    [Plugin] follow me rotate
    211 Posts 79 Posters 274.1k Views 79 Watching
      As Dave says the original author hasn't supported this tool for many years.
      It doesn't work in any of the newer SketchUp versions.
      Under the terms of its Β© notice it could be reworked and republished, but I looked at it last year and found that to make it compatible with newer SketchUp could involve so much work it might as well be rewritten from scratch !
      So search for an alternative tool...
        maxosmedia
        Is the plug-in module dead? Does not work on SU 2018-2019
          If you read the posts above yours, you'll see that it hasn't been updated in quite a long time. Evidently the author has elected not to support it anymore.
            Swick
            I get this error in the ruby console:
            Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
            c:/users/kasutaja/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in add' c:/users/kasutaja/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:42:in wikii_push_pull'
            c:/users/kasutaja/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/followandrotate_cn.rbs:109:in block in <main>' SketchUp:1:in call'
              If you read the last few posts in this thread you would know that this plugin hasn't been updated in years. It appears the author no longer supports it.
              • duanekempD Offline
                duanekemp
                What plugin would be suggested to replace Follow me rotate for the newer versions of SU that would follow a bezier curved line?
                Duane Kemp
                Kemp Productions
                Puidoux, Switzerland
                Gallery:
                https://duanekemp.artstation.com/
                  Helix along curve ?
                  (can't test on the new versions 😒
                    duanekemp
                    Pilou,
                    I'll give that a try. Thanks
                    Duane Kemp
                    Kemp Productions
                    Gallery:
                      andrea1980
                      hello, when I install the Follow me and rotate plugin and open sketchup it gives me Error: SketchUp: 1: in `eval 'and the extension doesn't work. how can i use it?
                        @andrea1980 said:
                        how can i use it?
                        You'd need an old version of SketchUp. If you read a few posts up from yours you will see this plugin does not work with SketchUp 2017. It hasn't been supported for years. Best thing is to look for a different tool to do what you want.
                          andrea1980
                          do you know a plugin that has the same follow me and rotate functions for sketchup 2017?
                            Again, if you read the last few posts in this thread you can see that Pilou offered a possible alternative. There may be something else that could do what you are trying to do but you haven't told us that, yet. You could start a new thread in the Newbie category, share your model file and describe what it is you are trying to accomplish. We'll surely be able to give you guidance.
                              andrea1980
                              index1.jpgThanks Dave for your availability. I have to make a model similar to this in the photo. what can i use? https://youtu.be/rfWNn6Yfyhs?t=415
                                Helix along a curve by Albertsoft above don't work for the 2017 ?
                                Helix along curve 0.9
                                Support Sketchup 2017, 2016, 2015, 2014, 2013, 8 & 7
                                If you want see some examples without Plugins take a look at Kito Raupp πŸ˜‰
                                  andrea1980
                                  orecchini 3.pngorecchini 1.pngorecchini 2.pngThanks for the advice you have given me, with helix along curve I managed to draw what I wanted. Thanks
                                    Dancing things! β˜€
                                      RAVZ
                                      Hei, I am facing a problem regarding this plugin. When i installed it a load error is generated saying Error: sketchup:1:in 'eval'. Moreover, this plugin is not working. It is showing in "Extension" Tab but not working even after trying various permutations of usage. Please, rectify this error along with the specified glitch.
                                        If you read back through the last few pages of this thread you will see that this plugin does not work in SketchUp 2017 or later and is not supported anymore. Best to use some alternative. Pilou provided some options a few posts up from yours.
                                          RAVZ
                                          Thanks people for telling me that the plugin named "follow and rotate" doesn't work in SU17 and later versions. But anyone please enlighten us with the alternative(s) till the time author brings the updated version of FaR so that there is no lag in work. Thank You! πŸ˜„ πŸ˜„
                                            There is probably some other extension that will do what you need. Which one depends on exactly what you are trying to model.
                                            I wouldn't hold my breath. It's been years since the author made any updates to this extension. I think it's fairly safe to assume there won't be any.
                                            • 11
                                            • 10 / 11
