    [Plugin] ReGlue
    35 Posts 11 Posters 15.7k Views 11 Watching
    • TommyKT
      TommyK
      There are times when I would like to select several components and reglue them to a face with one "ReGlue" operation. I have modified TIG's code a little to allow multiple selections of components. Hope you don't mind, TIG. The code is below, and not tested that much....
      # Copyright 2006-2013, TIG
      # Permission to use, copy, modify, and distribute this software for
      # any purpose and without fee is hereby granted, provided the above
      # copyright notice appear in all copies.
      # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      # Name; ReGlue
      # Description; A Tool to ReGlue a Component to a [recreated] Face.
      # Menu Item; Plugins -> ReGlue
      # Author; TIG
      # Usage; Select ONE Face and ONE [or MORE] UnGlued Component[s].
      # Use with care - because by picking a Component and an
      # unconnected Face you can 'UnGlue' it and 'ReGlue' it
      # onto this new Face even if it's not actually on the same
      # plane or at the same rotation !
      # Version;	1.0	27/12/06	First issue.
      # 1.1 20131210 Future-proofed
      require('sketchup.rb')
      module TIG
      module TIG;;ReGlue
      def self.do()
        model=Sketchup.active_model
        model.start_operation("ReGlue")
        ss=model.selection
       def self.status(txt)
        Sketchup;;set_status_text(txt, SB_PROMPT)
        Sketchup;;set_status_text(" ", SB_VCB_LABEL)
        Sketchup;;set_status_text(" ", SB_VCB_VALUE)
       end#def status
       def self.error(txt)
        self.status("REGLUE; ERROR...")
        UI.messagebox(txt)
        return nil
       end#def error
      	return self.error("ReGlue;\nNO Selection !") if ss.empty?
      	faces=ss.grep(Sketchup;;Face)
      	comps=ss.grep(Sketchup;;ComponentInstance)
      	return self.error("ReGlue;\nSelection MUST contain ONE Face !") if faces.length==0 || faces[1]
      	return self.error("ReGlue;\nSelection MUST contain ONE Component !") if comps.length==0
      	face=faces[0]
      	#Do for each component
      	i = 0
      	while defined? comps[i] do
      	  comp=comps[i]
      	  return nil unless comp && face
      	  comp.glued_to = face
      	  i = i + 1
      	end#while
         model.commit_operation
      end#def
      unless file_loaded?(__FILE__)###
        UI.menu("Plugins").add_item("ReGlue"){self.do()}
      file_loaded(__FILE__)###
      end#module
      end#TIG
      • K
        kaas
        nice little gem TIG. Saves a lot of repetitive stupid work. 👍
        Just as TommyK I changed it to a multiple reglue by
        comps.each{|c|c.glued_to = face}
        and uncommenting the
        #return self.error("ReGlue:\nSelection MUST contain ONE Component !") if comps.length==0 || comps[1] #comp=comps[0] #comp.glued_to = face
        • JQLJ
          JQL
          I also feel the need to have multiple components reglued. I'm used to using Superglue for that but Tig's Reglue works much better.
          So, Tig, are you thinking of adapting your own script to any of the above methods?
          If not, I think I'll use Tommy's from now on...
          Thank you guys!
          www.casca.pt
          Visit us on facebook!
            rv1974
            TIG, Is it possible to enable multiple components (implemented above by TommyK) re-glueing to multiple faces please?
              An instance can only glue to one face.
              It's a limitation within SketchUp, not the API.
                rv1974
                Does this API the Great and Powerful, allows to select all the components glued to a preselected face? If yes, maybe the script could take one face, select all the glued and reglue; then go to another face, repeat reglueing, and so on?
                • PixeroP
                  Pixero
                  Maybe Fredotools Move along could be helpful?
                    ToomyK's version a few posts back does that.
                    Just replace the text in the RB file with his alternative and save it.
                    Use a plain-text editor like Notepad++ to do the editing.
                      How is the code to determine which of the selected components gets glued to which selected face ?
                      Please outline the 'logic'...
                        rv1974
                        No, TommyK's code works only with one face.
                        @Pixero, the connection between MoveAlong and reglueing slips away from me.
