    [Plugin] ReGlue
    35 Posts 11 Posters 15.2k Views 11 Watching
      πŸ˜•
      If you have a face with some components glued onto it that are cutting holes, and you accidentally erase that face, then the face is easily replaced by over-drawing an edge etc... BUT the components will still remember that they were glued to the earlier face - and because that's now been erased they'll no longer cut openings at all.
      You need to place all new versions of the components, which can be a pain in the butt
      OR you can use a re-glue tool, which lets you select the face and one or more components that should be glued onto it. The selected components are then re-glued to that face, and once again they will cut openings as they used to...
      β˜€
      • EdsonE Offline
        Edson
        thanks for taking the time to answer me, tig. it is understood now. one more useful plugin from you.
        http://www.mahfuz.arq.br
        • archman212A Offline
          archman212
          thank you for sharing this plugin..very useful.
          archman212@gmail.com
            Here's a new future-proofed update.
            http://sketchucation.com/forums/viewtopic.php?p=349699#p349699
            • TommyKT Offline
              TommyK
              There are times when I would like to select several components and reglue them to a face with one "ReGlue" operation. I have modified TIG's code a little to allow multiple selections of components. Hope you don't mind, TIG. The code is below, and not tested that much....
              # Copyright 2006-2013, TIG
              # Permission to use, copy, modify, and distribute this software for
              # any purpose and without fee is hereby granted, provided the above
              # copyright notice appear in all copies.
              # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
              # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
              # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
              # Name; ReGlue
              # Description; A Tool to ReGlue a Component to a [recreated] Face.
              # Menu Item; Plugins -> ReGlue
              # Author; TIG
              # Usage; Select ONE Face and ONE [or MORE] UnGlued Component[s].
              # Use with care - because by picking a Component and an
              # unconnected Face you can 'UnGlue' it and 'ReGlue' it
              # onto this new Face even if it's not actually on the same
              # plane or at the same rotation !
              # Version;	1.0	27/12/06	First issue.
              # 1.1 20131210 Future-proofed
              require('sketchup.rb')
              module TIG
              module TIG;;ReGlue
              def self.do()
                model=Sketchup.active_model
                model.start_operation("ReGlue")
                ss=model.selection
               def self.status(txt)
                Sketchup;;set_status_text(txt, SB_PROMPT)
                Sketchup;;set_status_text(" ", SB_VCB_LABEL)
                Sketchup;;set_status_text(" ", SB_VCB_VALUE)
               end#def status
               def self.error(txt)
                self.status("REGLUE; ERROR...")
                UI.messagebox(txt)
                return nil
               end#def error
              	return self.error("ReGlue;\nNO Selection !") if ss.empty?
              	faces=ss.grep(Sketchup;;Face)
              	comps=ss.grep(Sketchup;;ComponentInstance)
              	return self.error("ReGlue;\nSelection MUST contain ONE Face !") if faces.length==0 || faces[1]
              	return self.error("ReGlue;\nSelection MUST contain ONE Component !") if comps.length==0
              	face=faces[0]
              	#Do for each component
              	i = 0
              	while defined? comps[i] do
              	  comp=comps[i]
              	  return nil unless comp && face
              	  comp.glued_to = face
              	  i = i + 1
              	end#while
                 model.commit_operation
              end#def
              unless file_loaded?(__FILE__)###
                UI.menu("Plugins").add_item("ReGlue"){self.do()}
              file_loaded(__FILE__)###
              end#module
              end#TIG
                kaas
                nice little gem TIG. Saves a lot of repetitive stupid work. πŸ‘
                Just as TommyK I changed it to a multiple reglue by
                comps.each{|c|c.glued_to = face}
                and uncommenting the
                #return self.error("ReGlue:\nSelection MUST contain ONE Component !") if comps.length==0 || comps[1] #comp=comps[0] #comp.glued_to = face
                • JQLJ Offline
                  JQL
                  I also feel the need to have multiple components reglued. I'm used to using Superglue for that but Tig's Reglue works much better.
