    [Plugin Library] LibFredo6 - v15.9d - 09 Jul 26
    2.2k Posts 580 Posters 5.7m Views 582 Watching
      alirezakharazmi
      Fredo,
      I can not install Cruviloft! This is the error:
      Curviloft: This plugin requires LibFredo6 version greater than 68.
      Current version is 75.
      I couldn't find a higher version of LibFredo. What should I do?
      Thank you so much.
      Alireza
      • fredo6F Offline
        @alirezakharazmi said:
        Fredo,
        I think the message is that you require LibFredo6 v8.6, and you have an old version (v7.5).
        So just upgrade LibFredo6.
        • fredo6F Offline
          @ztoundas said:
          Can we have access to 8.7a again? I've searched absolutely every where I can't find it, 8.7d broke Windows dialog boxes. Thanks!
          I fixed it with LibFredo6 v8.7e.
          • fredo6F Offline
            NEW RELEASE: LibFredo6 v8.7e - 01 Jan 19
            LibFredo6 8.7e fixes a major bug preventing some dialog boxes to display
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v8.7f - 10 Jan 19
              LibFredo6 8.7f fixes a major bug preventing Animator to generate videos with recent versions of FFmpeg
                tonyliu
                載入檔案 Fredo6_!LibFredo6.rb 時發生錯誤
                Error: #<ArgumentError: invalid byte sequence in UTF-8>
                c:/users/劉祐成/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:50:in gsub' c:/users/劉祐成/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:50:in get_dir_from_ENV'
                c:/users/劉祐成/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:413:in dir_appdata' c:/users/劉祐成/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:211:in startup'
                C:/Users/劉祐成/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/劉祐成/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                C:/Users/劉祐成/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                window10
                  @tonyliu
                  Your Windows user-name in Chinese [劉 祐 成] "Liú yòu chéng" seems to be causing the issue.
                  Ruby is having difficulty encoding it into UTF-8 format...
                  Having non-ASCII characters in user-names used to be a recipe for an error in Ruby; however, more recent versions are much better in forcing UTF-8 from such strings.
                  Typically using this in the Ruby Console:
                  ENV['USERNAME'].encoding
                  or
                  ENV['HOME'].encoding
                  Returns this:
                  Windows-1252
                  Which is then converted to the required encoding of UTF-8 in the Ruby processing.
                  What do you get returned for those ENV tests ?
                  Perhaps Fredo can strengthen his code to force that encoding ??
                    modoleinad
                    Error Loading File Fredo6_!LibFredo6.rb
                    c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in match' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in block (2 levels) in load_from_config'
                    c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in each' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in block in load_from_config'
                    c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in foreach' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in load_from_config'
                    c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in block in load_all_plugins' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in each'
                    c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in load_all_plugins' c:/users/dan/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:252:in startup'
                    C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                    C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_FredoScale.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                    C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                    C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:47:in module:Fredo6'
                    C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:26:in <top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                    C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
                    C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>' Error Loading File Fredo6_JointPushPull.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                    C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in module:Fredo6'
                    C:/Users/dan/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in `<top (required)>'
                    Can anyone help me understand what this error means?
                    • fredo6F Offline
                      @modoleinad
                      Usually, this problem comes when you installed Sketchup without Administrator rights.
                      So I am afraid you need to uninstall SU2018 and reinstall.
                        smeehanla
                        I tried to download FredoTools and Toposhaper yesterday. My current LibFredo6 version is 8.5. I got a message saying that I need LibFredo6 version 86 for FredoTools and LibFredo6 version 87 for Toposhaper. The extension manager doesn't give me the option of updating my 8.5 version. Do I need to uninstall version 8.5 and then install version 8.7? Or do I leave 8.5 in the manager and just install 8.7?
                          No need to uninstall the earlier version[s].
                          The new installation will overwrite any equivalent files/version etc as needed.
                          But you should restart SketchUp after finishing the installation[s] to ensure everything gets synced...
                          • guanjinG Offline
                            guanjin
                            cannot be set in sketchup2015, all Chinese is empty.
                            • fredo6F Offline
                              Can you be more explicit for the problem.
                              I do have the Chinese in SU2015
                              • guanjinG Offline
                                guanjin
                                [attachment=1:18r21dr6]<!-- ia1 -->LibFredo6 - plugins load chinese.png<!-- ia1 -->[/attachment:18r21dr6]
                                [attachment=0:18r21dr6]<!-- ia0 -->LibFredo6 - About Chinese.png<!-- ia0 -->[/attachment:18r21dr6]
                                Found that your version is 8.7h, I installed 8.7f
                                • fredo6F Offline
                                  v8.7f is the latest release. v8.7h is an internal release on my own laptop.
                                  • fredo6F Offline
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v8.7k - 14 Feb 19
                                      LibFredo6 8.7k fixes various bugs and the accuracy of the hand cursor over button palettes
                                        Puco
                                        Hi Fredo one question, I installed SU 2019 and the first thing that I freshly install is LibFredo6-v8.7K but when I go to Windows/LibFredo6Settings/Check for updates it gives info that 8.7j is actually installed and needs an update to 8.7k... I tried everything to fix this, fresh install and everything and after several attempts to install 8.7k, it gives a result as if I have installed 8.7j and needs an update. Any help?
                                          You must restart SketchUp to ensure the latest installed version is loaded.
                                          But if the issue continues after that, then come back...
                                            Puco
                                            Did restart SketchUp, and my pc to be entirely sure that everything is set correctly, but no luck, 8.7j is installed instead of 8.7k. Checked the download folder if I accidentally have the wrong version downloaded, but no, everything is ok, 8.7 K is what I have downloaded and installed, and yet, SketchUp even upon restart of the program and pc says that I need to actually update to 8.7 k 😞
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 111
                                            • 112
                                            • 70 / 112
