    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • pbacotP Offline
      Ok updating several Fredo6 plugins allows me to open without prompts and FredoTools and Fredo Collection seem to be in place as before!
      Still when I choose "View Trace Log Files..." sometimes a window flashes on and off but nothing else happens.
      FredoTools Launcher doesn't do anything.
      Solid Volume flashes a window briefly.
      • fredo6F Offline
        @oxer, @pbacot,
        Can you tell me which version of Safari you run on your Mac.
        It seems that Safari does not like a change I made in my code related to dialog boxes.
        • OxerO Offline
          Oxer
          Yes, have you probe anther options like Defaults Options..., Translate Language.., etc?
          To me, with all these options the popup window appear and disappear immediately.
          macOS High Sierra 10.13.6 & SU2017
          • pbacotP Offline
            I have Safari 12.0.2 (13606.3.4.1.4)
            • OxerO Offline
              Oxer
              • fredo6F Offline
                NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
                LibFredo6 8.7d fixes a major bug preventing dialog boxes to display on MAC
                • Z Offline
                  ztoundas
                  [quote="fredo6"]NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
                  ...Just installed an on windows, the dialog box for Convexify refused to show. :[
                  • Z Offline
                    ztoundas
                    Can we have access to 8.7a again? I've searched absolutely every where I can't find it, 8.7d broke Windows dialog boxes. Thanks!
                    • pbacotP Offline
                      Thanks Fredo for the help! (I just haven't got back to checking this last one.)
                        alirezakharazmi
                        Fredo,
                        I can not install Cruviloft! This is the error:
                        Curviloft: This plugin requires LibFredo6 version greater than 68.
                        Current version is 75.
                        I couldn't find a higher version of LibFredo. What should I do?
                        Thank you so much.
                        Alireza
                        • fredo6F Offline
                          @alirezakharazmi said:
                          Fredo,
                          I think the message is that you require LibFredo6 v8.6, and you have an old version (v7.5).
                          So just upgrade LibFredo6.
                          • fredo6F Offline
                            I fixed it with LibFredo6 v8.7e.
                            • fredo6F Offline
                              NEW RELEASE: LibFredo6 v8.7e - 01 Jan 19
                              LibFredo6 8.7e fixes a major bug preventing some dialog boxes to display
                              • fredo6F Offline
                                NEW RELEASE: LibFredo6 v8.7f - 10 Jan 19
                                LibFredo6 8.7f fixes a major bug preventing Animator to generate videos with recent versions of FFmpeg
                                  tonyliu
                                  θΌ‰ε…₯ζͺ”ζ‘ˆ Fredo6_!LibFredo6.rb ζ™‚η™Όη”ŸιŒ―θͺ€
                                  Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                  c:/users/εŠ‰η₯ζˆ/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:50:in gsub' c:/users/εŠ‰η₯ζˆ/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:50:in get_dir_from_ENV'
                                  c:/users/εŠ‰η₯ζˆ/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:413:in dir_appdata' c:/users/εŠ‰η₯ζˆ/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:211:in startup'
                                  C:/Users/εŠ‰η₯ζˆ/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/εŠ‰η₯ζˆ/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                  C:/Users/εŠ‰η₯ζˆ/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                                  window10
                                    @tonyliu
                                    Your Windows user-name in Chinese [εŠ‰ η₯ 成] "LiΓΊ yΓ²u chΓ©ng" seems to be causing the issue.
                                    Ruby is having difficulty encoding it into UTF-8 format...
                                    Having non-ASCII characters in user-names used to be a recipe for an error in Ruby; however, more recent versions are much better in forcing UTF-8 from such strings.
                                    Typically using this in the Ruby Console:
                                    ENV['USERNAME'].encoding
                                    or
                                    ENV['HOME'].encoding
                                    Returns this:
                                    Windows-1252
                                    Which is then converted to the required encoding of UTF-8 in the Ruby processing.
                                    What do you get returned for those ENV tests ?
                                    Perhaps Fredo can strengthen his code to force that encoding ??
                                      modoleinad
                                      Error Loading File Fredo6_!LibFredo6.rb
                                      c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in match' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in block (2 levels) in load_from_config'
                                      c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in each' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in block in load_from_config'
                                      c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in foreach' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in load_from_config'
                                      c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in block in load_all_plugins' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in each'
                                      c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in load_all_plugins' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:252:in startup'
                                      C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                      C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_FredoScale.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                                      C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                                      C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:47:in module:Fredo6'
                                      C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:26:in <top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                                      C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
                                      C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>' Error Loading File Fredo6_JointPushPull.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                                      C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in module:Fredo6'
                                      C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in `<top (required)>'
                                      Can anyone help me understand what this error means?
                                      • fredo6F Offline
                                        @modoleinad
                                        Usually, this problem comes when you installed Sketchup without Administrator rights.
                                        So I am afraid you need to uninstall SU2018 and reinstall.
                                          smeehanla
                                          I tried to download FredoTools and Toposhaper yesterday. My current LibFredo6 version is 8.5. I got a message saying that I need LibFredo6 version 86 for FredoTools and LibFredo6 version 87 for Toposhaper. The extension manager doesn't give me the option of updating my 8.5 version. Do I need to uninstall version 8.5 and then install version 8.7? Or do I leave 8.5 in the manager and just install 8.7?
                                            No need to uninstall the earlier version[s].
                                            The new installation will overwrite any equivalent files/version etc as needed.
                                            But you should restart SketchUp after finishing the installation[s] to ensure everything gets synced...
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 108
                                            • 109
                                            • 65 / 109
