    [Plugin] MaterialConsolidator
    59 Posts 32 Posters 45.1k Views 32 Watching
      Gabbiano
      Really a great plugin!
      Thank you TIG!
      • H Offline
        hegemonicoMX
        Came down in the best moment. I had a horrible mess in the materials of a collaborative model. ๐Ÿ˜‰ its a blessing
        • E Offline
          Ecuadorian
          Hey, TIG. How about adding some "fuzzy" logic to this? I mean, sometimes you have very similar materials that have only slightly different properties. For example, half a dozen of glasses with only slightly different tints, or slightly different alpha values, and it would be useful to consolidate them.
          -Miguel Lescano
          • JClementsJ Offline
            JClements
            A mighty handy plugin. Thanks!
              bsfranza
              is there somebody out there who can compile the above mentioned "accuracy" code addon into the plugin and share it with us ๐Ÿ˜„?
              would be awesome!!
              thanks
                Here's v2.0 which includes optional 'tolerances' for RGBA values.
                So you can now consolidate colors which are almost a match !
                Use it with thought...
                But it is one-step undo-able !
                https://sketchucation.com/pluginstore?pln=materialconsolidator
                Please read the updated usage notes in the first post: http://sketchucation.com/forums/viewtopic.php?p=295290#p295290
                  db11
                  Thanks TIG. This will be a very useful addition to an often-used plugin.
                  • pbacotP Offline
                    Thank you!
                      Sorry, for any inconvenience !
                      Here's v3.0
                      It tweaks any options checking - to avoid unexpected results !
                        bsfranza
                        WOW super many muchas gracias ๐Ÿ˜„
                        heavily appreciated!
                        edit:
                        of course one is never satisfied for long ...
                        plugin works as expected now, but its kind of slow on scenes with many many polygons and the report does not state the progress or if the plugin is still working or if the app is frozen and also there are some crucial options missing...
                        for example: work in only on entities in active context or vice versa, ignore entities and materials of active objects
                        dont know if anyone is aware of the age old plugin material maintance - this one is quite fast with what it does ..
                        maybe someone in the future can combine them and make a proper plugin, i personally would be happy to pay for something like that ๐Ÿ˜„
                        • 1 Offline
                          1010 Gunner
                          Need help with installation or use of this plugin.
                          'materialconsolidator' shows in my extension manager although there is no version, author etc information.
                          It is not showing in the 'extensions' tab
                          What do I need to do to get it to work?
                            First thing I'd do is look in the Tools Menu where the instructions say it will be located. See the first post.
                            If it's not there, then we need to look at how you went about installing it.
                            What version of SketchUp are you using? Your profile indicates version 7 but it had no Extension Manager.
                            • 1 Offline
                              1010 Gunner
                              That's it, thank you.
                                SirFievel33
                                Hey TIG, so I'm running your program on my 150MB file with many materials (~150) and components. It seems to 'freeze' on the "Making Nested Entities List." step. Takes up a lot of CPU processing power but not seeing any progress. I'm leaving it 'running' for a few hours to give it a chance to finish. If it's not frozen and working as intended, could I suggest making some form of a progress bar or status updates, maybe even a pause option. If it's not working as intended, well, consider yourself informed. ๐Ÿ˜•
                                  SirFievel33
                                  Returned to these error messages within Ruby Console (I'm using Sketchup Pro 2019)
                                  Material Consolidator: Tolerances: R=15 G=15 B=15 A=0
                                  Material Consolidator: Making Material Lists
                                  Material Consolidator: Making Entities List
                                  Material Consolidator: Making Nested Entities List
                                  Material Consolidator: Consolidating Materials
                                  Error: #<NoMethodError: undefined method display_name' for nil:NilClass> C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:202:in block (3 levels) in new'
                                  C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:195:in each' C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:195:in block (2 levels) in new'
                                  C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:191:in each' C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:191:in block in new'
                                  C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:189:in each' C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:189:in new'
                                  C:/Users/###/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/materialconsolidator.rb:71:in `block in module:MaterialConsolidator'
                                    I see the issue and will issue an update shortly...
                                      Here's v4.0
                                      It should fix the display_name error for nil-materials...
                                      • V Offline
                                        valerostudio
                                        Is it possible to get some kind of progress bar with this plugin? I usually use it toward the end of a project, where I have imported a bunch of components and have a lot of materials. I ran this yesterday and I wasn't sure if SketchUp had crashed or it was still working. I let it sit overnight and it was just working away. It would be nice to know how far it has to go. Thomthoms Cleanup does a great job of doing this.
                                          The Ruby Console lists the key stage of its operation - open it before you start.
                                          The bottom status_bar has a incrementing '...' to show it's doing something...
                                          It also reports the key stages of operation...
                                            melindasaur
                                            First of all THANK YOU SO MUCH for this! This is saving me so much headache already.
                                            It's not working for a couple of materials in one of my files. It WILL work in a new project if I apply those materials to surfaces and paste them in a new project... do you know why this might be? ie maybe it doesn't work with components?
                                            2019 file attached
                                            materialconsolidator-componentnotworking.skp
                                            • 3 / 3
