    [Plugin] ReGlue
    35 Posts 11 Posters 14.3k Views 11 Watching
      rv1974
      TIG, Is it possible to enable multiple components (implemented above by TommyK) re-glueing to multiple faces please?
      • TIGT Online
        An instance can only glue to one face.
        It's a limitation within SketchUp, not the API.
          rv1974
          Does this API the Great and Powerful, allows to select all the components glued to a preselected face? If yes, maybe the script could take one face, select all the glued and reglue; then go to another face, repeat reglueing, and so on?
          • PixeroP Offline
            Pixero
            Maybe Fredotools Move along could be helpful?
            • TIGT Online
              ToomyK's version a few posts back does that.
              Just replace the text in the RB file with his alternative and save it.
              Use a plain-text editor like Notepad++ to do the editing.
              • TIGT Online
                How is the code to determine which of the selected components gets glued to which selected face ?
                Please outline the 'logic'...
                  rv1974
                  No, TommyK's code works only with one face.
                  @Pixero, the connection between MoveAlong and reglueing slips away from me.
                    rv1974
                    Thats what I tried to ask you earlier- Whether API allows to detect the components glued to a preselected face. IF the answer is YES, then MAYBE the script could(?) progressevly take face by face and reglue corresponding components.
                    • hdpvH Offline
                      hdpv
                      @rv1974
                      I did this but it’s small script. Select face and components for reglue.
                      Suforyou
                      http://www.sketchupforyou.com
                        rv1974
                        @hdpv said:
                        @rv1974
                        and components? or face only?
                        • TIGT Online
                          There is a method:
                          glued = face.get_glued_instances
                          And it'd be easy to grep then iterate all of the faces and their glued components etc...
                          BUT there's no API ' .could_be_glued_instances' method...
                          BUT here's some possible [pretty much untested] code which might just do it...
                          ctr=0
                          model=Sketchup.active_model
                          faces=model.active_entities.grep(Sketchup;;Face)
                          comps=model.active_entities.grep(Sketchup;;ComponentInstance).find_all{|e|
                            e.definition.behavior.is2d? && ! e.glued_to
                          ### collect if comp can glue, but not glued !
                          cct=comps.length
                          faces.each{|f|
                            plane=f.plane
                            norm =f.normal
                            comps.dup.each{|e|
                              pt=e.transformation.origin
                              nm=e.transformation.zaxis
                              if pt.distance_to_plane(plane)==0 && norm==nm
                                ### glue-able
                                cp=f.classify_point(pt)
                                if cp==Sketchup;;Face;;PointInside || cp==Sketchup;;Face;;PointOnEdge || cp==Sketchup;;Face;;PointOnVertex
                                  ### on face so can glue
                                  e.glued_to=f
                                  comps.delete(e)
                                  ctr+=1
                                  ### reduce tested comps collection for speed
                          puts "\n\nReglued #{ctr} of #{cct}" ### print how many reglued
                            rv1974
                            @TIG This plugin reglues multiple components in SU 2022. In v2023 and newer it reglues only one component.
                            What is the reason for this degradation? Thanks
                            TIGT 1 Reply Last reply Reply Quote 0
                            • TIGT Online
                              TIG Moderator @rv1974
                              @rv1974
                              This plugin is over a decade old !
                              As far as I recall, and tell from the code and version, it has always needed a selection of one face and one component to work. for 19 years.
                              Although I do see from my posts do speaks of one or more components being processed...
                              As far as I can see this old code is very simplistic... e.g.
                              It does not check for gluing properties, or face-normal, or Z-axis, or position on the face.plane, or transformation.origin point on the face at all.
                              If it checked for several components being on the face and sharing the face.normal as their Z-axis etc, then it would be possible the get it to process several gluing components. However, this would require a complete rewrite...
                              I'll back check...
                              • TIGT Online
                                Here's v2.0 in the PluginStore...
                                https://sketchucation.com/pluginstore?pln=Re_Glue
                                It now allows multiple pre selected component-instances, but still only one preselected face.
                                These are glued to the face [is possible], any errors or unsuitable instances are reported in the Ruby Console...
                                R 1 Reply Last reply Reply Quote 1
                                  rv1974 @TIG
                                  @TIG Many thanks!
                                  designerbursaD 1 Reply Last reply Reply Quote 0
                                  • designerbursaD Offline
                                    designerbursa @rv1974
                                    @rv1974
                                    def self.glue_components_to_faces
                                      model = Sketchup.active_model
                                      selection = model.selection
                                      return UI.messagebox("Error: No selection!") if selection.empty?
                                      faces = selection.grep(Sketchup::Face)
                                      components = selection.grep(Sketchup::ComponentInstance)
                                      return UI.messagebox("Error: Select faces and components!") if faces.empty? || components.empty?
                                      model.start_operation("Glue Components to Faces", true)
                                      begin
                                        components.each do |component|
                                          closest_face = find_closest_aligned_face(component, faces)
                                          component.glued_to = closest_face if closest_face
                                      ensure
                                        model.commit_operation
                                    def self.find_closest_aligned_face(component, faces)
                                      component_normal = component.transformation.zaxis
                                      closest_face = faces.min_by { |face| face.normal.angle_between(component_normal) }
                                      closest_face
                                    R 1 Reply Last reply Reply Quote 0
                                      rv1974 @designerbursa
                                      @designerbursa what do you mean?
                                        @rv1974 I developed the code for pasting on all selected surfaces at once, it would be useful for everyone if it is updated in this way.
                                          @designerbursa
                                          I might be missing something but currently I can do it without any plugin
                                            @rv1974 If you can paste without extensions, I really congratulate you...
