    Rendered Walkthrough
    renderpluginsextensions
    39 Posts 8 Posters 14.1k Views 8 Watching
    • ntxdaveN Offline
      ntxdave
      You can also look at Shapespark
      Press F1...thank me later
        Dprince
        does enscape adapt the material settings from vray when doing the walkthrough rendering?
        • soloS Offline
          No, Enscape has it's own material system, does not adapt Vray materials, very simple and fast software to achieve animation and VR work
          • andybotA Offline
            andybot
            I've moved from V-Ray to Enscape recently for walk-throughs, and can highly recommend it!
              Dprince
              I keep getting this error when i try to run enscape
              • soloS Offline
                The warning has to do with your GPU, I assume you are on a laptop with an Intel integrated GPU which is not good enough to work with Enscape.
                  Dprince
                  oh ok. i guess i can only use this when i upgrade. any idea how i can do the walkthrough with Vray?
                  • soloS Offline
                    On your system I doubt it, you would need a week to render it if indeed it was even possible, sorry mate but your machine is just not suited for such things.
                    • ntxdaveN Offline
                      ntxdave
                      Once again, I would suggest you take a look at Shapespark I think it might do what you are looking for. Yes, they have their own material handling as well.
                        Dprince
                        for shapespaek can i save the online walkthrough as a video?
                          Dprince
                          @pbacot said:
                          Dprince,
                          Are you running Enscape on a Mac with BootCamp? Anyway if on a Mac see if you can select the GPU by turning off Automatic graphics switching in the Energy Saver settings. It will make the computer use a higher-performing card if you have one. Of course the card might still not be up to Enscape standards.
                          im using a windows computer
                          • pbacotP Offline
                            Dprince,
                            • ntxdaveN Offline
                              ntxdave
                              I do not think so. The output is for viewing in HTML/WebGL and VR.
                                Dprince
                                OK THANKS. thats not exactly what i want to do it has to be in video format and not available to just online viewing
                                • pbacotP Offline
                                  Sorry, I read your profile and thought it was the Mac.
                                    Dprince
                                    I would still like to know how to do the walk through using vray. no matter how long it takes to render
                                    • V Offline
                                      valerostudio
                                      This was an issue in the past with laptops. You still may have a graphics card Enscape can use. Try this https://enscape3d.com/knowledgebase/multi-gpu-issues/
                                      • V Offline
                                        valerostudio
                                        VRay will render animation based on SketchUp scene tabs. For example I would make a scene tab for point A of my walkthrough, then one for point B, point C, etc.
                                        Setup your animation settings in model info with Scene delay off and a reasonable amount of time for the transitions, so the speed is the way you like it.
                                        Render using VRay with animation enabled and saving to a folder. VRay will save each frame out. Then use an application to combine the frames into a video file. I bet there are a bunch of free ones. Photoshop will also do this now.
                                        There are plugins that can make the walkthrough smoother and with animation (doors open for example) but that becomes more complex, and you have to make sure its VRay compatible, but the procedure above is the fastest way to get up and running (pun intended).
                                        Smustard had some nice path animation plugins a long time ago. I am not sure if they still work. Worth a shot.
                                          Dprince
                                          What settings should i have for Vray animation or better yet are should the settings be? im using vray 3.4
                                          • andybotA Offline
                                            andybot
                                            The settings I would recommend are having a powerful CPU or using a render-farm.
