    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
    • soloS
      Is Animator and Thea 1.5 still working? I cannot get them to work together, I tried both from Animator dialog and from the Thea window to render an animation to no avail.
      • fredo6F
        Good you signal it.
        Something has changed in Thea 1.5, and the method for rendering does not work as it used to (you can see it in the Ruby console). This simply prevents the rendering from Animator with Thea. is ennoying and there is little I can do on my side.
        • soloS
          I have informed Tomasz about this issue, hopefully, he will fix it. I hear that Animator works with Vray now, I did not see Vray in the options, Is there a tutorial for Animator and Vray? I may need to use this if Thea is not working anymore.
          • fredo6F
            I sent a message to Tomas too.
            VRay is supported, but same thing happens with the most recent version (v1.6), where the API is less stable and can hang.
            More generally, there is not a lot of attention from rendering software companies to provide a stable and flexible API to use rendering from an external program (like Animator).
            • soloS
              That is too bad, so what do I do?
              Here are the options I have available, SU native or Thea, now that we know Thea no longer works (sad news) when I install Vray it will show up as an option? but the newest version does not work? so I have to somehow find an earlier version?
              Is there any other render engines that work with Animator?
              • fredo6F
                Solo,
                Twilight is also supported.
                By the way, you really need to install ffmpeg in order to get the video files (mp4, mov, ...). Otherwise, you'll only get a sequence of png image files).
                • fredo6F
                  Apparently, based on Tomasz advice, the problem disappears with the latest version 1.5.09.547.
                  I uninstalled Thea and then installed this latest version and it works again.
                  • C
                    Charlie__V
                    EDIT: Version# corrected.........thanks Fredo
                    ......... so I have to somehow find an earlier version?
                    Solo
                    Don’t know if this helps as I don’t know Thea’s last working version in Animator. (SU V1.5.09.547)
                    https://www.thearender.com/site/index.php/downloads
                      Macho3001
                      Hi Fredo
                      I have just downloaded your wonderful plugin and specially like the detailed control over keyframes management (easing etc) and the ability to render animations on vray. However, you have not built support into it so as to be able to render animations outside of the local environment (ie, vray cloud for instance) as 99% of professional animation renderings happen over render farms and not on local systems. Vray cloud https://www.chaosgroup.com/vray/cloud is the new rendering platform by chaosgroup like other 3rd party render farms out there and currently is in beta, free for testers. We are trying it out, and it indeed is good.
                      Is it possible to export out Keyframes from Animator as Sketchup Scenes (complete with easing values etc), so that those may be given out to Vray Cloud? I am sure many architectural firms out there would want this feature. Thanks.
                      Ar. Nitin Sharma
                      3DA Architects
                      3DADS
                      'Leadership, by Design'
                      3rd Dimension, Architecture Design Studio
                      • fredo6F
                        @macho3001 said:
                        Hi Fredo
                        Ar. Nitin Sharma
                        3DA Architects
                        Animator exposes an API for rendering software to batch the rendering from outside Animator. So far, only Theahas implemented it.
                        Generating scenes is not a solution, because you can only handle the movement of cameras, not objects.
                        • fredo6F
                          New Release: Animator - v2.2c - 26 Aug 18
                          Requirement: LibFredo6 v8.5a
                          Minor release
                          • Extension of validity
                          • Fix a problem coming from using transparent move! for performance, signaled by ithil
                          See plugin home page of Animator for Download of RBZ from the PluginStore.
                          See Main Post of the Animator thread for more information.
                          • T
                            Takkegek
                            Hi Fredo, I did some other tests with the plugin. But I was wondering, is it also possible to have a sun animation in these videos I made ( with thea render and animator ) ? So I want all the movement of the objects + sun animation ( from dusk till dawn for example), is this possible?
                            other little thing: there is 'no clip defined in model' when I want to start animation render in thea render sketchup ( not animator). Even if I have the license done. Rendering from animator is no problem though.
                            • fredo6F
                              Sun is supported (using Shadow Visual Effect). Just put two elements in the timeline with different dates and Animator will interpolate the shadows between the two.
                              Fred
                              • T
                                Takkegek
                                Thanks Fredo, I will try this!
                                  studzinski
                                  Hi, I have created a staging animation in SU for a construction of a metro station, an 8min video, approx. 160 scenes, showing how the station will be built from start to finish, with construction equipment, etc. I am looking for someone to turn this into a more photo realistic animation, add some movement to the construction equipment, etc. Animator seems like the right tool, though I have never used it myself. Is there someone that would be interested and had immediate availability to do this for me?
                                  Regards,
                                  Michal
                                  • B
                                    bulet
                                    Cannot find the explode function in the latest version.
                                    Please advise.
                                    • fredo6F
                                      It is in the Movement palette
                                      • ArcA
                                        Arc
                                        It is chinese translation, 100%.
                                        Animator_ZH.lang
                                        • B
                                          bulet
                                          [attachment=0:83dt0fyt]<!-- ia0 -->Animator explosion.png<!-- ia0 -->[/attachment:83dt0fyt]
                                          Thank you. Found it. Was a bit confused with the route.
                                          • V
                                            Valy2404
                                            Hi Fredo. when I export animation or render plugin writes that it needs a Pro version where I can fix it or buy a Pro version ?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 29
                                            • 30
                                            • 14 / 30
