    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • OxerO
      Oxer
      Nothing in Ruby Console. 😲
      I open for example Window Menu> LibFredo Options> Check Updates for Plugins and the window appears but it closes immediately.
      EDIT: After that I can use another Skechup Tools but if I press Cmd+Q (exit SU on Mac) SketchUp doesn't close, I have to force the exit.
      • OxerO
        Oxer
        It's with the dialogs (popup windows) only, the palletes works fine.
        How I said you before to access to yours plugins I can do this through the Tool & Extensions Menu or Contextual Menu only.
        • fredo6F
          Is it for all popup dialog boxes ?
          • pbacotP
            I have loaded this plugin but my Fredo tools don't work. I get several prompts on opening SketchUp. According to the Plugin Manager I have the latest plugin.
            • fredo6F
              Seems to be something quite old, because there is no longer a reference to LibFredo6 6.3 in the latest version of my plugins. Can you check for TopoShaper.
              Also, ff you run LibFredo6 8.7a, could you send me the trace file (Windows > Library Settings > Trace Log File...
              Another user has signaled me an anomaly with popup messages.
              • pbacotP
                I choose "View Trace Log Files..." and nothing happens. Let me try updating. I know most plugins are recent updates, but some like TopoShaper may not be.
                • pbacotP
                  hmm... check for updates doesn't work either.
                  • fredo6F
                    Same problem as Oxer. You are on Mac, and there seems to be a problem with Web dialog boxes.
                    Since you have FredoTools installed, could you check if
                    • the Quick Launcher works
                    • if Solid Volume displays a dialog box
                    • pbacotP
                      Ok updating several Fredo6 plugins allows me to open without prompts and FredoTools and Fredo Collection seem to be in place as before!
                      Still when I choose "View Trace Log Files..." sometimes a window flashes on and off but nothing else happens.
                      FredoTools Launcher doesn't do anything.
                      Solid Volume flashes a window briefly.
                      • fredo6F
                        @oxer, @pbacot,
                        Can you tell me which version of Safari you run on your Mac.
                        It seems that Safari does not like a change I made in my code related to dialog boxes.
                        • OxerO
                          Oxer
                          Yes, have you probe anther options like Defaults Options..., Translate Language.., etc?
                          To me, with all these options the popup window appear and disappear immediately.
                          macOS High Sierra 10.13.6 & SU2017
                          • pbacotP
                            I have Safari 12.0.2 (13606.3.4.1.4)
                            • OxerO
                              Oxer
                              • fredo6F
                                NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
                                LibFredo6 8.7d fixes a major bug preventing dialog boxes to display on MAC
                                • Z
                                  ztoundas
                                  [quote="fredo6"]NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
                                  ...Just installed an on windows, the dialog box for Convexify refused to show. :[
                                  • Z
                                    ztoundas
                                    Can we have access to 8.7a again? I've searched absolutely every where I can't find it, 8.7d broke Windows dialog boxes. Thanks!
                                    • pbacotP
                                      Thanks Fredo for the help! (I just haven't got back to checking this last one.)
                                        alirezakharazmi
                                        Fredo,
                                        I can not install Cruviloft! This is the error:
                                        Curviloft: This plugin requires LibFredo6 version greater than 68.
                                        Current version is 75.
                                        I couldn't find a higher version of LibFredo. What should I do?
                                        Thank you so much.
                                        Alireza
                                        • fredo6F
                                          @alirezakharazmi said:
                                          Fredo,
                                          I think the message is that you require LibFredo6 v8.6, and you have an old version (v7.5).
                                          So just upgrade LibFredo6.
                                          • fredo6F
                                            I fixed it with LibFredo6 v8.7e.
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 115
                                            • 116
                                            • 69 / 116
