    [Plugin] Animator - v4.5a - 22 Jul 25
    renderpluginsextensions
    544 Posts 119 Posters 1.8m Views 119 Watching
    • fredo6F Offline
      @floorguy
      Strange, indeed.
      Could you post the model so that I have a look.
      Many thanks
      • F Offline
        Floorguy
        @fredo6 said:
        @floorguy
        Strange, indeed.
        Many thanks
        Here's a link to the Sketchup file Fredo. Thanks for looking.
        (drive.google.com)
        • soloS Offline
          Is Animator and Thea 1.5 still working? I cannot get them to work together, I tried both from Animator dialog and from the Thea window to render an animation to no avail.
          • fredo6F Offline
            Good you signal it.
            Something has changed in Thea 1.5, and the method for rendering does not work as it used to (you can see it in the Ruby console). This simply prevents the rendering from Animator with Thea. is ennoying and there is little I can do on my side.
            • soloS Offline
              I have informed Tomasz about this issue, hopefully, he will fix it. I hear that Animator works with Vray now, I did not see Vray in the options, Is there a tutorial for Animator and Vray? I may need to use this if Thea is not working anymore.
              • fredo6F Offline
                I sent a message to Tomas too.
                VRay is supported, but same thing happens with the most recent version (v1.6), where the API is less stable and can hang.
                More generally, there is not a lot of attention from rendering software companies to provide a stable and flexible API to use rendering from an external program (like Animator).
                • soloS Offline
                  That is too bad, so what do I do?
                  Here are the options I have available, SU native or Thea, now that we know Thea no longer works (sad news) when I install Vray it will show up as an option? but the newest version does not work? so I have to somehow find an earlier version?
                  Is there any other render engines that work with Animator?
                  • fredo6F Offline
                    Solo,
                    Twilight is also supported.
                    By the way, you really need to install ffmpeg in order to get the video files (mp4, mov, ...). Otherwise, you'll only get a sequence of png image files).
                    • fredo6F Offline
                      Apparently, based on Tomasz advice, the problem disappears with the latest version 1.5.09.547.
                      I uninstalled Thea and then installed this latest version and it works again.
                        Charlie__V
                        EDIT: Version# corrected.........thanks Fredo
                        ......... so I have to somehow find an earlier version?
                        Solo
                        Don’t know if this helps as I don’t know Thea’s last working version in Animator. (SU V1.5.09.547)
                        404 Page not found : downloads
                        (www.thearender.com)
                          Macho3001
                          Hi Fredo
                          I have just downloaded your wonderful plugin and specially like the detailed control over keyframes management (easing etc) and the ability to render animations on vray. However, you have not built support into it so as to be able to render animations outside of the local environment (ie, vray cloud for instance) as 99% of professional animation renderings happen over render farms and not on local systems. Vray cloud https://www.chaosgroup.com/vray/cloud is the new rendering platform by chaosgroup like other 3rd party render farms out there and currently is in beta, free for testers. We are trying it out, and it indeed is good.
                          Is it possible to export out Keyframes from Animator as Sketchup Scenes (complete with easing values etc), so that those may be given out to Vray Cloud? I am sure many architectural firms out there would want this feature. Thanks.
                          Ar. Nitin Sharma
                          3DA Architects
                          3DADS
                          'Leadership, by Design'
                          3rd Dimension, Architecture Design Studio
                          • fredo6F Offline
                            @macho3001 said:
                            Hi Fredo
                            Ar. Nitin Sharma
                            3DA Architects
                            Animator exposes an API for rendering software to batch the rendering from outside Animator. So far, only Theahas implemented it.
                            Generating scenes is not a solution, because you can only handle the movement of cameras, not objects.
                            • fredo6F Offline
                              New Release: Animator - v2.2c - 26 Aug 18
                              Requirement: LibFredo6 v8.5a
                              Minor release
                              • Extension of validity
                              • Fix a problem coming from using transparent move! for performance, signaled by ithil
                              See plugin home page of Animator for Download of RBZ from the PluginStore.
                              See Main Post of the Animator thread for more information.
                                Takkegek
                                Hi Fredo, I did some other tests with the plugin. But I was wondering, is it also possible to have a sun animation in these videos I made ( with thea render and animator ) ? So I want all the movement of the objects + sun animation ( from dusk till dawn for example), is this possible?
                                other little thing: there is 'no clip defined in model' when I want to start animation render in thea render sketchup ( not animator). Even if I have the license done. Rendering from animator is no problem though.
                                • fredo6F Offline
                                  Sun is supported (using Shadow Visual Effect). Just put two elements in the timeline with different dates and Animator will interpolate the shadows between the two.
                                  Fred
                                    Takkegek
                                    Thanks Fredo, I will try this!
                                      studzinski
                                      Hi, I have created a staging animation in SU for a construction of a metro station, an 8min video, approx. 160 scenes, showing how the station will be built from start to finish, with construction equipment, etc. I am looking for someone to turn this into a more photo realistic animation, add some movement to the construction equipment, etc. Animator seems like the right tool, though I have never used it myself. Is there someone that would be interested and had immediate availability to do this for me?
                                      Regards,
                                      Michal
                                        bulet
                                        Cannot find the explode function in the latest version.
                                        Please advise.
                                        • fredo6F Offline
                                          It is in the Movement palette
                                          • ArcA Offline
                                            Arc
                                            It is chinese translation, 100%.
                                            Animator_ZH.lang
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 28 / 28
