    1.3k Posts 300 Posters 3.2m Views 298 Watching
      Architure
      Hi there,
      Sorry for my late reply. Here is the attached 2018 skp file . You can see that the selected mode is only applied between the first 3 curves.
      Let me know if I can provide more information.
      Cheers
      seat back.skp
      • fredo6F
        NEW RELEASE: Curviloft v1.8a - 31 Oct 18
        Curviloft 1.8a is a maintenance release for bug fixing.
        See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
        Main post of this thread
        • Z
          zswseu
          Looking forward to another excellent work.
            rv1974
            In 99% of of lofting uses I have to straighten borders connnecting ends of segments afterwards(thanks Thom there're Edge tools so it's not manual). Could there be an optionto keep them straight when creating?
            • fredo6F
              Not too sure what you mean by 'straighten'.
              Maybe an example would be helpful.
                rv1974
                Edit: Only after posting I figured out 'junction by connected lines' in 'spline method' fixes this problem' πŸ˜„
                • fredo6F
                  I really need to refresh the plugin with more explicit control of the different options (and maybe selecting a few ones which make sense). Currently, Curviloft rather exposes the options that come from the algorithm, up to the user to find out what is appropriate. That's why I still leave it in Beta after all these years!
                  • jgbJ
                    jgb
                    I wholeheartedly agree, but please also update your last 32 bit version as well.
                    I cannot run 64 bit apps on my old PC. I'm still running Make V.13.
                    jgb
                      Loft along the path: can we modify the path after launch the plugin?
                      I don't see it! (the path)
                      • fredo6F
                        What do you mean?
                        Do you have issues with Curviloft on Sketchup 2013?
                          rv1974
                          I searched hard to find how to save this method as default but no luck. Is it possible at least make this tool to remember last used settings at least? If it could remember them permanently it'd be even better. Thank you.
                          • fredo6F
                            Do you use the latest version (1.8a)? It keeps the latest settings across Sketchup sessions and I checked it works with SU2013.
                              rv1974
                              Great news! β˜€ Gone refreshing ALL of yours
                                rv1974
                                I checked, v1.8.a doesn't keep my last used settings (at least junktion by connected lines method)
                                • fredo6F
                                  I forgot to say that you need to enable the option in Default Parameters....
                                  • jgbJ
                                    jgb
                                    What do you mean?
                                    It's not that I have issues with CL in SU-2013, just I thought the latest CL update versions were 64 bit only. I will D/L the latest later this week.
                                    jgb
                                    • fredo6F
                                      In principle, Ruby script are independent from the OS details (hopefully), but sometimes dependent on the SketchUp version.
                                      The trend is effectively that I will progressively transition my scripts toward SU2016 and above, but I'll keep usually the existing version, at least in maintenance mode, and the new version would probably include more functionality. This is what happens with RoundCorner and FredoCorner. So when you see FredoLoft published for SU2016+, you would still have access to Curviloft, even if it would likely be in maintenance mode.
                                      • jgbJ
                                        jgb
                                        Thanks again. πŸ˜„ I'll now upgrade SU to 2016 (32bit) and all my plugins/extensions as well.
                                        jgb
                                        • E
                                          Einstein
                                          I made a loft and added a forced pair for each vertex of profile. Now there are some unnecessary pairs (yellow ones) between vertices and I was thinking if it's possible to remove them before applying the loft.
                                          In this case both profiles - upper and lower - are hexagons. So intuitively, pairs should be created between vertices only. Instead, Curviloft connected each vertex of lower profile to edge midpoint of upper profile, which created a lot of unnecessary edges. So I'm thinking if I could force the tool to always match vertex-to-vertex when profiles have the same number of verts.
                                          • fredo6F
                                            I think there is an option to match vertex to vertex.
                                            Anyway, the best would be to post your model so that I have a look.
                                            Keep in mind that for a human brain, you see indeed two similar hexagons, but for the script, these are two curves to match in different planes.
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 65
                                            • 66
                                            • 60 / 66
