    [Plugin] Slicer5
    338 Posts 83 Posters 419.2k Views 82 Watching
      Alagcommer
      I tried both solutions with no luck ๐Ÿ˜ž
        Works for me : I have Scale * 1000 ๐Ÿ˜‰
          Alagcommer
          Merci Pilou
          I'll try with this scale as 100 is not enough
            you can make 10 000...for be more sure! ๐Ÿ˜‰
              Alagcommer
              Finally I succeeded with a x1000 scale.
              But now I have the "invisible but there" issue !.
              Tweaking my OpenGl params didn't solve the problem.
              How can I see my sliced model?
                Do you mean clipping? Set the Camera to Perspective and hit Zoom Extents.
                You should be modeling with the camera set to Perspective and save Parallel Projection for exported images when it's appropriate.
                  Ahmed0007
                  Slotter not working for me in su2018
                  what's wrong i'm doing anyone can please figure out?
                  please see attachment
                    Please try it with the Ruby Console open and report any messages when you run it.
                    Also please post a screenshot of your settings.
                    If the object is too small, then slots might not get formed properly.
                    You can also attach a simple model's SKP, so that we can test it too...
                      Ahmed0007
                      Thanks a lot TIG for your quick response
                      i also tried in su 2015
                      Untitled.skp
                        Can you attached the un-sliced object to a post, so that I can have a look at its weirdness...
                        Also please provide your Slicer-settings...
                          Ahmed0007
                          settings included in skp file
                          un-sliced.skp
                            In v2018 it works fine for me.
                            Although in this screenshot the text height is bigger, it also works with the original
                            So... what is different in your set up ?
                              Ahmed0007
                              Pre Slotted works fine. its not update after changing.
                              i explain in previous gif
                                Ahmed0007
                                (streamable.com)
                                  Thank you.
                                  Now I see your issue.
                                  I'll investigate further...
                                    Ahmed0007
                                    Thank you for your Time.
                                    i also noticed another issue
                                    Bug Splat when i try to export dxf with 2d text References
                                    (without text it's works fine and fast)
                                      I think I've fixed the issue with the 'Add-Slot' tool failures...
                                      Here's v6.0...
                                      https://sketchucation.com/pluginstore?pln=TIG_Slicer
                                      Note that you can still only use this tool once on any 'un-slotted' set of parts...
                                        Ahmed0007
                                        ๐Ÿ˜ฎ ๐Ÿ˜ฒ Amazing Thank you soooooo Much.
                                          max444
                                          Hey TIG, awesome plugin here. I'm pretty new to sketchup but I decided it was what I needed to do what I'm trying to do so I'm working through it well. Quick question - I got my model sliced and ready but I'm having issues with the PNG export. It seems to save the background only, regardless of what setting I'm using to view the slices. I've tried wireframe and shaded ect. not sure what I'm missing here? Thanks again!
                                          • B
                                            boramille
                                            After It finished sliding, I can not see my object and everything in the file. Can anyone tell me how to get my object back?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
