredo6F
                Not obvious, but probably feasible.
                • summerson1990S
                  summerson1990
                  So could you please say how to make it possible to snap? Sometimes it seems like something close to snapping is working but I didn't realized yet in what cases and how exactly it does. Thanks!
                  • fredo6F
                    I just say that this is not supported in the current version. So I would need to make the change.
                    • summerson1990S
                      summerson1990
                      Ok, as you will do it it will be very useful. Thank you!
                        modavi
                        Hi Fredo, thanks for the amazing plugins! They're indispensable!
                        I am running into an issue exporting a mesh textured with ThruPaint to OBJ or FBX. Neither format preserves the UVs I've generated.
                        Mesh in sketchup
                        After exporting the above mesh to obj or fbx format, and then import it into another program (I've tried both maya and unity) the UVs seem to have reverted to a basic planar projection.
                        Unity mesh
                        Is there anything required to "bake" the UVs into the mesh before they can be exported successfully by the built in sketchup exporters? I've tried enabling triangulation in the export options, but that does not fix the issue.
                        It's worth noting I'm using Sketchup 19.3.252 on OSX.
                          rv1974
                          Fredo, would it be possible to add 'triangulate quads* on painting option to ThruPaint?
                          *- analogous to TT's Quadface Tools?
                          • fredo6F
                            What do you mean?
                            In QuadMesh mode, ThruPaint works whether the quads are true quads or are triangulated.
                            Do you want to force triangulation?
                              rv1974
                              Yes I mean 'force triangulation' option (I hope we are talking about the same things πŸ˜„
                              You see, if I'd export some perverted mesh (with QuadMesh UV applied) as foreign format (3ds, fbx, obj etc) I'd get tons of independent 'materials'- (one mat for every single face). The only wayI know to avoid this plague is triangulation. TT's Triangulate command works perfectly,
                              The only inconvenience it's an extra procedure. Simultaneous painting + triangulation would be just perfect.
                              • fredo6F
                                OK. But then, why don't you do the triangulation once, and then call ThruPaint after.
                                My problem is more to see how to fit the option in an already crowded GUI, and also keeping ThruPaint doing what it is paid for, that is, apply colors and textures, not alter the geometry.
                                  rv1974
                                  Quite often I have to deal with truly complex files (say +100k objects, +1.5M faces).
                                  It's simply inevitable to skip some objects (that must be triangulated).
                                  For instance, Profile Builder allows instant multiple paths profile creation. I suggested Whaat to add 'triangulate upon creation' option But it wasn't addressed unfortunately. And then when the moment of export comes... Houston we have a problem 😲
                                  Anyways.. I don't think one tiny 3x3mm Ξ” button will mess up the palette. Per contra, the benefit would be inexpressible.
                                  • B
                                    Bandika
                                    My favourite tool! Though now I have problems in SU2019.
                                    A tiny little surface, such as a chair seat lasted 1,5 hour to paint. Earlier it was cca. 5 seconds.
                                    Every little surface is 1 hour to do.
                                    What could happen? I am going crazy...
                                    • fredo6F
                                      That's not normal.
                                      Could you post or PM me the model.
                                      • B
                                        Bandika
                                        Dear Fredo!
                                        It just has recovered!!! I deleted then istalled again the extension, and now it is working as fine as before!!! Maybe it got scared from you:)
                                        Big thanks!
                                        • fredo6F
                                          Good to hear.
                                          Still, I wonder what was creating the performance problem...
                                          • B
                                            Bandika
                                            Me too. Strange, that it did not freeze, it worked, finally it made it - just in one and a half ours. I worked in two files that time, it was exactly the same. I am happy now that it works again:)
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
