    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 622.3k Views 135 Watching
    • david_hD
      david_h
      Thank you! it's really quite amazing how much of the basic stuff you forget when you don't dealwith it that often.
      D
        Yes it is amazing indeed.
        And it shows how deep SketchUp can be.
          rv1974
          Curic Extend is amazing!
          https://gumroad.com/curic
          50% discount code:
          10k followers
            A tool EXTRUDE EDGES BY VECTOR BY tig don't make the same ? πŸ˜‰
            http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=18111;image
              rv1974
              no, Curic works with multiple independent objects (groups, components) and\or its faces instantly.
              Does Tig's one extrude to a curved object?
                Yes.
                  rv1974
                  Very good, but once again ability to process multiple objects regardless the context makes night and day difference.
                    My EE... tool extends selected edges and by connection their faces to any objects in the way of the vector-path, or a picked point on that path - whichever is appropriate. It doesn't process the contents of selected groups etc, so you must edit them and select the geometry to process.
                    The objects to which it extrudes must include some faces [even if nested inside groups etc] - so curved surfaces are accommodated...
                    • K
                      Khai
                      My biggest Doh!
                      Struggling with microfaces on a component..
                      Brain : this is a component!
                      Me : I know
                      Brain : no, this is a component, get it?
                      Me : I know! Will you shuv up?
                      Brain : idiot. Copy it, enlarge it 500% over there, and then work on it, they won't be microfaces anymore and life will be easy. Pillock.
                      • BoxB
                        Why on earth is Curic Extend in this thread!
                        If you want to post it put it in a thread of its own in the Plugins SubForum.
                          @khai said:
                          My biggest Doh!
                          Me : I know
                          As demonstrated by Box:
                          403 Forbidden
                          (sketchucation.com)
                          • david_hD
                            david_h
                            Fellow Wizards:
                            so in previous versions of SU there was a blue icon with a query (?) symbol or something that would give you all the statistics of a model and the ability to fix and purge throughout. What happened to that too in V 18? Entity Info doesn't quite do it for me.
                            thx,
                            D
                              @david_h said:
                              so in previous versions of SU there was a blue icon with a query (?) symbol or something that would give you all the statistics...
                              I suspect you mean the Query tool which creates something that looks like this:
                              That is part of the Utilities Tools available from the Extension Warehouse.
                                CleanUp3? TIG's Purge All?
                                Do you still have the older version of SketchUp installed so you could check to see what it is called?
                                • david_hD
                                  david_h
                                  Thanks Dave. No. . it was a statistics tool of some kind. I didn't use it much but I need it today to find out where some problems are and that it can fix them.
                                  It had a menu that would come up that would show all the entities and an option to fix problems etc.
                                  again, Thanks.
                                  D
                                  EDIT: This just in:
                                  I think I found it!
                                  thx again.
                                  • david_hD
                                    david_h
                                    It was in the Window Menu. I just did't know to look for it there cuz it had it's own toolbar icon but it doesn't now.
                                    So. . . .
                                      A cool one never too late! πŸ’š
                                      • Draw a box
                                      • Draw a Line Guide in whatever direction wished
                                      • Release the mouse and type any integer fraction N/D in the VCB with your 2 hands! πŸ˜„
                                        7/3 for example...
                                        (any time you want till the good position of the Guide line wished! 😎
                                      I don't know why that works not with N*D or N+D or N-D ❓
                                        With the same tool : how to draw an only one Guide Point in the Space without plugin! πŸ˜„
                                        Draw with the Tape tool any one Guide point on an Edge (not on an hot point)
                                        (on a middle edge you can't draw a guide point)
                                        Move this Guide Point in the space
                                        Et voilΓ  πŸ˜„
                                          slbaumgartner
                                          It works with N/D as a side effect of supporting fractional inches. Though it's a common request, the measurement box doesn't support arithmetic and doesn't really understand division other than integer ratios.
                                          • BepB
                                            Bep
                                            Don't make this mistake.
                                            I unfolded a cilinder/ring, and measured its area (cmΒ²) with the tekst tool, with hidden lines turned off in view. (bottom strip of fig 1)
                                            The strip at the top drawn with the rectangle tool shows the correct area.
                                            although the face, when selected looks undivided, the square cmΒ² turn out to be only for a part of the ring.(fig 2)
                                            I notest, that drawn with the rectangle tool, entity-info identify's the rectangle as a face, and the unfolded rectangle as a surface.
                                            fig 1
                                            hidden lines off
                                            fig 2
                                            hidden lines on
                                            test
                                            "History is written by the winners"
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 34 / 35
