    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 346.6k Views 17 Watching
    • halroachH
      halroach
      A new update is out!
      You can now browse and search through your In-Model Components and Groups with ComponentFinder!
      Read more details on the FlexBlog.
      https://flextools.cc/wp-content/uploads/2019/01/CF_In-model_01_05-800.gif
      FlexTools - Super Quick Windows, Doors, Slats...
      • Epix3DE
        Epix3D
        When I mirror Flex doors and windows with copy the cutholes on original disappears..?
        Same happens if I modify a wall with flexcomponents.
        Is there a way of updating so the cutholes comes back?
        • halroachH
          halroach
          Can you upload a jpg or an skp example or send either to yoni@flextools.cc so I can better understand where the issue is.
          • Epix3DE
            Epix3D
            Flexwindows are mirrored from one side to the other cutting new holes but removing the original holes from the side copied from..
            [img]FlexToolsMissingHoles.jpg[/img]
            • Epix3DE
              Epix3D
              ..Strange thing happened, -when I closed and reopened the file the holes were back..?
              • jujuJ
                juju
                [img][attachment=0:2ociutft]<!--%20ia0%20-->FlexToolsMissingHoles.jpg<!--%20ia0%20-->[/attachment:2ociutft][/img]
                I've had success in the past when selecting the various DC's and hitting the Refresh on the FlexTools toolbar.
                • Epix3DE
                  Epix3D
                  Thank you Juju,. I will try that next time.
                  I have suggestion.
                  I often use CleanUp3 plugin to clean my files for unecessary geometry.
                  The door arc in FleTools Doors should be locked to avoid disappearing when cleaning for stray lines.
                  [img]LockArc.jpg[/img]
                  • halroachH
                    halroach
                    [img][attachment=0:3bf4o6r3]<!--%20ia0%20-->FlexToolsMissingHoles.jpg<!--%20ia0%20-->[/attachment:3bf4o6r3][/img]
                    Hi Epix3d,
                    Like Juju mentioned, this a good example where the refresh button/s come in handy 😎
                    A quick explanation:
                    When you first place a wall cutting window, it is automatically glued to a surface and it generates an opening. When you mirror and copy it, one or both of the components (The original or the mirrored) can become unglued, and the WallCutter algorithm doesn't know that the mirroring/copying happened, so it doesn't try to cut through anything. Moving the problematic window a little left and right OR doing a refresh, OR re-opening the model will jolt the window back to behaving as expected. Note though, that one of the windows will still be unglued.
                    I think it also depends which mirroring plugin you are using. I just tried to re-create this, and the original component's opening closed up, where as the copied component worked correctly and generated an opening... This seems to be the opposite of what is happening in the image you posted.
                    There are a few more 'advanced' situations where the refresh function is very useful. There are some good examples with animations at the learn pages:
                    https://flextools.cc/learn/wall-cutter/#Advanced-Operations
                    I just added a few mentions about the Mirroring situation.
                    Thanks for finding this!
                    • halroachH
                      halroach
                      I have suggestion.
                      [img][attachment=0:2iqdcvlq]<!--%20ia0%20-->LockArc.jpg<!--%20ia0%20-->[/attachment:2iqdcvlq][/img]
                      I don't quite remember why now, but something tells me not to lock components by default. Maybe it's the red color every time you select the component... 😄
                      Other than locking, another thing you could try in order to avoid the lines getting erased is to open the arc component and draw the radius lines so a surface is generated. Then hide the lines and the surface.
                      See if that works.
                      After which ever change suits you, you can then save the component aside with ComponentFinder for future use.
                      • Epix3DE
                        Epix3D
                        I cannot find any problem with locking the arc by default as it is locked steps inside the component.
                        i have made some door libraries previously working like this. If you want to delete the arcs(which should not be necessary as it is on own layer) you just unlock it.
                        I think default is best way to avoid customers deleting arcs by mistake.
                          seems all works fine! 😉
                          • halroachH
                            halroach
                            You can now produce 45(+) different Dynamic Doors, thanks to Mr. pcmoor and his extremely useful Multi Dynamic Door Panel.
                            How? By combining it with FlexDoor 😄
                            We've known about this multi door panel component for quite some time now, but it had a catch. The minute you made a copy of it, and altered one of the copies, both DCs would jumble up with sub-components flying all around your model. The only solution was to delve deep into each component and make all of it's sub-components unique - A very time intensive process. So... we decided to develop a tool just for this called 'Make Totally Unique'. After applying this tool to your new door variations, the door and all of it's sub-components will instantly become unique and they will all behave just right.
                            See more details in this FlexBlog post.
                            • P
                              porschegt2
                              Hi all,
                              Iam using the flextools pro but i cant Access to parameters from Windows and doors… anyone can help me out solve this issue?
                              thanks a lot
                              carlos
                              • jujuJ
                                juju
                                click into them a level or so to access more DC options
                                • halroachH
                                  halroach
                                  @porschegt2 said:
                                  Hi all,
                                  thanks a lot
                                  carlos
                                  Hi Carlos,
                                  I just replied to your email about this issue. If you still can't get to the parameters, please post a screenshot/video.
                                  *** Edit for reference:**
                                  The issue had to do with a crazy DC plugin bug - '/u' was appearing in the folder path where the SKP file was being saved to which would then cause the DC plugin to fail with errors.
                                  More about this issue at: https://forums.sketchup.com/t/error-on-component-options-window-when-downloading-in-window/19991/21
                                  • I
                                    Ivan K
                                    Just came to say a very big thank you to you all for including the hidden door!
                                    I was designing an interior renovation with "EZY Jamb" details and you showed up just in time!!!!
                                    Thank you!
                                    • jujuJ
                                      juju
                                      Yoni, can you look into incorporating the PCMoor DC door as well?
                                      • halroachH
                                        halroach
                                        Hey Juju,
                                        I'm unaware of this DC door. Can you send a link?
                                        When you say to incorporate, do you mean to get it to work as a wall cutting component?
                                        • halroachH
                                          halroach
                                          We’ve had a chance to visit a manufacturer of beautiful high quality hidden doors called Minimal Doors.
                                          Now we’re happy to share with you their elegant, hidden, very minimal (now flex) doors, and a new WallCutter feature ‘Hide Cut Edges’.
                                          Learn more about how to hide frames in this FlexBlog post.
                                          • jujuJ
                                            juju
                                            @halroach said:
                                            Hey Juju,
                                            Man, you guys must be real busy... 👍 😉
                                            See your BlogPost & mail comms of 01 February 2019.
                                            • 4 / 9
