    SketchUp 2019 release
    430 Posts 94 Posters 381.3k Views 94 Watching
      @andybot said:
      Amazing. Worst fears confirmed. ๐Ÿ˜ž
      What's that?
      They've fixed a mess of bugs and some issues that people have been complaining about, they added some new features that people wanted like dashed lines in SketchUp, they've made SketchUp Pro less expensive to get started in with their subscription option which also gives the user access to SketchUp Shop, an unlimited Trimble Connect storage account and other features. And for those who aren't interested in having access to SketchUp Shop and the other add-ons, they can continue with their Classic license as they've always done.
      • kenK
        ken
        I have 2018, with the maintenance license still in effect. I have downloaded 2019. It requests a license and an authorization code. Before I would copy the license from the previous version. This time 2019 says it is not a valid license.
        So do I to buy another 2019 license or am I doing something wrong. I just want the classic, not interested in the $600 program.
        So help if you can.
        Thank you in advance
        Ken
        So DaveR do you remember when the bowlers came into style?
        • pbacotP
          Ken,
          Maybe this?
          Tip: If youโ€™re active in the upgrade, maintenance, and support plan, you receive an email with new license information after a new version of SketchUp Pro is released. Download and install the new version of SketchUp Pro, authorize the license, and begin using the new version of SketchUp. After you authorize the new version, your old SketchUp license expires after 60 days.
          (help.sketchup.com)
          • PixeroP
            Pixero
            I think itโ€™s what I expected.
            Nothing about speed and stability for high poly models and faster import.
            Nothing very impressive but at least two things are good.
            DWG Import
            In SketchUp you now have the ability to Import and Export Materials improving interoperability for CAD and BIM workflows
            This one if it works as I hope will be of big use to me since much is modeled in Revit at work.
            Getting materials in to Sketchup will save me time.
            Fixed an issue where SketchUp would take focus during start up preventing work in other apps.
            A good and wanted fix.
            Now I can do something productive instead of looking at Sketchup loading.
            • utilerU
              utiler
              SketchUp 2019 Release:
              https://blog.sketchup.com/article/a-whole-new-way-to-sketchup
              Just Curious...
              • pbacotP
                The above referenced blog says they've made SketchUp "faster".
                • ntxdaveN
                  ntxdave
                  @pbacot said:
                  Ken,
                  Maybe this?
                  (help.sketchup.com)
                  I have the active upgrade, maintenance and support plan. I have had it for several years When I install the new version each year, the old version is still there and still works. It does not expire after the 60 days (or at least it never has for me).
                  Looks like I can continue on the same path with the Classic plan.
                  Press F1...thank me later
                  • F
                    function
                    dashed lines and some other stuff ๐ŸŽ‰ ๐ŸŽ‰ ๐ŸŽ‰
                    • ntxdaveN
                      ntxdave
                      Do not have it yet, but it appears that the dashed lines works in a way that all the sages tell us not to do. You can only use dashed lines in conjunction with a layer (according to my understanding). Which means that the layer where you are going to use dashed lines must be the "active" layer. All of the advice I have seen from the sages say that you should ALWAYS draw on layer0 and then assign the object/group/component to a layer after completing the action. Again, according to what I am seeing on the SketchUp forum, you would have to draw you objects/groups/components on a layer other than layer0 in order to use dashed lines.
                      Hope someone can show me that I am wrong!!
                      • ntxdaveN
                        ntxdave
                        Kind of my first impression also until I others corrected my understanding of some things. The Classic version and it's licensing continues the environment we have been used to. ๐Ÿ‘
                          alpro
                          Can I change my vote in the poll?? I've been using Sketchup since version 6 and had really high hopes for 2019 especially with the release delay. Doesn't seem like anything to get excited over though I will hold off on judging it till I have used it for a few weeks. But the biggest disappointment is going subscription. And before people start replying with "the classic version license" just read Mark's statements again, "for the time being", so it won't be long before Sketchup is following the Autodesk empire's footprints. I would of rather had them double or triple the yearly maintenance fee. So where to go from here? Guess now would be a good time for some developers to come up with a Blender addon that at least kinda mimicked SU especially with the 2.8 release. I would buy it.
                            There's never been a case where you would enter your license for the previous version in the licensing fields for a new one. Nothing has changed regarding that. They have already said they will be sending e-mails in the next day or so out to those who have current maintenance agreements providing new serial numbers and keys. If you can't wait that long, you can go to the website and get the license info directly
                            No. You don't need to buy another license. You can continue with what they now call the Classic license. You'll get SketchUp 2019 with a perpetual license.
                            So help if you can.
                            I tried. I hope that helps to clarify.
                            I ain't quite that old. ๐Ÿ˜„ I do remember the time ThomThom was trying to get them to have a comeback, though.
                            • jujuJ
                              juju
                              yeah, I saw that too, I would love to know what/how things were made faster and if it has been quantified / qualified
                                rogalxxx
                                They made shadows faster. It seems like it does not recalculate shadows when rotating view. No ora a short delay waiting for them to reappear.
                                I have my license valid till the end of 2020 but I did not recieve updated license. Keep waiting or should I do something?
                                • jujuJ
                                  juju
                                  go to licence manager section on their website, enter licence details with your e-mail, a new serial will be sent
                                  • sketch3d.deS
                                    sketch3d.de
                                    @juju said:
                                    go to licence manager section on their website...
                                    besides having bought by a reseller who will then deliver the license data of rev. 2019 to the registered email address in a few hours/days.
                                    • K
                                      Khai
                                      Hmm new license areas aside, not to impressed with only minor adjustments to the program and minor feature adds.
                                      Have to see how it goes...
                                        dedmin
                                        We know the future, even we try to fool ourself ๐Ÿ˜• SketchUP WEB -> Subscription Only -> Sketchup WEB Pro. Imagine the future where everything is on subscription only! The big corporations own everything and we are just subscribers! And all this push to the cloud is in line with this strategy - take full control over the tools and the data!
                                          rv1974
                                          Is there some way to disable this damn welcome window?
                                          • BoxB
                                            Window/Preferences/General untick Show welcome window.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 21
                                            • 22
                                            • 12 / 22
