    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    617 Posts 155 Posters 590.8k Views 154 Watching
    • fredo6F Offline
      @pilou said:
      It's buging in 2017! Drawing is good but at the end...so no drawing result! ๐Ÿ˜ฎ
      This bug is now fixed in v4.4b.
      In your model, one of the faces is perpendicular to the direction of pushpull and thus would disappear. That's the issue.
      Thanks for signaling.
        Bravo! ๐Ÿ‘
          SunnyGee2017
          First of all, thanks for the amazing plugins that you provide to the community!
          For some reason, I am experiencing errors with the Round Push-Pull tool. This happens in SU 2017 and SU 2018 alike. Every time I am trying to apply the function, the following error message appears. I have the latest versions of the LibFredo6 (8.7) and Fredo6 JointPushPull (4.4b) installed on a Windows10 machine with the latest drivers for my NVIDIA 960 GPU's. Any idea?
          Date: 13-Jan-19 09:26:04
          An error occurred in Round Push Pull
          Error in Analysis of model
          Cannot create unit vector from zero length vector
          body_lib6g6.rbe: 1863 -- intersect_plane_plane
          body_lib6g6.rbe: 1863 -- vector_exact_average
          jointpushpullalgo.rbe: 1445 -- block (2 levels) in round_compute_direction
          jointpushpullalgo.rbe: 1433 -- each
          jointpushpullalgo.rbe: 1433 -- block in round_compute_direction
          jointpushpullalgo.rbe: 1415 -- each
          jointpushpullalgo.rbe: 1415 -- round_compute_direction
          jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
          jointpushpullalgo.rbe: 1353 -- each
          jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
          jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
          jointpushpullalgo.rbe: 1111 -- each
          jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
          jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
          jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
          jointpushpulltool.rbe: 826 -- dragging_start
          jointpushpulltool.rbe: 1516 -- onLButtonDown
            Share the SKP file where you get this message.
              SunnyGee2017
              Any model. A simple cube is already enough.
                There's got to be something more to it than that. Round Push/Pull works fine on a cube here. What's different about your model?
                • fredo6F Offline
                  It works fine on a simple cube.
                  So there must be something special in your model, most likely polluting edges.
                  Anyway, I fixed the problem and it will go in a next version of LibFredo6.
                  But it's better to know why you have the problem.
                    theVonZipper
                    I'm sure Joint Push Pull v4.4b has generated multiple groups at once for me. I just can't recall what choice of options do this. Anyone know? Think I chose the face by face option ... but can't seem to replicate the multiple group results.
                    OK. Just realized that multiple groups are generated when the faces I'm push/pulling are not connected.
                    • designerbursaD Offline
                      designerbursa
                      It would be great if you add the thickness to the surface and add the option to delete the surface after grouping
                      • fredo6F Offline
                        The native PushPull does not have this option.
                        Although this could be possible, I think there are enough options in JPP. It is easy to remove the face after push-pull.
                          rv1974
                          1.copy surface to buffer
                          2.execute JPP
                          3. paste in place
                          4. delete
                          • fredo6F Offline
                            I don't understand. The grouping in Group PushPull 2D Faces is individual by face, which is not supported by JPP.
                            So this is two different features.
                              designerbursa
                              It would have been nice if there was an option of giving the thickness similar to the Autocad Exturude command! .. Yes, it is a waste of time but we can easily remove the remaining surfaces. ๐Ÿ˜„ Achievements in your studies Fredo6
                              "Group PushPull 2DFaces" will not need this plugin! .. thanks Fredo6
                                designerbursa
                                I am sorry for my English ๐Ÿ˜„
                                  reza1813
                                  Dear Fredo,
                                  Hello, I kindly reach you to mention a problem in the Joint Push Pull plugin.
                                  When I model organic shape or complex surface(Almost curve form or tensile structure) Pushing of the surface is not moving well and also I have tried to copy of surface and then use Curviloft to close it but it also doesn't work properly. What should I do exactly in this Situation? Thanks in advance.
                                  Joint Push Pull
                                  Sincerely
                                  Hamidreza
                                  • fredo6F Offline
                                    Could you post the model with the Tensile surface, so that I can try to investigate the problem with JPP.
                                    Also, can you use the Extrude tool in JPP (X marked) instead.
                                      reza1813
                                      Dear Fredo,
                                      Thanks a lot. It works when I use the Extrude tool in JPP (X marked). Thanks in advance.
                                      • CadFatherC Offline
                                        CadFather
                                        Hi Fredo, i noticed that JPP will treat group copies as instances - i think it would be great to bypass this and have it treat groups as separate. perhaps something for the next update cycle...
                                        • fredo6F Offline
                                          Definitely. This happens for freshly copied groups, that behave as components until you edit them. I need to correct this as I did in FredoCorner. Just some work!
                                            CadFather
                                            fantastic! : )
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 30
                                            • 31
                                            • 20 / 31
