    1.3k Posts 300 Posters 3.3m Views 298 Watching
      rv1974
      In 99% of of lofting uses I have to straighten borders connnecting ends of segments afterwards(thanks Thom there're Edge tools so it's not manual). Could there be an optionto keep them straight when creating?
      • fredo6F
        Not too sure what you mean by 'straighten'.
        Maybe an example would be helpful.
          rv1974
          Edit: Only after posting I figured out 'junction by connected lines' in 'spline method' fixes this problem' πŸ˜„
          • fredo6F
            I really need to refresh the plugin with more explicit control of the different options (and maybe selecting a few ones which make sense). Currently, Curviloft rather exposes the options that come from the algorithm, up to the user to find out what is appropriate. That's why I still leave it in Beta after all these years!
            • jgbJ
              jgb
              I wholeheartedly agree, but please also update your last 32 bit version as well.
              I cannot run 64 bit apps on my old PC. I'm still running Make V.13.
              jgb
                Loft along the path: can we modify the path after launch the plugin?
                I don't see it! (the path)
                • fredo6F
                  What do you mean?
                  Do you have issues with Curviloft on Sketchup 2013?
                    rv1974
                    I searched hard to find how to save this method as default but no luck. Is it possible at least make this tool to remember last used settings at least? If it could remember them permanently it'd be even better. Thank you.
                    • fredo6F
                      Do you use the latest version (1.8a)? It keeps the latest settings across Sketchup sessions and I checked it works with SU2013.
                        rv1974
                        Great news! β˜€ Gone refreshing ALL of yours
                          rv1974
                          I checked, v1.8.a doesn't keep my last used settings (at least junktion by connected lines method)
                          • fredo6F
                            I forgot to say that you need to enable the option in Default Parameters....
                            • jgbJ
                              jgb
                              What do you mean?
                              It's not that I have issues with CL in SU-2013, just I thought the latest CL update versions were 64 bit only. I will D/L the latest later this week.
                              jgb
                              • fredo6F
                                In principle, Ruby script are independent from the OS details (hopefully), but sometimes dependent on the SketchUp version.
                                The trend is effectively that I will progressively transition my scripts toward SU2016 and above, but I'll keep usually the existing version, at least in maintenance mode, and the new version would probably include more functionality. This is what happens with RoundCorner and FredoCorner. So when you see FredoLoft published for SU2016+, you would still have access to Curviloft, even if it would likely be in maintenance mode.
                                • jgbJ
                                  jgb
                                  Thanks again. πŸ˜„ I'll now upgrade SU to 2016 (32bit) and all my plugins/extensions as well.
                                  jgb
                                  • E
                                    Einstein
                                    I made a loft and added a forced pair for each vertex of profile. Now there are some unnecessary pairs (yellow ones) between vertices and I was thinking if it's possible to remove them before applying the loft.
                                    In this case both profiles - upper and lower - are hexagons. So intuitively, pairs should be created between vertices only. Instead, Curviloft connected each vertex of lower profile to edge midpoint of upper profile, which created a lot of unnecessary edges. So I'm thinking if I could force the tool to always match vertex-to-vertex when profiles have the same number of verts.
                                    • fredo6F
                                      I think there is an option to match vertex to vertex.
                                      Anyway, the best would be to post your model so that I have a look.
                                      Keep in mind that for a human brain, you see indeed two similar hexagons, but for the script, these are two curves to match in different planes.
                                      • E
                                        Einstein
                                        I used default method "Match vertex to vertex (when possible)" but looks like the case was interpreted as "impossible" πŸ˜›
                                        Here's an example:
                                        vertex matching.skp
                                        • fredo6F
                                          I understand. There is something wrong in the vertex matching, also in the Loft by Spline tool. I'll need to have a closer look.
                                            reza1813
                                            Dear Fredo,
                                            Hello, I kindly reach you to suggest some feature for the future update of Curviloft plugin.
                                            1. I wonder to know why Curviloft doesn't create a surface when we have an Integrated curve. In fact, I always use the Soap Skin Bubble plugin in order to deal with this type of shape and unfortunately I have a problem to push surface properly. Would you mind any possibility to add this feature of Soap Skin Bubble plugin to the next version of Curviloft concerning to create the surface for all type of connected line and curve?
                                              Curviloft
                                            2. Furthermore, this is the FormZ software. I wonder to know, Is there any possibility to change the type of surface and also how it is pushed and pulled in the Curviloft with some icon in order to increase or decrease it like FormZ software? (I know that there is some option in the spline method)
                                              Curviloft-Formz
                                            Sincerely
                                            Hamidreza
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 65
                                            • 66
                                            • 60 / 66
