    [Plugin][$] TopoShaper - v2.7a - 01 Apr 24
    455 Posts 144 Posters 695.1k Views 143 Watching
      clement duvoux
      Bonjour Fredo,
      Après installation de la dernière version de Toposhaper (2.3b) et de LibFredo6 v8.1h, Toposhaper ne s'execute pas à l'ouverture de Sketchup, renvoyant un message d'erreur qui est le suivant : "you must install LibFredo6 to run Toposhaper
      Open the download page of LibFredo6 at https....".
      Après vérification dans l'extension manager, LibFredo est pourtant bien installé. Une idée sur l'origine du bug ?
      • fredo6F Offline
        @clement duvoux said:
        Bonjour Fredo,
        Il faut verifier que LibFredo6 est bien chargé. Est ce qu'il y a un menu Window > LibFredo6 Settings.... ?
          gio
          @pixero said:
          I was wondering if there is a limit to how detailed a ISO lines terrain can be to work with Toposhaper?
          As you can see in the attached image only a part of the terrain is created. If I try with a less dense contour file of the same area it works but I need the detail as high as possible.
          [attachment=0:1bzib748]<!-- ia0 -->screenshot.jpg<!-- ia0 -->[/attachment:1bzib748]
          Maybe you can make just smaller portions and join them in the end?
          Gio
            dlannetts
            Hello,
            Great plugin, however I am having an issue, after generating the terrain from guide points, using the toolbar, and clicking off elsewhere, the toolbar disappears and I can't seem to get it back to modify the terrain. How can I get the toolbar back after it has disappeared?
            David.
            • fredo6F Offline
              @dlannetts said:
              Hello,
              David.
              Can you open the Ruby console, as there may be an error.
              Did the terrain generate correctly by the way?
                simonhaufe
                I just try TopoShaper with a point cloud with more than 130.000 points out of a ASCII-File. How I can import it in SU and make any kind of terrain model?
                Any ideas and suggestions are most welcome!! 😎 ☀
                Best Regards Simon
                • fredo6F Offline
                  Best Regards Simon
                  I don't think TopoShaper can handle 130,000 points; and I don't think either that Sketchup will not scream with a mesh of 130,000 vertices.
                  So you'll probably have to find a way, with other tools to simplify the input points or raw mesh, either simplifying, or cutting in pieces if the cloud covers a very large area. I don't know if there are Ruby scripts in Sketchup to do that, but I know there are specialized terrain software that can do it. There are several discussion threads in Sketchucation and Sketchup forums about terrains.
                    rspierenburg
                    I'm trying to use Toposhaper to create a topo from points. I have points selected and when I run the plugin all I get is a blank error.
                    Toposhaper Error
                    • fredo6F Offline
                      It would be helpful that you attach your model so that I can investigate. Thanks.
                        rspierenburg
                        Thanks, Here is the model.
                        Topography.skp
                        • fredo6F Offline
                          @Rspierenburg
                          You just need to put all contruction points and the contour within a Group, then select the group and run TopoShaper Cloud.
                          Note that your model seems to have some points which create peaks.
                          Rspierenburg - Topography - SU2015.skp
                            Anastasia_0111
                            What can be the reason of such error of TopoShaper?
                            It appears on SketchUp17 and 18, if I try very simple terrain, just of 2 or 3 curves.
                              Put your SKP, that can be helping! 😉
                              Save as V6 for a more large audience! 😉
                                Anastasia_0111
                                As I said it happens in any file, just if I try to create a terrain from 2 simple curves drawn by "freehand".
                                This is a full text of the error:
                                body_lib6g6.rbe
                                2254
                                block in proximity_point_curve_by_circle
                                body_lib6g6.rbe
                                2249
                                each
                                body_lib6g6.rbe
                                2249
                                toposhaperalgo.rbe
                                2419
                                block in altitude_at_point
                                toposhaperalgo.rbe
                                2417
                                each
                                toposhaperalgo.rbe
                                2417
                                altitude_at_point
                                toposhaperalgo.rbe
                                2390
                                altitude_multi
                                toposhaperalgo.rbe
                                427
                                block in top_processing
                                toposhaperalgo.rbe
                                425
                                each
                                toposhaperalgo.rbe
                                425
                                each_with_index
                                toposhaperalgo.rbe
                                425
                                top_processing
                                toposhapertool.rbe
                                574
                                algo_processing
                                toposhapertool.rbe
                                666
                                execute_validate
                                toposhaperpalette.rbe
                                130
                                execute_from_palette
                                76
                                notify_from_palette
                                518
                                call
                                518
                                block (2 levels) in palette_validate
                                body_lib6palette.rbe
                                3596
                                call
                                3596
                                execute_button
                                3401
                                onLButtonUp
                                lib6palette.rbe
                                91
                                onLButtonUp
                                toposhapertool.rbe
                                984
                                onLButtonUp
                                • fredo6F Offline
                                  @Anastasia_0111
                                  Could you indicate the text of the error (just just give the files and line numbers), as well as post one of this simple model with free-hand drawn curve.
                                  Many thanks
                                    peggy1124
                                    Thank you Fredo
                                    amazing plugin
                                      Keniff
                                      Hi, Can't get this to work on my Mac. Using the supplied 'test' SKP file I either get a full on program bug splat! a non contoured output, just the shape of the face or the attached useless error message:
                                      Any help appreciated
                                        Keniff
                                        Hi, Finally got this working on my mac after I realised that it worked on a group rather than selecting points (contrary to some vids I've watched) However, now I've got it working the results I've got are not using all the cloud points in the group. Therefore the result is very "pointy" Any help appreciated
                                        • fredo6F Offline
                                          Very difficult to help if you do not post the model
                                            akaraphon
                                            hi fredo btw this plugin is very useful but i have some question . i want to create full area terrain but this is what i got . could you help me what i have to do
                                            ps. thank you
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