                  So, Tig, are you thinking of adapting your own script to any of the above methods?
                  If not, I think I'll use Tommy's from now on...
                  Thank you guys!
                  www.casca.pt
                  Visit us on facebook!
                    rv1974
                    TIG, Is it possible to enable multiple components (implemented above by TommyK) re-glueing to multiple faces please?
                      An instance can only glue to one face.
                      It's a limitation within SketchUp, not the API.
                        rv1974
                        Does this API the Great and Powerful, allows to select all the components glued to a preselected face? If yes, maybe the script could take one face, select all the glued and reglue; then go to another face, repeat reglueing, and so on?
                        • PixeroP Offline
                          Pixero
                          Maybe Fredotools Move along could be helpful?
                            ToomyK's version a few posts back does that.
                            Just replace the text in the RB file with his alternative and save it.
                            Use a plain-text editor like Notepad++ to do the editing.
                              How is the code to determine which of the selected components gets glued to which selected face ?
                              Please outline the 'logic'...
                                rv1974
                                No, TommyK's code works only with one face.
                                @Pixero, the connection between MoveAlong and reglueing slips away from me.
                                  rv1974
                                  Thats what I tried to ask you earlier- Whether API allows to detect the components glued to a preselected face. IF the answer is YES, then MAYBE the script could(?) progressevly take face by face and reglue corresponding components.
                                  • hdpvH Offline
                                    hdpv
                                    @rv1974
                                    I did this but it’s small script. Select face and components for reglue.
                                    Suforyou
                                    http://www.sketchupforyou.com
                                      rv1974
                                      @hdpv said:
                                      @rv1974
                                      and components? or face only?
                                        There is a method:
                                        glued = face.get_glued_instances
                                        And it'd be easy to grep then iterate all of the faces and their glued components etc...
                                        BUT there's no API ' .could_be_glued_instances' method...
                                        BUT here's some possible [pretty much untested] code which might just do it...
                                        ctr=0
                                        faces=model.active_entities.grep(Sketchup;;Face)
                                        comps=model.active_entities.grep(Sketchup;;ComponentInstance).find_all{|e|
                                          e.definition.behavior.is2d? && ! e.glued_to
                                        ### collect if comp can glue, but not glued !
                                        cct=comps.length
                                        faces.each{|f|
                                          plane=f.plane
                                          norm =f.normal
                                          comps.dup.each{|e|
                                            pt=e.transformation.origin
                                            nm=e.transformation.zaxis
                                            if pt.distance_to_plane(plane)==0 && norm==nm
                                              ### glue-able
                                              cp=f.classify_point(pt)
                                              if cp==Sketchup;;Face;;PointInside || cp==Sketchup;;Face;;PointOnEdge || cp==Sketchup;;Face;;PointOnVertex
                                                ### on face so can glue
                                                e.glued_to=f
                                                comps.delete(e)
                                                ctr+=1
                                                ### reduce tested comps collection for speed
                                        puts "\n\nReglued #{ctr} of #{cct}" ### print how many reglued
                                          rv1974
                                          @TIG This plugin reglues multiple components in SU 2022. In v2023 and newer it reglues only one component.
                                          What is the reason for this degradation? Thanks
                                          TIGT 1 Reply Last reply Reply Quote 0
                                            TIG Moderator @rv1974
                                            @rv1974
                                            This plugin is over a decade old !
                                            As far as I recall, and tell from the code and version, it has always needed a selection of one face and one component to work. for 19 years.
                                            Although I do see from my posts do speaks of one or more components being processed...
                                            As far as I can see this old code is very simplistic... e.g.
                                            It does not check for gluing properties, or face-normal, or Z-axis, or position on the face.plane, or transformation.origin point on the face at all.
                                            If it checked for several components being on the face and sharing the face.normal as their Z-axis etc, then it would be possible the get it to process several gluing components. However, this would require a complete rewrite...
                                            I'll back check...
