    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 634.0k Views 102 Watching
    • fredo6F
      @summerson1990 said:
      So could you please say how to make it possible to snap? Sometimes it seems like something close to snapping is working but I didn't realized yet in what cases and how exactly it does. Thanks!
      I just say that this is not supported in the current version. So I would need to make the change.
      • summerson1990S
        summerson1990
        Ok, as you will do it it will be very useful. Thank you!
          modavi
          Hi Fredo, thanks for the amazing plugins! They're indispensable!
          I am running into an issue exporting a mesh textured with ThruPaint to OBJ or FBX. Neither format preserves the UVs I've generated.
          Mesh in sketchup
          After exporting the above mesh to obj or fbx format, and then import it into another program (I've tried both maya and unity) the UVs seem to have reverted to a basic planar projection.
          Unity mesh
          Is there anything required to "bake" the UVs into the mesh before they can be exported successfully by the built in sketchup exporters? I've tried enabling triangulation in the export options, but that does not fix the issue.
          It's worth noting I'm using Sketchup 19.3.252 on OSX.
            rv1974
            Fredo, would it be possible to add 'triangulate quads* on painting option to ThruPaint?
            *- analogous to TT's Quadface Tools?
            • fredo6F
              What do you mean?
              In QuadMesh mode, ThruPaint works whether the quads are true quads or are triangulated.
              Do you want to force triangulation?
                rv1974
                Yes I mean 'force triangulation' option (I hope we are talking about the same things πŸ˜„
                You see, if I'd export some perverted mesh (with QuadMesh UV applied) as foreign format (3ds, fbx, obj etc) I'd get tons of independent 'materials'- (one mat for every single face). The only wayI know to avoid this plague is triangulation. TT's Triangulate command works perfectly,
                The only inconvenience it's an extra procedure. Simultaneous painting + triangulation would be just perfect.
                • fredo6F
                  OK. But then, why don't you do the triangulation once, and then call ThruPaint after.
                  My problem is more to see how to fit the option in an already crowded GUI, and also keeping ThruPaint doing what it is paid for, that is, apply colors and textures, not alter the geometry.
                    rv1974
                    Quite often I have to deal with truly complex files (say +100k objects, +1.5M faces).
                    It's simply inevitable to skip some objects (that must be triangulated).
                    For instance, Profile Builder allows instant multiple paths profile creation. I suggested Whaat to add 'triangulate upon creation' option But it wasn't addressed unfortunately. And then when the moment of export comes... Houston we have a problem 😲
                    Anyways.. I don't think one tiny 3x3mm Ξ” button will mess up the palette. Per contra, the benefit would be inexpressible.
                    • B
                      Bandika
                      My favourite tool! Though now I have problems in SU2019.
                      A tiny little surface, such as a chair seat lasted 1,5 hour to paint. Earlier it was cca. 5 seconds.
                      Every little surface is 1 hour to do.
                      What could happen? I am going crazy...
                      • fredo6F
                        That's not normal.
                        Could you post or PM me the model.
                        • B
                          Bandika
                          Dear Fredo!
                          It just has recovered!!! I deleted then istalled again the extension, and now it is working as fine as before!!! Maybe it got scared from you:)
                          Big thanks!
                          • fredo6F
                            Good to hear.
                            Still, I wonder what was creating the performance problem...
                            • B
                              Bandika
                              Me too. Strange, that it did not freeze, it worked, finally it made it - just in one and a half ours. I worked in two files that time, it was exactly the same. I am happy now that it works again:)
                                rv1974
                                Fredo, is it possible to add ability to assign (globally ) front face materials to corresponding back faces AND preserve front faces texture coordinates?
                                • fredo6F
                                  In principle, the UV are mirrored on the backface.
                                  Can you first try FredoTool:ReverseOrientFace to see if this does the job with the good mirroring on the back face.
                                    rv1974
                                    In my tests your ReverseOrientFace is completely OK on transferring UV's when flipping.
                                    Does it mean you potentially could add my request to ThruPaint or ReverseOrientFace?
                                    Off-topic Minor issue: In ReverseOrientFace I can't make make tooltips work (they are enabled and SU restarted)
                                    • fredo6F
                                      Just to be sure, you want a very unusual behavior, which is that the UV on the other side of the face are different.
                                      In Sketchup, ThruPaint, etc... the flipping of faces or the painting on both sides of a face keeps the UV identical (so that if the material is transparent, you see only one texture).
                                        rv1974
                                        In simple words I need singe click solution that'd take everything I see on front and apply in exact manner to the back (no matter what happens currently on the back, it will be replaced with front textures).
                                        Theoretically ThruPaint is good if you'd start from the scratch and use TruPaint exclusively all the way.
                                        • fredo6F
                                          Do you have an example. I am still not sure of what you want.
                                            rv1974
                                            The same components with the same material applied, but with randomized UV's..
                                            Is it theoretically possible in current SU? Maybe some trick thru dynamic components?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
