    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
      aofaofaof
      thanks
      • T
        tonamu
        Thanks for share.
        tonamu
        • fredo6F
          NEW RELEASE: Tools on Surface 2.3a- 06 Oct 17
          This maintenance release is required for:
          • the support of usernames with non-ascii characters
          • the compatibility for High Sierra for Mac users
          • the support for hi-resolution screens
          • the certification for SU2017
          You will need to migrate to LibFredo6 7.7g or higher
          Please see main post for download
            rv1974
            Fredo would it be hard to add fillet tool please?
            • fredo6F
              What do you mean?
              This is a set of tools "on Surface".
                rv1974
                I mean fillet on 3d surface. See attached:
                Say you have AB and CD lines. The red fillet connectig AB abd CD is demanded.
                fil.skp
                  rv1974
                  Street - underground parking ramp junction. Example from real life (VERY common an tedious task).
                  ca.skp
                  • fredo6F
                    @rv1974
                    Somehow, you are asking if I could implement teh equivalent of BezierSpline 'on surface', of which the filetting is just one tool.
                    That's probably possible, but non trivial.
                    Actually the real difficulty with TOS is to handle the sharp changes in surface, because this is where directions may change abruptly. If everything was on a smooth surfce it would be simpler.
                    I'll think about it.
                      rv1974
                      I'd gladly use this 3d fillet on more or less 'calm' surfaces and get an error report on sharp ones. no problem.
                      • E
                        Einstein
                        Hi!
                        As you can see in the screenshot, I selected two neighbouring surfaces. Offset on Surface creates one big offset for them both, together. I was thinking, if it's possible that offsets would be created separately, independently for each surface?
                        • fredo6F
                          @einstein said:
                          Hi!
                          Why don't you select each face for individual offset?
                          • E
                            Einstein
                            Because in another model I have tones of surfaces to offset and selecting them one by one would be haaard.
                              rv1974
                              Use one of lattisizers and then intersect it
                              • fredo6F
                                NEW RELEASE: Tools on Surface 2.4a- 01 Nov 18
                                This maintenance release is for bug fixing
                                You will need to migrate to LibFredo6 8.6j or higher
                                Please see main post for discussion
                                See Plugin download page for download
                                  reza1813
                                  Dear Fredo,
                                  Hello, I kindly reach you to ask you, Is there any possibility to add curve line to the Tools On Surface plugin or link BezierSpline plugin with Tools On Surface in order to draw the F-spline or Catmull Spline. Because sometimes we need to draw the special curve on curved surfaces. (Attachment file).
                                  Tools On Surface
                                  Tools On Surface
                                  Tools On Surface
                                  Sincerely
                                  Hamidreza
                                  • fredo6F
                                    That's relatively difficult to make a Draw Bezier on Surface.
                                    I think in the case of your model, the best would be to proceed with shaped cylinder and then intersect the torus.
                                      reza1813
                                      Dear Fredo,
                                      Thank you for your prompt reply to my question. Wow, I thought that adding curve line(Bezier) on Tool on surface plugin will be possible in SketchUp as MESH interface because this is just an example in order to show you what I mean and you obviously know that we usually need to add curve line on the curved surface(Like other Software: Rhino and...). Indeed, I ever use Drap(Feature in the SketchUp) or Flowify plugin(Anders L.) in order to put a pattern on my curved surface but most of the time it doesn't work properly or It does not look like what I am looking for.
                                      All in all, I hope so in the near future, we have this feature on SketchUp. Thanks in advance.
                                      Tools On Surface
                                      Tools On Surface 02
                                      Yours sincerely,
                                      Hamidreza
                                      • ChumleyC
                                        Chumley
                                        Hi there.
                                        Do you have a link to download the Tools on Surface plugin? I tried on the main page but link doesn't work.
                                        Thanks.
                                          You should always look in the Plugin Store for the latest versions of almost all toolsets...
                                          See here...
                                          https://sketchucation.com/pluginstore?pln=ToolsOnSurface
                                          Also remember to download and install the latest LibFredo...
                                          https://sketchucation.com/pluginstore?pln=LibFredo6
                                          After the installations, restart SketchUp to ensure everything gets synced...
                                          • C
                                            Caleb_Stanley
                                            I am having issues upon the startup of SketchUp with ToolsOnSurface, I believe it may have something to do with the latest update but I am not sure. Below is the text of the error code upon starting.
                                            ToolsOn Surface 2.4a: Error starting up plugin (creating menus and icons) invalid byte sequence in UTF-8 [in lib6config.rbe - #'===0: line 319]
                                            c:/...'sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1058:in'rescue in block in effective_load_part2'
                                            Please Help. Thank you.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 29 / 32