                          rv1974
                          Thats what I tried to ask you earlier- Whether API allows to detect the components glued to a preselected face. IF the answer is YES, then MAYBE the script could(?) progressevly take face by face and reglue corresponding components.
                          • hdpvH
                            hdpv
                            @rv1974
                            I did this but it’s small script. Select face and components for reglue.
                            Suforyou
                            http://www.sketchupforyou.com
                              rv1974
                              @hdpv said:
                              @rv1974
                              and components? or face only?
                                There is a method:
                                glued = face.get_glued_instances
                                And it'd be easy to grep then iterate all of the faces and their glued components etc...
                                BUT there's no API ' .could_be_glued_instances' method...
                                BUT here's some possible [pretty much untested] code which might just do it...
                                ctr=0
                                faces=model.active_entities.grep(Sketchup;;Face)
                                comps=model.active_entities.grep(Sketchup;;ComponentInstance).find_all{|e|
                                  e.definition.behavior.is2d? && ! e.glued_to
                                ### collect if comp can glue, but not glued !
                                cct=comps.length
                                faces.each{|f|
                                  plane=f.plane
                                  norm =f.normal
                                  comps.dup.each{|e|
                                    pt=e.transformation.origin
                                    nm=e.transformation.zaxis
                                    if pt.distance_to_plane(plane)==0 && norm==nm
                                      ### glue-able
                                      cp=f.classify_point(pt)
                                      if cp==Sketchup;;Face;;PointInside || cp==Sketchup;;Face;;PointOnEdge || cp==Sketchup;;Face;;PointOnVertex
                                        ### on face so can glue
                                        e.glued_to=f
                                        comps.delete(e)
                                        ctr+=1
                                        ### reduce tested comps collection for speed
                                puts "\n\nReglued #{ctr} of #{cct}" ### print how many reglued
                                  rv1974
                                  @TIG This plugin reglues multiple components in SU 2022. In v2023 and newer it reglues only one component.
                                  What is the reason for this degradation? Thanks
                                  TIGT 1 Reply Last reply
                                    TIG Moderator @rv1974
                                    @rv1974
                                    This plugin is over a decade old !
                                    As far as I recall, and tell from the code and version, it has always needed a selection of one face and one component to work. for 19 years.
                                    Although I do see from my posts do speaks of one or more components being processed...
                                    As far as I can see this old code is very simplistic... e.g.
                                    It does not check for gluing properties, or face-normal, or Z-axis, or position on the face.plane, or transformation.origin point on the face at all.
                                    If it checked for several components being on the face and sharing the face.normal as their Z-axis etc, then it would be possible the get it to process several gluing components. However, this would require a complete rewrite...
                                    I'll back check...
                                      Here's v2.0 in the PluginStore...
                                      https://sketchucation.com/pluginstore?pln=Re_Glue
                                      It now allows multiple pre selected component-instances, but still only one preselected face.
                                      These are glued to the face [is possible], any errors or unsuitable instances are reported in the Ruby Console...
                                      R 1 Reply Last reply
                                        rv1974 @TIG
                                        @TIG Many thanks!
                                        designerbursaD 1 Reply Last reply
                                        • designerbursaD
                                          designerbursa @rv1974
                                          @rv1974
                                          def self.glue_components_to_faces
                                            model = Sketchup.active_model
                                            selection = model.selection
                                            return UI.messagebox("Error: No selection!") if selection.empty?
                                            faces = selection.grep(Sketchup::Face)
                                            components = selection.grep(Sketchup::ComponentInstance)
                                            return UI.messagebox("Error: Select faces and components!") if faces.empty? || components.empty?
                                            model.start_operation("Glue Components to Faces", true)
                                            begin
                                              components.each do |component|
                                                closest_face = find_closest_aligned_face(component, faces)
                                                component.glued_to = closest_face if closest_face
                                            ensure
                                          def self.find_closest_aligned_face(component, faces)
                                            component_normal = component.transformation.zaxis
                                            closest_face = faces.min_by { |face| face.normal.angle_between(component_normal) }
                                            closest_face
                                            rv1974 @designerbursa
                                            @designerbursa what do you mean?
