    [Plugin] AMS Library 3.7.1b (29 May 2021)
    108 Posts 39 Posters 686.2k Views 39 Watching
    • P
      perroloco2000
      SketchUp Make 2016 16.1.1449 64-bits (spanish). Windows 10 Home 1511 (10586.164)
      I have a fresh install of windows 10 (last version) and SketchUp (last version). I still haven´t other plugins, and didn´t modify default shortcuts.
      I installed AMS Library 3.2.1. (all works)
      I installed AMS Window Settings 4.2.0. all functions works but when I hide menu bar the crash come. Thanks
        Anton_S
        Ok I am able to reproduce it with Spanish localization. I even get frozen strings errors, which I have no idea what's causing them and how to prevent them. I will look into into it and do my best to fix it.
          Anton_S
          Hi perecollo2000. Try the new version. I think it should be fixed now.
          • P
            perroloco2000
            hi Anton .... YOU SOLVED IT!!!
            100% working, thank you very much for your work, and quick reply
            your plugins really help my work on the laptop screen
            great autor, thanks
            • P
              pnickles
              Forgive me but I'm a newb who can barely work his way through/around Extensions.
              I'm unable to get the MSphysics to load/run. It is registered under Plugins but I receive the following message when I open Sketchup2016. I've tried copying/pasting the "main.rb" file into every imaginable Plugin folder but it still fails to see/find the file.?
              (I installed the AMS Library v3.2.2 AFTER I installed the MSphysics extension but the order of installation shouldn't matter, correct?)
              I'm running Win8 via Parallels, SU2016.
              Error message
              Folder showing MAIN.RB file in MSPhysics folder
                Anton_S
                Pnickles, you got it into the correct plugins folder, but placed the content improperly.
                I suggest deleteding whatever you placed in the plugins folder manually (including MSPhysics which is placed improperly based on your screenshot) and starting over with the following instructions. Download ams_Lib_3.2.2.zip, extract it, and place ams_Lib folder and ams_Lib.rb file into the plugins folder. Same applies to MSPhysics_0.5.0.zip. It should look something like this:
                • P
                  pnickles
                  Different error messages now. See attached. Perhaps it's because I'm running Win8 via Parallels?
                  • Bryan KB
                    Are there how to use instructions somewhere?
                      Anton_S
                      Bryan, in case you're wondering if it's a plugin, well it's not. AMS library is more of a dependency for a few of my other plugins.
                      • W
                        wikii
                        How to get the version number?
                        AMS.ver ?
                          Anton_S
                          Use AMS::Lib::VERSION It returns a string like "3.3.0".
                          • Bryan KB
                            Thanks Anton, but what I'm looking for is how to use it. It's installed without a problem but I need some kind of instructions or tutorial on how to use the controls.
                            Thanks.
                              Anton_S
                              The first post contains a link to the library's documentation. I not particularly sure if that's what you desire though.
                              • Bryan KB
                                Anton, thanks. I found some great video tutorials. https://www.youtube.com/user/samketner/videos?sort=dd%26amp;view=0%26amp;shelf_id=0
                                My new problem is that the UI menu is not displaying correctly nor or the contents.. There are no tabs and the menu window is not resizable so I cannot access the contents at the bottom of the screen.
                                Here is a screen shot.
                                Any ideas?
                                • L
                                  ladyquestio
                                  I keep getting this error. What is happening?
                                  http://tanyaloser.tripod.com/loaderror10.JPG
                                    Anton_S
                                    Hmm. I'm not getting any errors in my SU8. Are you using the latest versions of both plugins? If not, try completely removing both and installing once again.
                                    Edit: Actually I'm getting a similar error when I attempt to start MSPhysics simulation in SU8. I haven't been able to determine the cause, so try sticking to SU2013+.
                                    Edit: I will ensure the compatibility with SU version prior to 2013 at some point.
                                    • L
                                      ladyquestio
                                      Anton:
                                      I removed all the files as per instruction. Defragged the HD. then reloaded SU8 . I have a video of what happens.
                                      Watch and see. then Tell me what I did wrong.
                                      https://youtu.be/nUL87J2N79A
                                        Anton_S
                                        Sorry, I forgot to test it on Windows XP. It should be fixed now. Upgrade to AMS Library, version 3.5.2.
                                        • G
                                          GalvinHRO
                                          with the AMS library i can get the name of the default tray but not the object itself or the child dialogs like "Materials" or "Entity Info" anybody knows if this feature exist or a workaround. If not is it possible to make one with the win32API?
                                            Anton_S
                                            Galvin,
                                            The Tray window structure in SU2018 is as follows:
                                            Provided that you have the handle of the tray, you can then obtain the first two levels of child windows, and then iterate through all windows of that child window to get all the dialogs.
                                            With AMS Library, you can use the following function to get all trays:
                                            trays = AMS;;Sketchup.get_active_dialogs.find_all { |handle|
                                              AMS;;Window.get_class_name(handle) =~ /Afx;MiniFrame/i
                                            # => [133134]
                                            Then once you have the trays, you can get the first two levels of child windows:
                                            trays.each { |tray|
                                              c1 = AMS;;Window.get_related(tray, 5) # GW_CHILD
                                              next unless c1
                                              c2 = AMS;;Window.get_related(c1, 5) # GW_CHILD
                                              next unless c2
                                              dialogs = AMS;;Window.get_child_windows(c2, false, false)
                                              panes = dialogs.find_all { |dialog|
                                                AMS;;Window.get_class_name(dialog) =~ /CPanelHeader/i
                                              panes.each { |pane|
                                                # First child window contains pane caption
                                                c3 = AMS;;Window.get_related(pane, 5) # GW_CHILD
                                                next unless c3
                                                puts AMS;;Window.get_caption(c3)
                                            # => Layers
                                            # => Shadows
                                            # => Fog
                                            # => Materials
                                            # => Soften Edges
                                            # => Styles
                                            # => Entity Info
                                            Note that this will not work with sketchup versions prior to 14.
                                            Anton
                                            • 4 / 6
