    1.3k Posts 300 Posters 3.3m Views 298 Watching
      rv1974
      Thanks for mentioning those alternatives- I'll check them. I'm so glued to your tools that completely forgot others πŸ˜„
      BTW the straight line on a blue tower shows the horizontal segments don't sit perfectly on it. The gap is ridiculously small in real life scale (~0.3cm in the middle floors, but big enough to spoil the model
        rv1974
        Fredo could you take a look please
        messy result with a newest version (loft)
        • fredo6F
          I need to consider this case of indetical profiles more seriously, which Curviloft did not really do.
          So I'll come with something more robust.
            Architure
            Hi there,
            When selecting more than 3 edge curves, and choosing for junction by orthogonal bezier curves, the surfaces do not get the reach the right spline method result.
            Here is what the ruby console shows
            Error: #<ArgumentError: Cannot create unit vector from zero length vector>
            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in axes' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in compute_by_offset'
            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:58:in compute_by_vectors2' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:86:in compute_by_normals'
            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:357:in block in spline_profiling_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in each'
            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in each_with_index' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in spline_profiling_construct'
            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:249:in spline_junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in generic_junction_construct'
            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all'
            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all'
            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:530:in option_set_prop'
            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:206:in option_set_prop' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in call'
            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in block in pal_family_spline_method' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3963:in call'
            Just ask me for the file if needed!
            Cheers
            Manuel
            • fredo6F
              Yes the file would be useful, as this seems to be a special case.
                Architure
                Hi there,
                Sorry for my late reply. Here is the attached 2018 skp file . You can see that the selected mode is only applied between the first 3 curves.
                Let me know if I can provide more information.
                Cheers
                seat back.skp
                • fredo6F
                  NEW RELEASE: Curviloft v1.8a - 31 Oct 18
                  Curviloft 1.8a is a maintenance release for bug fixing.
                  See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
                  Main post of this thread
                  • Z
                    zswseu
                    Looking forward to another excellent work.
                      rv1974
                      In 99% of of lofting uses I have to straighten borders connnecting ends of segments afterwards(thanks Thom there're Edge tools so it's not manual). Could there be an optionto keep them straight when creating?
                      • fredo6F
                        Not too sure what you mean by 'straighten'.
                        Maybe an example would be helpful.
                          rv1974
                          Edit: Only after posting I figured out 'junction by connected lines' in 'spline method' fixes this problem' πŸ˜„
                          • fredo6F
                            I really need to refresh the plugin with more explicit control of the different options (and maybe selecting a few ones which make sense). Currently, Curviloft rather exposes the options that come from the algorithm, up to the user to find out what is appropriate. That's why I still leave it in Beta after all these years!
                            • jgbJ
                              jgb
                              I wholeheartedly agree, but please also update your last 32 bit version as well.
                              I cannot run 64 bit apps on my old PC. I'm still running Make V.13.
                              jgb
                                Loft along the path: can we modify the path after launch the plugin?
                                I don't see it! (the path)
                                • fredo6F
                                  What do you mean?
                                  Do you have issues with Curviloft on Sketchup 2013?
                                    rv1974
                                    I searched hard to find how to save this method as default but no luck. Is it possible at least make this tool to remember last used settings at least? If it could remember them permanently it'd be even better. Thank you.
                                    • fredo6F
                                      Do you use the latest version (1.8a)? It keeps the latest settings across Sketchup sessions and I checked it works with SU2013.
                                        rv1974
                                        Great news! β˜€ Gone refreshing ALL of yours
                                          rv1974
                                          I checked, v1.8.a doesn't keep my last used settings (at least junktion by connected lines method)
                                          • fredo6F
                                            I forgot to say that you need to enable the option in Default Parameters....
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 65
                                            • 66
                                            • 60 / 66
