    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 289.9k Views 17 Watching
    • Epix3DE Offline
      Epix3D
      I cannot find any problem with locking the arc by default as it is locked steps inside the component.
      i have made some door libraries previously working like this. If you want to delete the arcs(which should not be necessary as it is on own layer) you just unlock it.
      I think default is best way to avoid customers deleting arcs by mistake.
        seems all works fine! 😉
        • halroachH Offline
          halroach
          You can now produce 45(+) different Dynamic Doors, thanks to Mr. pcmoor and his extremely useful Multi Dynamic Door Panel.
          How? By combining it with FlexDoor 😄
          We've known about this multi door panel component for quite some time now, but it had a catch. The minute you made a copy of it, and altered one of the copies, both DCs would jumble up with sub-components flying all around your model. The only solution was to delve deep into each component and make all of it's sub-components unique - A very time intensive process. So... we decided to develop a tool just for this called 'Make Totally Unique'. After applying this tool to your new door variations, the door and all of it's sub-components will instantly become unique and they will all behave just right.
          See more details in this FlexBlog post.
          FlexTools - Super Quick Windows, Doors, Slats...
            porschegt2
            Hi all,
            Iam using the flextools pro but i cant Access to parameters from Windows and doors… anyone can help me out solve this issue?
            thanks a lot
            carlos
            • jujuJ Offline
              juju
              click into them a level or so to access more DC options
              • halroachH Offline
                halroach
                @porschegt2 said:
                Hi all,
                thanks a lot
                carlos
                Hi Carlos,
                I just replied to your email about this issue. If you still can't get to the parameters, please post a screenshot/video.
                *** Edit for reference:**
                The issue had to do with a crazy DC plugin bug - '/u' was appearing in the folder path where the SKP file was being saved to which would then cause the DC plugin to fail with errors.
                More about this issue at: https://forums.sketchup.com/t/error-on-component-options-window-when-downloading-in-window/19991/21
                • I Offline
                  Ivan K
                  Just came to say a very big thank you to you all for including the hidden door!
                  I was designing an interior renovation with "EZY Jamb" details and you showed up just in time!!!!
                  Thank you!
                  • jujuJ Offline
                    juju
                    Yoni, can you look into incorporating the PCMoor DC door as well?
                    • halroachH Offline
                      halroach
                      Hey Juju,
                      I'm unaware of this DC door. Can you send a link?
                      When you say to incorporate, do you mean to get it to work as a wall cutting component?
                      • halroachH Offline
                        halroach
                        We’ve had a chance to visit a manufacturer of beautiful high quality hidden doors called Minimal Doors.
                        Now we’re happy to share with you their elegant, hidden, very minimal (now flex) doors, and a new WallCutter feature ‘Hide Cut Edges’.
                        Learn more about how to hide frames in this FlexBlog post.
                        • jujuJ Offline
                          juju
                          @halroach said:
                          Hey Juju,
                          Man, you guys must be real busy... 👍 😉
                          See your BlogPost & mail comms of 01 February 2019.
                          • halroachH Offline
                            halroach
                            Hah 😄
                            Well... we are crazy busy, that's true!
                            I thought you were referring to a different (complete) door component that I haven't seen in the 3D warehouse, and not to the dynamic panel.
                            The blog post/video basically show how to insert the door panel into FlexDoor, and you can always save it aside with Component Finder for later use.
                            We could theoretically incorporate it into one of our components by default... but should we?
                            It's a cool panel, though the workflow with it - the need to use the 'make totally unique' tool, isn't a straight forward process. I think it would confuse and frustrate sketchuppers who first install flextools. They would copy the door around and then find that things are acting really weird with components flying around, and they wouldn't know why. It's also a bit heavy/slow in larger models. I think it would be problematic.
                            • halroachH Offline
                              halroach
                              New Flex Casement Double Window with 20 window style presets is released! 🎉 🎉 🎉
                              See more details in the FlexBlog:  https://flextools.cc/blog/flex-casement-double-window/
                              • halroachH Offline
                                halroach
                                A new video by Justin from The Sketchup Essentials shows how to build a house in no time using FlexTools and Tig Roof.
                                • pbacotP Offline
                                  Nice video. Congrats. Windows are almost always set according to the head height not the sill height.
                                  • halroachH Offline
                                    halroach
                                    https://flextools.cc/wp-content/uploads/2019/04/fixed-window_01_02.gif
                                    3 New Flex Windows released!
                                    Dynamic Hopper-Awning, Casement Single and a Fixed Window are now available.
                                    They can also be combined into new types of windows!
                                    Learn more in the FlexBlog.
                                    • halroachH Offline
                                      halroach
                                      https://flextools.cc/wp-content/uploads/2019/04/hopper_awning_01_03e.gif
                                      With this new Flex Window, you can create a simple Hopper.
                                      Change one setting and it's an Awning!
                                      Change another setting and it's flipped inside out!
                                      Double Click into it and you have the same  20 presets and full customization  like with the previously released Casement-Double.
                                      • halroachH Offline
                                        halroach
                                        https://flextools.cc/wp-content/uploads/2019/04/casement-single_01_01.gif
                                        Casement-Single Flex Window
                                        It’s just like the recently released Casement-Double, but single! 😄
                                        • pbacotP Offline
                                          Looks great. Are you sure about the handle placement for hoppers and awnings? Can the handle be omitted?
                                          • halroachH Offline
                                            halroach
                                            Hi pbacot,
                                            The handle in the hoppers and awnings (and in the casements too) are placed by default like in a tilt and turn window, but they aren't tilt AND turns, rather just tilt, OR Turn... So you have a good point! 😄
                                            I'll add an option to center the handle on the lower rail for it to suit tilt OR turn windows!
                                            The handle's placement, visibility and rotation can be easily changed. Double click into the component and select it:
                                            You can choose to hide it completely.
                                            You can have it visible on one side of the window or the other.
                                            (It may sound weird to have the handle on the outside, but it makes sense when you start flipping the window in and out and if you happen to like placing windows from the interior rather than from the exterior, or if you'd like to use the casement windows as doors...)
                                            You can also delete the handle all together if it bothers you - no harm will be done, everything else will continue working.
                                            You can also swap the handle with others or customize the handle manually to any handle you choose following the instructions here: https://flextools.cc/learn/flexdoor/hardware/
                                            It may look daunting, but once you get the hang of it, making your own dynamic handle is a matter of minutes.
                                            I hope that all makes sense.
                                            • 4 / 9
