    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.1m Views 79 Watching
    • tuna1957T
      tuna1957
      Still shaking off the rust... Model the small section in the center. Copy it around your circle as on the left. Squeeze and stretch with Vertex tools until it suits you. Run SubD and there you have it. Old school swag lampshade. Just add some metal bits and textures, ready to hang....
      • HornOxxH
        HornOxx
        ๐Ÿ˜„ cool nice vintage look ๐Ÿ‘ again and again a surprise to me what happens to rectangles when pressing the SubD button ๐Ÿ˜„
        never trust a skinny cook
        • tuna1957T
          tuna1957
          Thanks HornOxx. Had brain fade. Should have shown proxy right before SubD..... so here it is !
          • BoxB
            Here's one you don't automatically think of using SUbD on. I created the threads using a standard 24 segment circle in the usual manner, then tapered them using FredoScale. Then using QFT I converted all the faces to quads so I could SUbD it and get these lovely smooth spindles. The rest was added after the SUbD.
            • HornOxxH
              HornOxx
              ๐Ÿ‘ ๐Ÿ˜ฒ the modelling is brilliant! as well as the quality of the metal representation in your render!
              • BoxB
                Thanks HornOxx, but there's always something that catches you out. To me the colour of the screws and the shape of the galvanized bracket just aren't right. But this is a SUbD thread so it's not so important.
                • tuna1957T
                  tuna1957
                  Box , your spindles are just insane ๐Ÿ‘ ๐Ÿ‘
                  • BoxB
                    Thanks Tuna.
                    • ntxdaveN
                      ntxdave
                      The spindles would be another good one for your tips And tricks thread. ๐Ÿ‘
                      Press F1...thank me later
                      • T
                        TeKnoel
                        Here's a study of a custom golf club I cranked out for one of the partners in my firm. Make of that what you will. Fun to model tho.
                        • BoxB
                          Something to keep in mind, SUbD and using quads isn't just about smoothing faces, the quads allow so much more control of the faces that make up your shapes.
                          The grid structure of the quads let me use Components onto Faces (onto Face Collections) to position all the cones evenly.
                          I could add and remove loops to thicken areas and thin others very easily too.
                          • cottyC
                            cotty
                            Very nice!
                            my SketchUp gallery
                              I'm happy to see how quad-based workflows have caught on within SketchUp users. For a while I felt like a raving lunatic back when I first created QuadFace Tools.
                              Always great to see your creations Box!
                                Btw, do you have some quad that are not fully QuadFace quads? I see some unexpected uneven edges in the back there:
                                • BoxB
                                  Yeah something odd happened there Thomas. They look right before using SUbD but you get that odd line of wobble. It was inside so I wasn't too concerned. The QFT convert often needs a bit of fixing.
                                    Do you have the control mesh so I can have a look?
                                    • HornOxxH
                                      HornOxx
                                      ... what a cool idea again Box !! - is this the way you created your cool "galaxy-like flying" lights recently? - somehow with a hidden quad geometry then? ๐Ÿ‘ ๐Ÿ˜„ but why aren't the prickles(?) inside too? ๐Ÿ˜ฎ
                                      @teknoel said:
                                      ... a custom golf club I cranked ... Fun to model tho.
                                      ๐Ÿ‘ ๐Ÿ‘ a well chosen SubD application example, Prima! ๐Ÿ˜„
                                      • BoxB
                                        The file is on a different computer, but I'm not sure if I still have the control, I normally unsubd them when I start playing around with them and render, as sometimes it seems to effect the render time.
                                        So I probably saved it unSUbD'd. I'll have a look tomorrow.
                                        • BoxB
                                          It was too much with them inside, needed a bit of contrast. Bit hard on the mollusc too.
                                          • BoxB
                                            Here's a quick shell I'm trying to get right, but too sleepy now. So maybe later.
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 83
                                            • 84
                                            • 63 / 84
