    Power Toolbar (2.5) - fix for 2019
    78 Posts 39 Posters 130.3k Views 39 Watching
    • CadFatherC Offline
      CadFather
      Ciao Rich, hope you're good! : )
        Pherim
        @cadfather said:
        aware of the glitch with extrude and 2017. busy at present, but as soon as i get some time to dive into the code again, i'll post a working update
        Great! Looking forward to it!
          CadFather
          posted a new update - should be working with 2017 (thanks to TIG).
          also just to let you know, i hope to be working on a fuller update sometime in the new year.
          Cheers
            Pherim
            Great, thank you!
              shri
              this plugin makes my work faster..thanks alot
              • onzkiO Offline
                onzki
                LOL, I was too lazy to read! I miss that one. I'll charge this to my Duh moments.
                [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                • N Offline
                  nickweboffer
                  hi
                  I have installed and uninstalled several times but the whole powerbar just doesn't show up in my SU 2015. what are my options?
                  • jujuJ Offline
                    juju
                    @nickweboffer said:
                    hi
                    did you remember to go to View > Toolbars and check that the toolbar is selected?
                      Pherim
                      Hello,
                      I have a small issue with one of the functions and I wonder if anything can be done about it. It's about the "Equalise Curves" tool, which is very handy in certain situations, but whenever I use it, one end of the curve moves a little. I am only using "Divide by number", not by length, but it happens in both modes. Is it possible to change it so that both ends stay in their original position? Or is there another plugin which can do that? Unlike other tools in this collection, I can't find a corresponding separate plugin for this function. And for example Fredo6's Curvizard can only simplify contours by angle, but not equalise the segments.
                        CadFather
                        Hi Pherim, i'll have a look at it, though that might be a while as i'm away
                          Pherim
                          Thank you! Also, sometimes it does not redraw the curve, but it just disappears.
                          Then I get this error in the Ruby Console:
                          Error; #<ArgumentError; Not enough points - at least 2 required>
                          C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb;3841;in `add_curve'
                          C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb;3841;in `main'
                          C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb;578;in `block in <module;Max_Coppoletta>'
                          SketchUp;1;in `call'
                          • V Offline
                            vzynsky
                            JHS powerbar 2.4 + su17! What was the problem? 😕
                            https://scontent.fdad1-1.fna.fbcdn.net/v/t1.0-9/21728301_1450124848414787_6713604283302657052_n.jpg?oh=39fd716e7f701ed415829835d3fb3cf2&oe=5A49F8D4
                              GoodWin_2203
                              thanks for the wonderful plugin! very useful. I have a problem with the "extrude lines" tool. it does not work correctly. when I specify the height to which you want to squeeze a curved line, it does not squeeze it out, but simply moves it with copying. Do you know why this is so?
                              • majidM Offline
                                majid
                                Silly question: Does it work with the latest SU?
                                • Y Offline
                                  young77
                                  Hi…
                                  I have a question about extrude line in JHS Power Bar plugin. I have tried to create a line and select the line, then click on extrude line in that plugin, but it didn’t extruded as seen in youtube tutorial, it was only an offset from first to second point with the same line, there is no any extrusion at all. Please advise me how to correct my steps thanks.
                                  please refers to my link : https://ufile.io/fk7et
                                  • V Offline
                                    valerostudio
                                    Will we get support for 2019? It doesnt seem to be installing correctly.
                                      stefanozilio
                                      Only for Info, I used your bar a lot
                                      Do you have the intension to update it for SU2019?
                                      SZ
                                        CadFather
                                        Yes, hope to work on an update sometime soon, time is a bit short but I will.
                                        also if problems, please try to be as specific as possible.
                                          CadFather
                                          ok, try this - a quick fix so it loads. first test seems fine. so let me know if you encounter issues..
                                          later i'll have a proper look at the script and update it properly - thanks
                                          Powerbar Fix for 2019.rbz
                                          • atelierpaarA Offline
                                            atelierpaar
                                            Hello,
                                            I hope this chat also relates to jhs powerbar.
                                            After intalling SU 2019 I get the following errorcode :
                                            Fehler beim Laden der Datei C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb
                                            Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb:7367: Invalid return in class/module body
                                            return nil
                                            C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:in load' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:in module:JHS_powerbar'
                                            C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:7:in <module:Max_Coppoletta>' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:6:in <top (required)>'
                                            C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load'
                                            C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:in register_extension' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:in module:JHS_powerbar'
                                            C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:8:in <module:Max_Coppoletta>' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:7:in <top (required)>'
                                            unfortuantely I have no clou how to fix this.
                                            Any suggestions ?
                                            thanks
                                            Uli
                                            • 3 / 4
