    [Plugin] follow me rotate
    211 Posts 79 Posters 263.7k Views 79 Watching
    • duanekempD Offline
      duanekemp
      @wikii said:
      It is still in developing, here is the current version.
      Get the latest version as an RBZ from the PluginStore:
      wikii, This is such a cool, useful and needed plugin. Alternatives to get similar results are tedious, time consuming and not always effective. If possible, I'd like to encourage the continued development of this plugin for SU2017 and SU2018.... resurrect this puppy so it can be used without reverting to SU 2015/16.
      I hope you release a new version since this does what needs to be done. And again, thank you for making this!!!
      Duane Kemp
      Kemp Productions
      Puidoux, Switzerland
      Gallery:
      https://duanekemp.artstation.com/
        Ahmed0007
        Thanks For Plugin
        Please Update for 2017/18
        • E Offline
          Einstein
          Houson, I have a problem 😞
          I installed Follow and rotate, checked that all files have been pasted into Plugins folder. I clicked the extension record but the plugin window didn't show up 😞 Instead, Ruby throwed an error:
          Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
          c:/users/dell/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:42:in add' c:/users/dell/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:42:in wikii_push_pull'
          c:/users/dell/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:109:in block in <main>' SketchUp:1:in call'
          I preselected a face (with and then without its bounding edges, as TIG advised) and a welded path-curve but nothing happened. Adding quide point at the begining and ending of path did not help either. I read that many people had similar problem formerly but I didn't find solution in the thread.
          I removed the .rbs file with _en suffix which prevented SU from splashing error on startup but still I cannot run the tool.
            Einstein, see this. It doesn't work in SU2017 or SU2018 and the author would need to fix it because it is encrypted. So far the author hasn't shown any interest in fixing it, though.
            • N Offline
              ninja29
              hi, how to i install this rbz file to sketcup 2017? thank you
                If you've downloaded the RBZ file to your computer, use Install Extension which will be found in Window>Extension manager. There's not much point installing this one, however. If you read my post before yours and follow the link I provided, you'll see it doesn't work in SU2017.
                  aleksandri
                  somethings's wrong.. I can't get it to work properly
                    Go back to posts over a year ago where it's explained how to remove the incorrect RB file so that it at least loads.
                    However, since it's already been reported as flaky in v2017, its encrypted files might not now be fixable...
                    • H Offline
                      hikamalsingh
                      Hi Wikii ... please help
                      I am using sketup2018pro
                      I have loaded the new file Far_v1.0
                      I am selecting the follow curve and then the plane (without edges)
                      and its giving me the following error
                      c:/users/kamal/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in add' c:/users/kamal/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in wikii_push_pull'
                      c:/users/kamal/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:109:in block in <main>' SketchUp:1:in call'
                      thanks
                        It's already been reported that this extension doesn't work in Su2017 or SU2018. See the previous posts in this thread regarding that. It appears that the author isn't going to update it for newer versions of SketchUp. At least they haven't yet.
                          As Dave says the original author hasn't supported this tool for many years.
                          It doesn't work in any of the newer SketchUp versions.
                          Under the terms of its Β© notice it could be reworked and republished, but I looked at it last year and found that to make it compatible with newer SketchUp could involve so much work it might as well be rewritten from scratch !
                          So search for an alternative tool...
                            maxosmedia
                            Is the plug-in module dead? Does not work on SU 2018-2019
                              If you read the posts above yours, you'll see that it hasn't been updated in quite a long time. Evidently the author has elected not to support it anymore.
                                Swick
                                I get this error in the ruby console:
                                c:/users/kasutaja/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in add' c:/users/kasutaja/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in wikii_push_pull'
                                c:/users/kasutaja/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:109:in block in <main>' SketchUp:1:in call'
                                  If you read the last few posts in this thread you would know that this plugin hasn't been updated in years. It appears the author no longer supports it.
                                    duanekemp
                                    What plugin would be suggested to replace Follow me rotate for the newer versions of SU that would follow a bezier curved line?
                                    Duane Kemp
                                    Kemp Productions
                                    Gallery:
                                      Helix along curve ?
                                      (can't test on the new versions 😒
                                        duanekemp
                                        Pilou,
                                        I'll give that a try. Thanks
                                        Duane Kemp
                                        Kemp Productions
                                        Gallery:
                                          andrea1980
                                          hello, when I install the Follow me and rotate plugin and open sketchup it gives me Error: SketchUp: 1: in `eval 'and the extension doesn't work. how can i use it?
                                            @andrea1980 said:
                                            how can i use it?
                                            You'd need an old version of SketchUp. If you read a few posts up from yours you will see this plugin does not work with SketchUp 2017. It hasn't been supported for years. Best thing is to look for a different tool to do what you want.
                                            • 11
                                            • 10 / 11
