    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
    • fredo6F
      Solo,
      Twilight is also supported.
      By the way, you really need to install ffmpeg in order to get the video files (mp4, mov, ...). Otherwise, you'll only get a sequence of png image files).
      • fredo6F
        Apparently, based on Tomasz advice, the problem disappears with the latest version 1.5.09.547.
        I uninstalled Thea and then installed this latest version and it works again.
        • C
          Charlie__V
          EDIT: Version# corrected.........thanks Fredo
          @solo said:
          That is too bad, so what do I do?
          ......... so I have to somehow find an earlier version?
          Solo
          Don’t know if this helps as I don’t know Thea’s last working version in Animator. (SU V1.5.09.547)
          https://www.thearender.com/site/index.php/downloads
            Macho3001
            Hi Fredo
            I have just downloaded your wonderful plugin and specially like the detailed control over keyframes management (easing etc) and the ability to render animations on vray. However, you have not built support into it so as to be able to render animations outside of the local environment (ie, vray cloud for instance) as 99% of professional animation renderings happen over render farms and not on local systems. Vray cloud https://www.chaosgroup.com/vray/cloud is the new rendering platform by chaosgroup like other 3rd party render farms out there and currently is in beta, free for testers. We are trying it out, and it indeed is good.
            Is it possible to export out Keyframes from Animator as Sketchup Scenes (complete with easing values etc), so that those may be given out to Vray Cloud? I am sure many architectural firms out there would want this feature. Thanks.
            Ar. Nitin Sharma
            3DA Architects
            3DADS
            'Leadership, by Design'
            3rd Dimension, Architecture Design Studio
            • fredo6F
              @macho3001 said:
              Hi Fredo
              Ar. Nitin Sharma
              3DA Architects
              Animator exposes an API for rendering software to batch the rendering from outside Animator. So far, only Theahas implemented it.
              Generating scenes is not a solution, because you can only handle the movement of cameras, not objects.
              • fredo6F
                New Release: Animator - v2.2c - 26 Aug 18
                Requirement: LibFredo6 v8.5a
                Minor release
                • Extension of validity
                • Fix a problem coming from using transparent move! for performance, signaled by ithil
                See plugin home page of Animator for Download of RBZ from the PluginStore.
                See Main Post of the Animator thread for more information.
                • T
                  Takkegek
                  Hi Fredo, I did some other tests with the plugin. But I was wondering, is it also possible to have a sun animation in these videos I made ( with thea render and animator ) ? So I want all the movement of the objects + sun animation ( from dusk till dawn for example), is this possible?
                  other little thing: there is 'no clip defined in model' when I want to start animation render in thea render sketchup ( not animator). Even if I have the license done. Rendering from animator is no problem though.
                  • fredo6F
                    Sun is supported (using Shadow Visual Effect). Just put two elements in the timeline with different dates and Animator will interpolate the shadows between the two.
                    Fred
                    • T
                      Takkegek
                      Thanks Fredo, I will try this!
                        studzinski
                        Hi, I have created a staging animation in SU for a construction of a metro station, an 8min video, approx. 160 scenes, showing how the station will be built from start to finish, with construction equipment, etc. I am looking for someone to turn this into a more photo realistic animation, add some movement to the construction equipment, etc. Animator seems like the right tool, though I have never used it myself. Is there someone that would be interested and had immediate availability to do this for me?
                        Regards,
                        Michal
                        • B
                          bulet
                          Cannot find the explode function in the latest version.
                          Please advise.
                          • fredo6F
                            It is in the Movement palette
                            • ArcA
                              Arc
                              It is chinese translation, 100%.
                              Animator_ZH.lang
                              • B
                                bulet
                                [attachment=0:83dt0fyt]<!-- ia0 -->Animator explosion.png<!-- ia0 -->[/attachment:83dt0fyt]
                                Thank you. Found it. Was a bit confused with the route.
                                • V
                                  Valy2404
                                  Hi Fredo. when I export animation or render plugin writes that it needs a Pro version where I can fix it or buy a Pro version ?
                                  • V
                                    Valy2404
                                    • fredo6F
                                      New Release: Animator - v2.3a - 14 Nov 18
                                      Requirement: LibFredo6 v8.6k
                                      Minor release
                                      • Mouse Wheel can now be used for scrolling on Mac platforms
                                      • Various bug fixing
                                      • P
                                        palphd
                                        Hi Fredo,
                                        Is there an option for achieving transparent backgrounds when generating a video as an images sequence (PNGs)?
                                        Cheers,
                                        • fredo6F
                                          Good point. I have to test, but it should be possible. I'll have to add the option in the GUI too.
                                          • P
                                            palphd
                                            @fredo6 said:
                                            Thanks so much for the reply! Animator is such a fantastic plugin, but I was going insane trying to find that option since MSPhysics and ClothWorks have it. Adding it to Animator will truly complete the SketchUp animation trifecta as far as I'm concerned.
                                            Good luck and thanks again! 👍 I'll stay tuned 😎
                                            Cheers,
                                            Chris*
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 29
                                            • 30
                                            • 15 / 30
