    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 342.9k Views 17 Watching
    • halroachH
      halroach
      @porschegt2 said:
      Hi all,
      Iam using the flextools pro but i cant Access to parameters from Windows and doors… anyone can help me out solve this issue?
      thanks a lot
      carlos
      Hi Carlos,
      I just replied to your email about this issue. If you still can't get to the parameters, please post a screenshot/video.
      *** Edit for reference:**
      The issue had to do with a crazy DC plugin bug - '/u' was appearing in the folder path where the SKP file was being saved to which would then cause the DC plugin to fail with errors.
      More about this issue at: https://forums.sketchup.com/t/error-on-component-options-window-when-downloading-in-window/19991/21
      FlexTools - Super Quick Windows, Doors, Slats...
      • I
        Ivan K
        Just came to say a very big thank you to you all for including the hidden door!
        I was designing an interior renovation with "EZY Jamb" details and you showed up just in time!!!!
        Thank you!
        • jujuJ
          juju
          Yoni, can you look into incorporating the PCMoor DC door as well?
          • halroachH
            halroach
            Hey Juju,
            I'm unaware of this DC door. Can you send a link?
            When you say to incorporate, do you mean to get it to work as a wall cutting component?
            • halroachH
              halroach
              We’ve had a chance to visit a manufacturer of beautiful high quality hidden doors called Minimal Doors.
              Now we’re happy to share with you their elegant, hidden, very minimal (now flex) doors, and a new WallCutter feature ‘Hide Cut Edges’.
              Learn more about how to hide frames in this FlexBlog post.
              • jujuJ
                juju
                @halroach said:
                Hey Juju,
                Man, you guys must be real busy... 👍 😉
                See your BlogPost & mail comms of 01 February 2019.
                • halroachH
                  halroach
                  Hah 😄
                  Well... we are crazy busy, that's true!
                  I thought you were referring to a different (complete) door component that I haven't seen in the 3D warehouse, and not to the dynamic panel.
                  The blog post/video basically show how to insert the door panel into FlexDoor, and you can always save it aside with Component Finder for later use.
                  We could theoretically incorporate it into one of our components by default... but should we?
                  It's a cool panel, though the workflow with it - the need to use the 'make totally unique' tool, isn't a straight forward process. I think it would confuse and frustrate sketchuppers who first install flextools. They would copy the door around and then find that things are acting really weird with components flying around, and they wouldn't know why. It's also a bit heavy/slow in larger models. I think it would be problematic.
                  • halroachH
                    halroach
                    New Flex Casement Double Window with 20 window style presets is released! 🎉 🎉 🎉
                    See more details in the FlexBlog:  https://flextools.cc/blog/flex-casement-double-window/
                    • halroachH
                      halroach
                      A new video by Justin from The Sketchup Essentials shows how to build a house in no time using FlexTools and Tig Roof.
                      • pbacotP
                        Nice video. Congrats. Windows are almost always set according to the head height not the sill height.
                        • halroachH
                          halroach
                          https://flextools.cc/wp-content/uploads/2019/04/fixed-window_01_02.gif
                          3 New Flex Windows released!
                          Dynamic Hopper-Awning, Casement Single and a Fixed Window are now available.
                          They can also be combined into new types of windows!
                          Learn more in the FlexBlog.
                          • halroachH
                            halroach
                            https://flextools.cc/wp-content/uploads/2019/04/hopper_awning_01_03e.gif
                            With this new Flex Window, you can create a simple Hopper.
                            Change one setting and it's an Awning!
                            Change another setting and it's flipped inside out!
                            Double Click into it and you have the same  20 presets and full customization  like with the previously released Casement-Double.
                            • halroachH
                              halroach
                              https://flextools.cc/wp-content/uploads/2019/04/casement-single_01_01.gif
                              Casement-Single Flex Window
                              It’s just like the recently released Casement-Double, but single! 😄
                              • pbacotP
                                Looks great. Are you sure about the handle placement for hoppers and awnings? Can the handle be omitted?
                                • halroachH
                                  halroach
                                  Hi pbacot,
                                  The handle in the hoppers and awnings (and in the casements too) are placed by default like in a tilt and turn window, but they aren't tilt AND turns, rather just tilt, OR Turn... So you have a good point! 😄
                                  I'll add an option to center the handle on the lower rail for it to suit tilt OR turn windows!
                                  The handle's placement, visibility and rotation can be easily changed. Double click into the component and select it:
                                  You can choose to hide it completely.
                                  You can have it visible on one side of the window or the other.
                                  (It may sound weird to have the handle on the outside, but it makes sense when you start flipping the window in and out and if you happen to like placing windows from the interior rather than from the exterior, or if you'd like to use the casement windows as doors...)
                                  You can also delete the handle all together if it bothers you - no harm will be done, everything else will continue working.
                                  You can also swap the handle with others or customize the handle manually to any handle you choose following the instructions here: https://flextools.cc/learn/flexdoor/hardware/
                                  It may look daunting, but once you get the hang of it, making your own dynamic handle is a matter of minutes.
                                  I hope that all makes sense.
                                  • halroachH
                                    halroach
                                    https://flextools.cc/wp-content/uploads/2019/04/fixed-window_01_01e.gif
                                    A Fixed Flex Window
                                    It's similar to the original FlexWindow, but it is a lot simpler.
                                    Read more details in the FlexBlog: https://flextools.cc/blog/3-new-flex-windows/
                                    • halroachH
                                      halroach
                                      We started working on FlexStairs!
                                      Here is a work-in-progress video:
                                      • The stairs are recalculated while scaling according to the restrictions you enter (based on Blondel's Rule).
                                      • The top step can be hidden.
                                      • You can set a minimum riser height.
                                      • You can also set a fixed tread length.
                                      To be continued... 😄
                                      • jujuJ
                                        juju
                                        Personally I’d say that if the tool does the various possibilities structurally it should be fine as longs as components are used. The range of possibilities for balustrades and handrails together with inlays, finishes, nosings, etc. is so wide that I’d rather take the time to customize the components particular to the application than try to fiddle with numerous settings to see what it comes out like only to end up doing a partial custom job anyway. Remember to work in landings and being able to set governing parameters for that.
                                        • Epix3DE
                                          Epix3D
                                          Where can I find wooden double doors like in gif?
                                          https://sjc1.discourse-cdn.com/sketchup/uploads/default/original/3X/8/1/810cb8d05dc3dff79482b6b160b78fed6d186963.gif
                                          Also in my(Activated)ComponentFinder text is red when searching and doesn´t work.?
                                          • halroachH
                                            halroach
                                            Hi Epix,
                                            The components in that animation were all components I created with the Flex components as a base.
                                            1. Pull in a FlexDoor component.
                                            2. Change the door to a double door in the component options window - double click into the component and then select it to reach the correct options window and change number of doors to 2.
                                            3. Change the handles with handles from the 3DWarehouse and then recalibrate their location with the interact tool.
                                            4. Add which ever wood material to the sub-components you want.
                                            1. You can then save the component with component finder for later use:
                                            The red text appears if nothing comes up when searching. Since it appears you have no folders open it won't find anything for sure. Add a few folders and then search through them and it should work as expected.
                                            Please let me know how it works out.
                                            • 4 / 9
