    Rendered Walkthrough
    renderpluginsextensions
    39 Posts 8 Posters 15.1k Views 8 Watching
      Dprince
      oh ok. i guess i can only use this when i upgrade. any idea how i can do the walkthrough with Vray?
      • soloS
        On your system I doubt it, you would need a week to render it if indeed it was even possible, sorry mate but your machine is just not suited for such things.
        • ntxdaveN
          ntxdave
          Once again, I would suggest you take a look at Shapespark I think it might do what you are looking for. Yes, they have their own material handling as well.
          Press F1...thank me later
            Dprince
            for shapespaek can i save the online walkthrough as a video?
              Dprince
              @pbacot said:
              @dprince said:
              I keep getting this error when i try to run enscape
              Dprince,
              Are you running Enscape on a Mac with BootCamp? Anyway if on a Mac see if you can select the GPU by turning off Automatic graphics switching in the Energy Saver settings. It will make the computer use a higher-performing card if you have one. Of course the card might still not be up to Enscape standards.
              im using a windows computer
              • pbacotP
                Dprince,
                • ntxdaveN
                  ntxdave
                  I do not think so. The output is for viewing in HTML/WebGL and VR.
                    Dprince
                    OK THANKS. thats not exactly what i want to do it has to be in video format and not available to just online viewing
                    • pbacotP
                      Sorry, I read your profile and thought it was the Mac.
                        Dprince
                        I would still like to know how to do the walk through using vray. no matter how long it takes to render
                        • V
                          valerostudio
                          This was an issue in the past with laptops. You still may have a graphics card Enscape can use. Try this https://enscape3d.com/knowledgebase/multi-gpu-issues/
                          • V
                            valerostudio
                            VRay will render animation based on SketchUp scene tabs. For example I would make a scene tab for point A of my walkthrough, then one for point B, point C, etc.
                            Setup your animation settings in model info with Scene delay off and a reasonable amount of time for the transitions, so the speed is the way you like it.
                            Render using VRay with animation enabled and saving to a folder. VRay will save each frame out. Then use an application to combine the frames into a video file. I bet there are a bunch of free ones. Photoshop will also do this now.
                            There are plugins that can make the walkthrough smoother and with animation (doors open for example) but that becomes more complex, and you have to make sure its VRay compatible, but the procedure above is the fastest way to get up and running (pun intended).
                            Smustard had some nice path animation plugins a long time ago. I am not sure if they still work. Worth a shot.
                              Dprince
                              What settings should i have for Vray animation or better yet are should the settings be? im using vray 3.4
                              • andybotA
                                andybot
                                The settings I would recommend are having a powerful CPU or using a render-farm.
                                • PixeroP
                                  Pixero
                                  Several years ago I rendered a animation with Vray 1.5 on one PC.
                                  I believe rendering took 4-5 weeks 24/7.
                                  I would NOT do it like that again. πŸ˜†
                                  With Enscape I rendered a 4 minutes animation in less than an hour.
                                    Dprince
                                    my machine cant run enscape . each time i try it crashes
                                    • andybotA
                                      andybot
                                      If you're serious about rendering an animation with V-Ray, I would highly recommend looking at render farms, there are quite a few options out there.
                                      • soloS
                                        You said in a PM you had $1600 to spend on a new laptop, this will get it done:
                                        Amazon.com
                                        (www.amazon.com)
                                          Dprince
                                          Can you send me some examples please? Thanks
                                            Dprince
                                            Amazon.com
                                            (www.amazon.com)
                                            I was looking at this also ASUS ROG STRIX Hero Edition Gaming Laptop, https://www.amazon.com/dp/B076D95JW7/ref=cm_sw_r_cp_api_i_2m6KCb2GCA8BM
