    [Plugin] ReGlue
    35 Posts 11 Posters 15.7k Views 11 Watching
    • hdpvH
      hdpv
      @rv1974
      I did this but it’s small script. Select face and components for reglue.
      Suforyou
      http://www.sketchupforyou.com
        rv1974
        @hdpv said:
        @rv1974
        and components? or face only?
          There is a method:
          glued = face.get_glued_instances
          And it'd be easy to grep then iterate all of the faces and their glued components etc...
          BUT there's no API ' .could_be_glued_instances' method...
          BUT here's some possible [pretty much untested] code which might just do it...
          ctr=0
          model=Sketchup.active_model
          faces=model.active_entities.grep(Sketchup;;Face)
          comps=model.active_entities.grep(Sketchup;;ComponentInstance).find_all{|e|
            e.definition.behavior.is2d? && ! e.glued_to
          ### collect if comp can glue, but not glued !
          cct=comps.length
          faces.each{|f|
            plane=f.plane
            norm =f.normal
            comps.dup.each{|e|
              pt=e.transformation.origin
              nm=e.transformation.zaxis
              if pt.distance_to_plane(plane)==0 && norm==nm
                ### glue-able
                cp=f.classify_point(pt)
                if cp==Sketchup;;Face;;PointInside || cp==Sketchup;;Face;;PointOnEdge || cp==Sketchup;;Face;;PointOnVertex
                  ### on face so can glue
                  e.glued_to=f
                  comps.delete(e)
                  ctr+=1
                  ### reduce tested comps collection for speed
          puts "\n\nReglued #{ctr} of #{cct}" ### print how many reglued
            rv1974
            @TIG This plugin reglues multiple components in SU 2022. In v2023 and newer it reglues only one component.
            What is the reason for this degradation? Thanks
            TIGT 1 Reply Last reply
              TIG Moderator @rv1974
              @rv1974
              This plugin is over a decade old !
              As far as I recall, and tell from the code and version, it has always needed a selection of one face and one component to work. for 19 years.
              Although I do see from my posts do speaks of one or more components being processed...
              As far as I can see this old code is very simplistic... e.g.
              It does not check for gluing properties, or face-normal, or Z-axis, or position on the face.plane, or transformation.origin point on the face at all.
              If it checked for several components being on the face and sharing the face.normal as their Z-axis etc, then it would be possible the get it to process several gluing components. However, this would require a complete rewrite...
              I'll back check...
                Here's v2.0 in the PluginStore...
                https://sketchucation.com/pluginstore?pln=Re_Glue
                It now allows multiple pre selected component-instances, but still only one preselected face.
                These are glued to the face [is possible], any errors or unsuitable instances are reported in the Ruby Console...
                R 1 Reply Last reply
                  rv1974 @TIG
                  @TIG Many thanks!
                  designerbursaD 1 Reply Last reply
                  • designerbursaD
                    designerbursa @rv1974
                    @rv1974
                    def self.glue_components_to_faces
                      model = Sketchup.active_model
                      selection = model.selection
                      return UI.messagebox("Error: No selection!") if selection.empty?
                      faces = selection.grep(Sketchup::Face)
                      components = selection.grep(Sketchup::ComponentInstance)
                      return UI.messagebox("Error: Select faces and components!") if faces.empty? || components.empty?
                      model.start_operation("Glue Components to Faces", true)
                      begin
                        components.each do |component|
                          closest_face = find_closest_aligned_face(component, faces)
                          component.glued_to = closest_face if closest_face
                      ensure
                        model.commit_operation
                    def self.find_closest_aligned_face(component, faces)
                      component_normal = component.transformation.zaxis
                      closest_face = faces.min_by { |face| face.normal.angle_between(component_normal) }
                      closest_face
                      rv1974 @designerbursa
                      @designerbursa what do you mean?
                      • designerbursaD
                        @rv1974 I developed the code for pasting on all selected surfaces at once, it would be useful for everyone if it is updated in this way.
                          @designerbursa
                          I might be missing something but currently I can do it without any plugin
                          • designerbursaD
                            @rv1974 If you can paste without extensions, I really congratulate you...
                              @designerbursa
                              • designerbursaD
                                @rv1974 I am using Sketchup 2021 version
                                • designerbursaD
                                  designerbursa @designerbursa
                                  @designerbursa ```
                                  module GlueComponentsToFaces
                                    extend self
                                    def glue_components_to_faces
                                      if selection.empty?
                                        return UI.messagebox("Error: No selection! Please select faces and components.")
                                      begin
                                      rescue => e
                                        UI.messagebox("An error occurred: #{e.message}")
                                      ensure
                                    def find_closest_aligned_face(component, faces)
                                      closest_face
                                  # Adding a menu item for ease of use in SketchUp
                                  if not file_loaded?(__FILE__)
                                    UI.menu("Plugins").add_item("Glue Components to Faces") {
                                      GlueComponentsToFaces.glue_components_to_faces
                                    file_loaded(__FILE__)
                                  ### I haven't tested it on the 2024 version but you can try this, maybe it will work. It works smoothly on my 2021 version
                                    @designerbursa I took a closer look.. your version is indeed more advanced and user friendly, many thanks!
                                    P.S. you can cut and paste in place multiple and un-glued components in any SU version to get the same positive result, but your script is less laborious indeed.
                                    • designerbursaD
                                      designerbursa
                                      module Reglue
                                          extend self
                                          # Menü öğesinin eklenme konumunu belirleyen değişken
                                          SUPPORT_MENU_POSITION ||= Sketchup::Menu.instance_method(:add_item).arity != 1 ? 8 : nil
                                            if selection.empty?
                                              UI.messagebox("Hata: Hiçbir seçim yapılmadı!")
                                              return
                                            components = selection.grep(Sketchup::ComponentInstance).select { |comp| comp.glued_to.nil? }
                                              UI.messagebox("Hata: Lütfen hem yüzeyleri hem de yapıştırılabilir bileşenleri seçin!")
                                              return
                                            model.start_operation("Bileşenleri Yüzeylere Yeniden Yapıştır", true)
                                          unless @loaded
                                            UI.add_context_menu_handler do |menu|
                                              selection = Sketchup.active_model.selection
                                              next if selection.empty?
                                              has_faces = selection.any? { |entity| entity.is_a?(Sketchup::Face) }
                                              has_glueable_components = selection.any? { |entity| entity.is_a?(Sketchup::ComponentInstance) && entity.glued_to.nil? }
                                              if has_faces && has_glueable_components
                                                position = SUPPORT_MENU_POSITION
                                                menu.add_item("Reglue", position) { glue_components_to_faces }
                                            @loaded = true
                                      • 2 / 2
