    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.1m Views 585 Watching
    • pbacotP
      I have loaded this plugin but my Fredo tools don't work. I get several prompts on opening SketchUp. According to the Plugin Manager I have the latest plugin.
      • fredo6F
        Seems to be something quite old, because there is no longer a reference to LibFredo6 6.3 in the latest version of my plugins. Can you check for TopoShaper.
        Also, ff you run LibFredo6 8.7a, could you send me the trace file (Windows > Library Settings > Trace Log File...
        Another user has signaled me an anomaly with popup messages.
        • pbacotP
          I choose "View Trace Log Files..." and nothing happens. Let me try updating. I know most plugins are recent updates, but some like TopoShaper may not be.
          • pbacotP
            hmm... check for updates doesn't work either.
            • fredo6F
              Same problem as Oxer. You are on Mac, and there seems to be a problem with Web dialog boxes.
              Since you have FredoTools installed, could you check if
              • the Quick Launcher works
              • if Solid Volume displays a dialog box
              • pbacotP
                Ok updating several Fredo6 plugins allows me to open without prompts and FredoTools and Fredo Collection seem to be in place as before!
                Still when I choose "View Trace Log Files..." sometimes a window flashes on and off but nothing else happens.
                FredoTools Launcher doesn't do anything.
                Solid Volume flashes a window briefly.
                • fredo6F
                  @oxer, @pbacot,
                  Can you tell me which version of Safari you run on your Mac.
                  It seems that Safari does not like a change I made in my code related to dialog boxes.
                  • OxerO
                    Oxer
                    Yes, have you probe anther options like Defaults Options..., Translate Language.., etc?
                    To me, with all these options the popup window appear and disappear immediately.
                    macOS High Sierra 10.13.6 & SU2017
                    • pbacotP
                      I have Safari 12.0.2 (13606.3.4.1.4)
                      • OxerO
                        Oxer
                        • fredo6F
                          NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
                          LibFredo6 8.7d fixes a major bug preventing dialog boxes to display on MAC
                          • Z
                            ztoundas
                            [quote="fredo6"]NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
                            ...Just installed an on windows, the dialog box for Convexify refused to show. :[
                            • Z
                              ztoundas
                              Can we have access to 8.7a again? I've searched absolutely every where I can't find it, 8.7d broke Windows dialog boxes. Thanks!
                              • pbacotP
                                Thanks Fredo for the help! (I just haven't got back to checking this last one.)
                                  alirezakharazmi
                                  Fredo,
                                  I can not install Cruviloft! This is the error:
                                  Curviloft: This plugin requires LibFredo6 version greater than 68.
                                  Current version is 75.
                                  I couldn't find a higher version of LibFredo. What should I do?
                                  Thank you so much.
                                  Alireza
                                  • fredo6F
                                    @alirezakharazmi said:
                                    Fredo,
                                    I think the message is that you require LibFredo6 v8.6, and you have an old version (v7.5).
                                    So just upgrade LibFredo6.
                                    • fredo6F
                                      I fixed it with LibFredo6 v8.7e.
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v8.7e - 01 Jan 19
                                        LibFredo6 8.7e fixes a major bug preventing some dialog boxes to display
                                        • fredo6F
                                          NEW RELEASE: LibFredo6 v8.7f - 10 Jan 19
                                          LibFredo6 8.7f fixes a major bug preventing Animator to generate videos with recent versions of FFmpeg
                                          • T
                                            tonyliu
                                            載入檔案 Fredo6_!LibFredo6.rb 時發生錯誤
                                            Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                            c:/users/劉祐成/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:50:in gsub' c:/users/劉祐成/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:50:in get_dir_from_ENV'
                                            c:/users/劉祐成/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:413:in dir_appdata' c:/users/劉祐成/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:211:in startup'
                                            C:/Users/劉祐成/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/劉祐成/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                            C:/Users/劉祐成/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                                            window10
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 112
                                            • 113
                                            • 70 / 113
