[Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
@peerman said:
Edit: OK, after replacing the chromium app with the latest from chromium.org the viewport is working!
Next PBR plugin version will include latest Chromium macOS stable version.
So I played around with it a bit. A couple of things I noticed. The suns position doesn't get exported and the UVs aren't coming through correct.
I've added a screenshot. The house is exploded (was a component) but that didn't help.
It looks promising!Best,
Peter
@peerman said:
[...] the UVs aren't coming through correct. [...]
This is a known issue and there is a workaround.
Texture looks weird with perpendicular lines around.
With your preferred photo editing software, resize texture image to a power of 2 in height and width (e.g. 1024x2048, 2048x2048, 4096x4096). Reimport texture image in SketchUp.
Source: https://github.com/SamuelTS/SketchUp-PBR-Plugin/blob/master/docs/help.md#in-pbr-viewport
Ah thank you! I should've read the documentation better...
I will try it again.Best,
No problem, Peter.
Best regards,
Samuel
v1.3.5 of PBR plugin has just been released.
Enhance macOS support.
Upgrade Chromium browsers.
Update sunlight direction. Beta
Add two materials to library.
Clarify menu and Viewport UI.
Fix camera's orbit control damping.
PBR plugin v1.3.6 includes a library of 73 materials!
Most have been converted from texturehaven.com.
All these materials contain at least one normal map. -
The next PBR plugin version will include a virtual atmosphere (sun and stars). Demonstration:
PBR plugin v1.4.0 is out!
What's new?
- You can change sun elevation in Viewport. Sun and stars rise.
- You can save image in Viewport just by clicking on camera icon.
- Hold mouse middle button to zoom more quickly in Viewport!
- You can enter VR mode in Viewport — if you own a VR headset.
- You can't change environment map from menu anymore. Sorry.
- Material Library includes 79 materials! Thanks to Texture Haven.
PBR plugin v1.4.1 is out.
- Enhances Material Editor UX.
- Library includes 82 materials.
Great stuff! Just found out about this plugin. Look forward to trying it
Thank you!
The latest PBR plugin version (downloadable here) includes a toolbar
and one more material. -
PBR plugin v1.4.3 :
- Checks required plugin.
- Externalizes material lib.
I'm happy to announce that PBR plugin is now available through the SketchUcation PluginStore.
v1.4.5 of PBR plugin fixes a light exposure issue in Viewport.
Material Library of PBR plugin includes 100 materials --> Direct link to download it.
I've downloaded the plugin and seems successfully installed but I'm unable to get a viewport to open. I've applied a PBR material and click on Reopen Viewport from the toolbar. I get a dialog box with "Propagate materials to whole model (Recommended)". Whether I select Yes or No, nothing happens. It's likely I'm not following the correct procedure?
