    Rendered Walkthrough
    renderpluginsextensions
    39 Posts 8 Posters 15.1k Views 8 Watching
      Dprince
      I would still like to know how to do the walk through using vray. no matter how long it takes to render
      • V
        valerostudio
        This was an issue in the past with laptops. You still may have a graphics card Enscape can use. Try this https://enscape3d.com/knowledgebase/multi-gpu-issues/
        • V
          valerostudio
          VRay will render animation based on SketchUp scene tabs. For example I would make a scene tab for point A of my walkthrough, then one for point B, point C, etc.
          Setup your animation settings in model info with Scene delay off and a reasonable amount of time for the transitions, so the speed is the way you like it.
          Render using VRay with animation enabled and saving to a folder. VRay will save each frame out. Then use an application to combine the frames into a video file. I bet there are a bunch of free ones. Photoshop will also do this now.
          There are plugins that can make the walkthrough smoother and with animation (doors open for example) but that becomes more complex, and you have to make sure its VRay compatible, but the procedure above is the fastest way to get up and running (pun intended).
          Smustard had some nice path animation plugins a long time ago. I am not sure if they still work. Worth a shot.
            Dprince
            What settings should i have for Vray animation or better yet are should the settings be? im using vray 3.4
            • andybotA
              andybot
              The settings I would recommend are having a powerful CPU or using a render-farm.
              • PixeroP
                Pixero
                Several years ago I rendered a animation with Vray 1.5 on one PC.
                I believe rendering took 4-5 weeks 24/7.
                I would NOT do it like that again. πŸ˜†
                With Enscape I rendered a 4 minutes animation in less than an hour.
                  Dprince
                  my machine cant run enscape . each time i try it crashes
                  • andybotA
                    andybot
                    If you're serious about rendering an animation with V-Ray, I would highly recommend looking at render farms, there are quite a few options out there.
                    • soloS
                      You said in a PM you had $1600 to spend on a new laptop, this will get it done:
                      Amazon.com
                      (www.amazon.com)
                        Dprince
                        Can you send me some examples please? Thanks
                          Dprince
                          Amazon.com
                          (www.amazon.com)
                          I was looking at this also ASUS ROG STRIX Hero Edition Gaming Laptop, https://www.amazon.com/dp/B076D95JW7/ref=cm_sw_r_cp_api_i_2m6KCb2GCA8BM
                          • soloS
                            Amazon.com
                            (www.amazon.com)
                            Considering you are usimg Vray 3.4 I assume you are not using GPU rendering, so the alienware will have more cores than the ASUS, both will work great for Enscape however
                            • andybotA
                              andybot
                              Here's a list from Chaos Group: https://www.chaosgroup.com/render-farms (not all of these have SU+V-Ray support, but if you narrow the list to just SU, it misses farms like Rebus)
                              And they have their own cloud: https://www.chaosgroup.com/cloud (I haven't used it so I couldn't speak to how it compares.)
                                Dprince
                                Thanks.
                                what do u guys think about these specs thinking about building a desktop computer
                                CPU: AMD – Ryzen 5 1600 3.2GHz 6-Core Processor
                                CPU-Cooler: Already included with CPU
                                Motherboard: MSI – B350 PC MATE ATX AM4 Motherboard
                                Memory: Corsair – Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory
                                Storage: Samsung – 860 Evo 500GB 2.5β€³ Solid State Drive
                                GPU: MSI – GeForce GTX 1060 2GB Video Card
                                Case: Deepcool – DUKASE WHV2 ATX Mid Tower Case
                                Power Supply: Corsair – CX 500W 80+ Bronze Certified Semi-Modular ATX
                                • andybotA
                                  andybot
                                  Looks good. Now you can render a V-Ray animation in one week instead of four.
                                    Dprince
                                    lol. I plan on using enscape for walkthroughs/animation
                                    • soloS
                                      In that case I'd suggest a GPU with much more ram, 2gb is very little
                                      • andybotA
                                        andybot
                                        Smart plan! I have a pair of GTX 1070's and they're working great with Enscape.
                                        Also, at 8GB memory. Like Solo says, gotta have enough memory.
                                          Dprince
                                          Thanks for the suggestion champ
                                            Dprince
                                            I was thinking about getting the Nvidia GTX 1060 8gb
                                            • 2 / 2
