    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 289.8k Views 17 Watching
    • halroachH Offline
      halroach
      Thank you Juju,. I will try that next time.
      I have suggestion.
      I often use CleanUp3 plugin to clean my files for unecessary geometry.
      The door arc in FleTools Doors should be locked to avoid disappearing when cleaning for stray lines.
      [img][attachment=0:2iqdcvlq]<!--%20ia0%20-->LockArc.jpg<!--%20ia0%20-->[/attachment:2iqdcvlq][/img]
      I don't quite remember why now, but something tells me not to lock components by default. Maybe it's the red color every time you select the component... 😄
      Other than locking, another thing you could try in order to avoid the lines getting erased is to open the arc component and draw the radius lines so a surface is generated. Then hide the lines and the surface.
      See if that works.
      After which ever change suits you, you can then save the component aside with ComponentFinder for future use.
      FlexTools - Super Quick Windows, Doors, Slats...
      • Epix3DE Offline
        Epix3D
        I cannot find any problem with locking the arc by default as it is locked steps inside the component.
        i have made some door libraries previously working like this. If you want to delete the arcs(which should not be necessary as it is on own layer) you just unlock it.
        I think default is best way to avoid customers deleting arcs by mistake.
          seems all works fine! 😉
          • halroachH Offline
            halroach
            You can now produce 45(+) different Dynamic Doors, thanks to Mr. pcmoor and his extremely useful Multi Dynamic Door Panel.
            How? By combining it with FlexDoor 😄
            We've known about this multi door panel component for quite some time now, but it had a catch. The minute you made a copy of it, and altered one of the copies, both DCs would jumble up with sub-components flying all around your model. The only solution was to delve deep into each component and make all of it's sub-components unique - A very time intensive process. So... we decided to develop a tool just for this called 'Make Totally Unique'. After applying this tool to your new door variations, the door and all of it's sub-components will instantly become unique and they will all behave just right.
            See more details in this FlexBlog post.
              porschegt2
              Hi all,
              Iam using the flextools pro but i cant Access to parameters from Windows and doors… anyone can help me out solve this issue?
              thanks a lot
              carlos
              • jujuJ Offline
                juju
                click into them a level or so to access more DC options
                • halroachH Offline
                  halroach
                  @porschegt2 said:
                  Hi all,
                  thanks a lot
                  carlos
                  Hi Carlos,
                  I just replied to your email about this issue. If you still can't get to the parameters, please post a screenshot/video.
                  *** Edit for reference:**
                  The issue had to do with a crazy DC plugin bug - '/u' was appearing in the folder path where the SKP file was being saved to which would then cause the DC plugin to fail with errors.
                  More about this issue at: https://forums.sketchup.com/t/error-on-component-options-window-when-downloading-in-window/19991/21
                  • I Offline
                    Ivan K
                    Just came to say a very big thank you to you all for including the hidden door!
                    I was designing an interior renovation with "EZY Jamb" details and you showed up just in time!!!!
                    Thank you!
                    • jujuJ Offline
                      juju
                      Yoni, can you look into incorporating the PCMoor DC door as well?
                      • halroachH Offline
                        halroach
                        Hey Juju,
                        I'm unaware of this DC door. Can you send a link?
                        When you say to incorporate, do you mean to get it to work as a wall cutting component?
                        • halroachH Offline
                          halroach
                          We’ve had a chance to visit a manufacturer of beautiful high quality hidden doors called Minimal Doors.
                          Now we’re happy to share with you their elegant, hidden, very minimal (now flex) doors, and a new WallCutter feature ‘Hide Cut Edges’.
                          Learn more about how to hide frames in this FlexBlog post.
                          • jujuJ Offline
                            juju
                            @halroach said:
                            Hey Juju,
                            Man, you guys must be real busy... 👍 😉
                            See your BlogPost & mail comms of 01 February 2019.
                            • halroachH Offline
                              halroach
                              Hah 😄
                              Well... we are crazy busy, that's true!
                              I thought you were referring to a different (complete) door component that I haven't seen in the 3D warehouse, and not to the dynamic panel.
                              The blog post/video basically show how to insert the door panel into FlexDoor, and you can always save it aside with Component Finder for later use.
                              We could theoretically incorporate it into one of our components by default... but should we?
                              It's a cool panel, though the workflow with it - the need to use the 'make totally unique' tool, isn't a straight forward process. I think it would confuse and frustrate sketchuppers who first install flextools. They would copy the door around and then find that things are acting really weird with components flying around, and they wouldn't know why. It's also a bit heavy/slow in larger models. I think it would be problematic.
                              • halroachH Offline
                                halroach
                                New Flex Casement Double Window with 20 window style presets is released! 🎉 🎉 🎉
                                See more details in the FlexBlog:  https://flextools.cc/blog/flex-casement-double-window/
                                • halroachH Offline
                                  halroach
                                  A new video by Justin from The Sketchup Essentials shows how to build a house in no time using FlexTools and Tig Roof.
                                  • pbacotP Offline
                                    Nice video. Congrats. Windows are almost always set according to the head height not the sill height.
                                    • halroachH Offline
                                      halroach
                                      https://flextools.cc/wp-content/uploads/2019/04/fixed-window_01_02.gif
                                      3 New Flex Windows released!
                                      Dynamic Hopper-Awning, Casement Single and a Fixed Window are now available.
                                      They can also be combined into new types of windows!
                                      Learn more in the FlexBlog.
                                      • halroachH Offline
                                        halroach
                                        https://flextools.cc/wp-content/uploads/2019/04/hopper_awning_01_03e.gif
                                        With this new Flex Window, you can create a simple Hopper.
                                        Change one setting and it's an Awning!
                                        Change another setting and it's flipped inside out!
                                        Double Click into it and you have the same  20 presets and full customization  like with the previously released Casement-Double.
                                        • halroachH Offline
                                          halroach
                                          https://flextools.cc/wp-content/uploads/2019/04/casement-single_01_01.gif
                                          Casement-Single Flex Window
                                          It’s just like the recently released Casement-Double, but single! 😄
                                          • pbacotP Offline
                                            Looks great. Are you sure about the handle placement for hoppers and awnings? Can the handle be omitted?
                                            • 4 / 9
