    [Plugin] Slicer5
    338 Posts 83 Posters 419.2k Views 82 Watching
    • C
      carpa65
      Hi, first of all a very fine script that fit my needs.
      one thing i would see is the posibilityto increase the number of
      sides/polygons on curves and circles. i would like to export the files to a milling machine and cutter with perfect circles without steps.
      keep doing the good work.
        The number of sides on curves and circles is determined by the user when they draw them, not by Slicer. If you want smoother curves in the slices, draw smoother curves in the slicee.
          Alagcommer
          Hi TIG,
          The quality of your work is impressive.
          I meet a problem with a model :
          When i do a XZ slices it crashes but not with Z only.
          Could you tell me what is wrong with this model ?
          I'm awaiting for your answer.
          Regards
          Alain
          param
          model
            It's probably because the slicing spacing results in tiny length edges, which SketchUp can't make - < 1/1000"
            Either rotate the object and try slicing it in the pseudo-z axis...
            Or use a pseudo 'Dave' method...
            With just your object in its own model...
            Scale the object up by x100.
            Do the slicing, increasing all of the slice measurements by x100 too.
            Do the slicing.
            Assuming it's all done successfully...
            Rescale the results by 1/100 - you can do this using the Tapemeasure tool - pick two points on the object and type in what the distance should be when scaled-back.
            Choose to scale the model.
            Now everything is back to the small size.
            Some geometry can exist, but SketchUp's native tools, and by extension Ruby code, cannot create it !
              Alagcommer
              thanks for your help.
              I'll let you know.
                Alagcommer
                I tried both solutions with no luck 😞
                  Works for me : I have Scale * 1000 πŸ˜‰
                    Alagcommer
                    Merci Pilou
                    I'll try with this scale as 100 is not enough
                      you can make 10 000...for be more sure! πŸ˜‰
                        Alagcommer
                        Finally I succeeded with a x1000 scale.
                        But now I have the "invisible but there" issue !.
                        Tweaking my OpenGl params didn't solve the problem.
                        How can I see my sliced model?
                          Do you mean clipping? Set the Camera to Perspective and hit Zoom Extents.
                          You should be modeling with the camera set to Perspective and save Parallel Projection for exported images when it's appropriate.
                            Ahmed0007
                            Slotter not working for me in su2018
                            what's wrong i'm doing anyone can please figure out?
                            please see attachment
                              Please try it with the Ruby Console open and report any messages when you run it.
                              Also please post a screenshot of your settings.
                              If the object is too small, then slots might not get formed properly.
                              You can also attach a simple model's SKP, so that we can test it too...
                                Ahmed0007
                                Thanks a lot TIG for your quick response
                                i also tried in su 2015
                                Untitled.skp
                                  Can you attached the un-sliced object to a post, so that I can have a look at its weirdness...
                                  Also please provide your Slicer-settings...
                                    Ahmed0007
                                    settings included in skp file
                                    un-sliced.skp
                                      In v2018 it works fine for me.
                                      Although in this screenshot the text height is bigger, it also works with the original
                                      So... what is different in your set up ?
                                        Ahmed0007
                                        Pre Slotted works fine. its not update after changing.
                                        i explain in previous gif
                                          Ahmed0007
                                          (streamable.com)
                                            Thank you.
                                            Now I see your issue.
                                            I'll investigate further...
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
