    [Plugin] ReGlue
    35 Posts 11 Posters 15.2k Views 11 Watching
      How is the code to determine which of the selected components gets glued to which selected face ?
      Please outline the 'logic'...
        rv1974
        @tig said:
        @rv1974 said:
        Does this API the Great and Powerful, allows to select all the components glued to a preselected face? If yes, maybe the script could take one face, select all the glued and reglue; then go to another face, repeat reglueing, and so on?
        ToomyK's version a few posts back does that.
        Just replace the text in the RB file with his alternative and save it.
        Use a plain-text editor like Notepad++ to do the editing.
        No, TommyK's code works only with one face.
        @Pixero, the connection between MoveAlong and reglueing slips away from me.
          rv1974
          Thats what I tried to ask you earlier- Whether API allows to detect the components glued to a preselected face. IF the answer is YES, then MAYBE the script could(?) progressevly take face by face and reglue corresponding components.
          • hdpvH Offline
            hdpv
            @rv1974
            I did this but it’s small script. Select face and components for reglue.
            Suforyou
            http://www.sketchupforyou.com
              rv1974
              @hdpv said:
              @rv1974
              and components? or face only?
                There is a method:
                glued = face.get_glued_instances
                And it'd be easy to grep then iterate all of the faces and their glued components etc...
                BUT there's no API ' .could_be_glued_instances' method...
                BUT here's some possible [pretty much untested] code which might just do it...
                ctr=0
                model=Sketchup.active_model
                faces=model.active_entities.grep(Sketchup;;Face)
                comps=model.active_entities.grep(Sketchup;;ComponentInstance).find_all{|e|
                  e.definition.behavior.is2d? && ! e.glued_to
                ### collect if comp can glue, but not glued !
                cct=comps.length
                faces.each{|f|
                  plane=f.plane
                  norm =f.normal
                  comps.dup.each{|e|
                    pt=e.transformation.origin
                    nm=e.transformation.zaxis
                    if pt.distance_to_plane(plane)==0 && norm==nm
                      ### glue-able
                      cp=f.classify_point(pt)
                      if cp==Sketchup;;Face;;PointInside || cp==Sketchup;;Face;;PointOnEdge || cp==Sketchup;;Face;;PointOnVertex
                        ### on face so can glue
                        e.glued_to=f
                        comps.delete(e)
                        ctr+=1
                        ### reduce tested comps collection for speed
                puts "\n\nReglued #{ctr} of #{cct}" ### print how many reglued
                  rv1974
                  @TIG This plugin reglues multiple components in SU 2022. In v2023 and newer it reglues only one component.
                  What is the reason for this degradation? Thanks
                  TIGT 1 Reply Last reply Reply Quote 0
                    TIG Moderator @rv1974
                    @rv1974
                    This plugin is over a decade old !
                    As far as I recall, and tell from the code and version, it has always needed a selection of one face and one component to work. for 19 years.
                    Although I do see from my posts do speaks of one or more components being processed...
                    As far as I can see this old code is very simplistic... e.g.
                    It does not check for gluing properties, or face-normal, or Z-axis, or position on the face.plane, or transformation.origin point on the face at all.
                    If it checked for several components being on the face and sharing the face.normal as their Z-axis etc, then it would be possible the get it to process several gluing components. However, this would require a complete rewrite...
                    I'll back check...
                      Here's v2.0 in the PluginStore...
                      https://sketchucation.com/pluginstore?pln=Re_Glue
                      It now allows multiple pre selected component-instances, but still only one preselected face.
                      These are glued to the face [is possible], any errors or unsuitable instances are reported in the Ruby Console...
                      R 1 Reply Last reply Reply Quote 1
                        rv1974 @TIG
                        @TIG Many thanks!
                        designerbursaD 1 Reply Last reply Reply Quote 0
                        • designerbursaD Offline
                          designerbursa @rv1974
                          @rv1974
                          def self.glue_components_to_faces
                            model = Sketchup.active_model
                            selection = model.selection
                            return UI.messagebox("Error: No selection!") if selection.empty?
                            faces = selection.grep(Sketchup::Face)
                            components = selection.grep(Sketchup::ComponentInstance)
                            return UI.messagebox("Error: Select faces and components!") if faces.empty? || components.empty?
                            model.start_operation("Glue Components to Faces", true)
                            begin
                              components.each do |component|
                                closest_face = find_closest_aligned_face(component, faces)
                                component.glued_to = closest_face if closest_face
                            ensure
                              model.commit_operation
                          def self.find_closest_aligned_face(component, faces)
                            component_normal = component.transformation.zaxis
                            closest_face = faces.min_by { |face| face.normal.angle_between(component_normal) }
                            closest_face
                          R 1 Reply Last reply Reply Quote 0
                            rv1974 @designerbursa
                            @designerbursa what do you mean?
                              @rv1974 I developed the code for pasting on all selected surfaces at once, it would be useful for everyone if it is updated in this way.
                                @designerbursa
                                I might be missing something but currently I can do it without any plugin
                                  @rv1974 If you can paste without extensions, I really congratulate you...
                                    @designerbursa
                                      @rv1974 I am using Sketchup 2021 version
                                        designerbursa @designerbursa
                                        @designerbursa ```
                                        module GlueComponentsToFaces
                                          extend self
                                          def glue_components_to_faces
                                            if selection.empty?
                                              return UI.messagebox("Error: No selection! Please select faces and components.")
                                            begin
                                            rescue => e
                                              UI.messagebox("An error occurred: #{e.message}")
                                            ensure
                                          def find_closest_aligned_face(component, faces)
                                            closest_face
                                        # Adding a menu item for ease of use in SketchUp
                                        if not file_loaded?(__FILE__)
                                          UI.menu("Plugins").add_item("Glue Components to Faces") {
                                            GlueComponentsToFaces.glue_components_to_faces
                                          file_loaded(__FILE__)
                                        ### I haven't tested it on the 2024 version but you can try this, maybe it will work. It works smoothly on my 2021 version
                                          @designerbursa I took a closer look.. your version is indeed more advanced and user friendly, many thanks!
                                          P.S. you can cut and paste in place multiple and un-glued components in any SU version to get the same positive result, but your script is less laborious indeed.
                                            designerbursa
                                            module Reglue
                                                extend self
                                                # Menü öğesinin eklenme konumunu belirleyen değişken
                                                SUPPORT_MENU_POSITION ||= Sketchup::Menu.instance_method(:add_item).arity != 1 ? 8 : nil
                                                  if selection.empty?
                                                    UI.messagebox("Hata: Hiçbir seçim yapılmadı!")
                                                    return
                                                  components = selection.grep(Sketchup::ComponentInstance).select { |comp| comp.glued_to.nil? }
                                                    UI.messagebox("Hata: Lütfen hem yüzeyleri hem de yapıştırılabilir bileşenleri seçin!")
                                                    return
                                                  model.start_operation("Bileşenleri Yüzeylere Yeniden Yapıştır", true)
                                                unless @loaded
                                                  UI.add_context_menu_handler do |menu|
                                                    selection = Sketchup.active_model.selection
                                                    next if selection.empty?
                                                    has_faces = selection.any? { |entity| entity.is_a?(Sketchup::Face) }
                                                    has_glueable_components = selection.any? { |entity| entity.is_a?(Sketchup::ComponentInstance) && entity.glued_to.nil? }
                                                    if has_faces && has_glueable_components
                                                      position = SUPPORT_MENU_POSITION
                                                      menu.add_item("Reglue", position) { glue_components_to_faces }
                                                  @loaded = true
                                            • 2 / 2
