    [Plugin] follow me rotate
    211 Posts 79 Posters 274.1k Views 79 Watching
      ...or use an old version of Su! πŸ˜‰
        targetx
        Hi guys!
        Carefully had read everything, made every step as adviced. Installed, removed EN version. No errors, plugin appeared in the menu and everything seemed to be successful, but ... while clicking on the plugin there is NO input box ... Tried on SU 2016 ans 2013 - same result. Please help me to run the plugin πŸ˜„ Thanks!
        • duanekempD Offline
          duanekemp
          @wikii said:
          It is still in developing, here is the current version.
          Get the latest version as an RBZ from the PluginStore:
          wikii, This is such a cool, useful and needed plugin. Alternatives to get similar results are tedious, time consuming and not always effective. If possible, I'd like to encourage the continued development of this plugin for SU2017 and SU2018.... resurrect this puppy so it can be used without reverting to SU 2015/16.
          I hope you release a new version since this does what needs to be done. And again, thank you for making this!!!
          Duane Kemp
          Kemp Productions
          Puidoux, Switzerland
          Gallery:
          https://duanekemp.artstation.com/
            Ahmed0007
            Thanks For Plugin
            Please Update for 2017/18
            • E Offline
              Einstein
              Houson, I have a problem 😞
              I installed Follow and rotate, checked that all files have been pasted into Plugins folder. I clicked the extension record but the plugin window didn't show up 😞 Instead, Ruby throwed an error:
              Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
              c:/users/dell/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:42:in add' c:/users/dell/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:42:in wikii_push_pull'
              c:/users/dell/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:109:in block in <main>' SketchUp:1:in call'
              I preselected a face (with and then without its bounding edges, as TIG advised) and a welded path-curve but nothing happened. Adding quide point at the begining and ending of path did not help either. I read that many people had similar problem formerly but I didn't find solution in the thread.
              I removed the .rbs file with _en suffix which prevented SU from splashing error on startup but still I cannot run the tool.
                Einstein, see this. It doesn't work in SU2017 or SU2018 and the author would need to fix it because it is encrypted. So far the author hasn't shown any interest in fixing it, though.
                • N Offline
                  ninja29
                  hi, how to i install this rbz file to sketcup 2017? thank you
                    If you've downloaded the RBZ file to your computer, use Install Extension which will be found in Window>Extension manager. There's not much point installing this one, however. If you read my post before yours and follow the link I provided, you'll see it doesn't work in SU2017.
                      aleksandri
                      somethings's wrong.. I can't get it to work properly
                        Go back to posts over a year ago where it's explained how to remove the incorrect RB file so that it at least loads.
                        However, since it's already been reported as flaky in v2017, its encrypted files might not now be fixable...
                        • H Offline
                          hikamalsingh
                          Hi Wikii ... please help
                          I am using sketup2018pro
                          I have loaded the new file Far_v1.0
                          I am selecting the follow curve and then the plane (without edges)
                          and its giving me the following error
                          c:/users/kamal/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in add' c:/users/kamal/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in wikii_push_pull'
                          c:/users/kamal/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:109:in block in <main>' SketchUp:1:in call'
                          thanks
                            It's already been reported that this extension doesn't work in Su2017 or SU2018. See the previous posts in this thread regarding that. It appears that the author isn't going to update it for newer versions of SketchUp. At least they haven't yet.
                              As Dave says the original author hasn't supported this tool for many years.
                              It doesn't work in any of the newer SketchUp versions.
                              Under the terms of its Β© notice it could be reworked and republished, but I looked at it last year and found that to make it compatible with newer SketchUp could involve so much work it might as well be rewritten from scratch !
                              So search for an alternative tool...
                                maxosmedia
                                Is the plug-in module dead? Does not work on SU 2018-2019
                                  If you read the posts above yours, you'll see that it hasn't been updated in quite a long time. Evidently the author has elected not to support it anymore.
                                    Swick
                                    I get this error in the ruby console:
                                    c:/users/kasutaja/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in add' c:/users/kasutaja/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in wikii_push_pull'
                                    c:/users/kasutaja/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:109:in block in <main>' SketchUp:1:in call'
                                      If you read the last few posts in this thread you would know that this plugin hasn't been updated in years. It appears the author no longer supports it.
                                        duanekemp
                                        What plugin would be suggested to replace Follow me rotate for the newer versions of SU that would follow a bezier curved line?
                                        Duane Kemp
                                        Kemp Productions
                                        Gallery:
                                          Helix along curve ?
                                          (can't test on the new versions 😒
                                            duanekemp
                                            Pilou,
                                            I'll give that a try. Thanks
                                            Duane Kemp
                                            Kemp Productions
                                            Gallery:
                                            • 11
                                            • 10 / 11
