    Rendered Walkthrough
    renderpluginsextensions
    39 Posts 8 Posters 14.1k Views 8 Watching
    • V Offline
      valerostudio
      This was an issue in the past with laptops. You still may have a graphics card Enscape can use. Try this https://enscape3d.com/knowledgebase/multi-gpu-issues/
      • V Offline
        valerostudio
        @dprince said:
        I would still like to know how to do the walk through using vray. no matter how long it takes to render
        VRay will render animation based on SketchUp scene tabs. For example I would make a scene tab for point A of my walkthrough, then one for point B, point C, etc.
        Setup your animation settings in model info with Scene delay off and a reasonable amount of time for the transitions, so the speed is the way you like it.
        Render using VRay with animation enabled and saving to a folder. VRay will save each frame out. Then use an application to combine the frames into a video file. I bet there are a bunch of free ones. Photoshop will also do this now.
        There are plugins that can make the walkthrough smoother and with animation (doors open for example) but that becomes more complex, and you have to make sure its VRay compatible, but the procedure above is the fastest way to get up and running (pun intended).
        Smustard had some nice path animation plugins a long time ago. I am not sure if they still work. Worth a shot.
          Dprince
          What settings should i have for Vray animation or better yet are should the settings be? im using vray 3.4
          • andybotA Offline
            andybot
            The settings I would recommend are having a powerful CPU or using a render-farm.
            • PixeroP Offline
              Pixero
              Several years ago I rendered a animation with Vray 1.5 on one PC.
              I believe rendering took 4-5 weeks 24/7.
              I would NOT do it like that again. πŸ˜†
              With Enscape I rendered a 4 minutes animation in less than an hour.
                Dprince
                my machine cant run enscape . each time i try it crashes
                • andybotA Offline
                  andybot
                  If you're serious about rendering an animation with V-Ray, I would highly recommend looking at render farms, there are quite a few options out there.
                  • soloS Offline
                    You said in a PM you had $1600 to spend on a new laptop, this will get it done:
                    Amazon.com
                    (www.amazon.com)
                      Dprince
                      Can you send me some examples please? Thanks
                        Dprince
                        Amazon.com
                        (www.amazon.com)
                        I was looking at this also ASUS ROG STRIX Hero Edition Gaming Laptop, https://www.amazon.com/dp/B076D95JW7/ref=cm_sw_r_cp_api_i_2m6KCb2GCA8BM
                        • soloS Offline
                          Amazon.com
                          (www.amazon.com)
                          Considering you are usimg Vray 3.4 I assume you are not using GPU rendering, so the alienware will have more cores than the ASUS, both will work great for Enscape however
                          • andybotA Offline
                            andybot
                            Here's a list from Chaos Group: https://www.chaosgroup.com/render-farms (not all of these have SU+V-Ray support, but if you narrow the list to just SU, it misses farms like Rebus)
                            And they have their own cloud: https://www.chaosgroup.com/cloud (I haven't used it so I couldn't speak to how it compares.)
                              Dprince
                              Thanks.
                              what do u guys think about these specs thinking about building a desktop computer
                              CPU: AMD – Ryzen 5 1600 3.2GHz 6-Core Processor
                              CPU-Cooler: Already included with CPU
                              Motherboard: MSI – B350 PC MATE ATX AM4 Motherboard
                              Memory: Corsair – Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory
                              Storage: Samsung – 860 Evo 500GB 2.5β€³ Solid State Drive
                              GPU: MSI – GeForce GTX 1060 2GB Video Card
                              Case: Deepcool – DUKASE WHV2 ATX Mid Tower Case
                              Power Supply: Corsair – CX 500W 80+ Bronze Certified Semi-Modular ATX
                              • andybotA Offline
                                andybot
                                Looks good. Now you can render a V-Ray animation in one week instead of four.
                                  Dprince
                                  lol. I plan on using enscape for walkthroughs/animation
                                  • soloS Offline
                                    In that case I'd suggest a GPU with much more ram, 2gb is very little
                                    • andybotA Offline
                                      andybot
                                      Smart plan! I have a pair of GTX 1070's and they're working great with Enscape.
                                      Also, at 8GB memory. Like Solo says, gotta have enough memory.
                                        Dprince
                                        Thanks for the suggestion champ
                                          Dprince
                                          I was thinking about getting the Nvidia GTX 1060 8gb
                                          • V Offline
                                            valerostudio
                                            VRay cloud is very nicely integrated and easy to use but I thought that I read that you can find cheaper farms out there. The price tag of Enscape will pay for itself with one animation job. Not pushing Enscape down your throat but we have all been there with V-Ray and Enscape is just damn fast and easy.
                                            • 2 / 2
