[Plugin Library] LibFredo6 - v14.6a - 18 Sep 24
Well, I believe I have some insight into the problems I have been having with loading .rbe files. Unfortunately my hard drive boot sector failed horribly, so I was forced to replace the disk in my laptop. With a fresh install of Windows 10 including all updates, I installed nothing to the system except SU 2016 as Administrator. I downloaded the latest version of Fredo6, Animator, RoundCorner and installed them using Windows>Preferences, restarted SU and all plug-ins loaded perfectly. So there was something seriously wrong with my system somewhere. In the process of reinstalling all necessary programs and will be restarting SU after each install to verify that nothing screws up SU.
Glad this now works for you.
Hello and thank you for your work.
recently, no more of your plugin works. the tools appear but have no effect.
I updated, uninstalled and reinstalled libfredo6, but it still does not work.
I downloaded other plugin not coming from you and they work perfectly.
I tested on SU 2016 and 2017.
if anyone has a solution I am interested.thank you
Could you open the Ruby console and see if there are error messages when you launch a plugin.
yes i have this error message : Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/olf/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:ininitialize' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in
open'
c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:inwrite_to_file' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:127:in
store'
c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1219:inusage_use' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1207:in
command_invoke'
c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1190:inblock (2 levels) in build_config_commands' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1339:in
call'
c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1339:inblock in add_command' SketchUp:1:in
call'thanks
The error relates to permissions for writing to a data file:
To me this suggests that you might have installed SketchUp incorrectly.
For the avoidance of doubt here is the only proper way [you probably don't need to uninstall and reinstall...]
Close SketchUp.
Whilst logged in as your normal user-account [olf ?], find the v2017 SketchUp installer exe file.
It's probably in your Downloads folder ?
Select its icon, right-click > context-menu > "Run as administrator"
When offered the option choose 'Repair' [on a new installation choose 'Install'].When it completes retry.
If the error persists then the permissions are still awry, so try deleting the folder:
When SketchUp next loads it should remake the folders and files - hopefully, this time with proper permissions ? -
the first solution did not work. but as soon as I removed the folder LIBFREDO6_DATA_Dir I found the functionality of all your plugin.
thanks for your help
NEW RELEASE: LibFredo6 v8.3a - 07 May 18
LibFredo6 8.3a is a major release supporting Animator 2.0 (look and feel and functionality).
Hi, I updated the Spanish language file for LibFredo6-v8.3a, here the file:
Thank you very much.
I included it in LibFredo6 distribution. So it will be part of the next release.Fredo
NEW RELEASE: LibFredo6 v8.4a - 20 May 18
LibFredo6 8.4a is a major release supporting Animator 2.1 (Movement Apparition).
NEW RELEASE: LibFredo6 v8.4c - 21 May 18
LibFredo6 8.4c is an update to bring adjustments to Animator 2.1 (Movement Apparition, with sliding boundaries).
Getting the following error message when I open some drawing files but not all. This is with the updated v8.4c
Error: #<ArgumentError: wrong number of arguments (0 for 1)>
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:158:ininitialize' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in
new'
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:inshow' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:66:in
time_for_check?'
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:377:inblock in after_startup' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:in
call'
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:inis_online' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:in
initialize'
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:1054:innew' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:1054:in
<main>'
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:ineval' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:in
require'
c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:in<main>' C:/PROGRA~1/SketchUp/SKETCH~3/Tools/extensions.rb:197:in
eval'
C:/PROGRA~1/SketchUp/SKETCH~3/Tools/extensions.rb:197:inrequire' C:/PROGRA~1/SketchUp/SKETCH~3/Tools/extensions.rb:197:in
load'
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/su_dynamiccomponents.rb:47:inregister_extension' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/su_dynamiccomponents.rb:47:in
<top (required)>'Any help would be appreciated
NEW RELEASE: LibFredo6 v8.4d - 21 May 18
LibFredo6 8.4d fixes a bug in the periodic popup for Check For Update. So the errors happens by default every 15 days.
By the way, the new popup has changed, replacing the old single Ruby picture window.
Thanks for signaling. This is a small bug in the periodic popup prompting for a Check for Update.
This is fixed in v8.4d, just published.
I use Sketchup 2017.
Why LibFredo6 not work. -
NEW RELEASE: LibFredo6 v8.4e - 28 May 18
LibFredo6 8.4e fixes a bug related to text selection in some web dialog boxes
Merci Fredo
La version v8.4e de Lib Fredo6 corrige effectivement les petits problèmes rencontrés lors de la sélection de texte des outils "volumes Solides" et "Étiqueter les surfaces". -
Hi Fredo, please, how to install LibFredo to a different folder? I have installed the AdditionalPluginFolder, created another folder for plugins, but a guess I need .zip file to install LibFredo6 to that folder. I can see only .rbz file in download and I don't know, how to change destination plugin folder in Sketchup 2018 extention manager. Thanx for help!
