    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.9m Views 589 Watching
      I know Fredo has an urgent call out to the SketchUp guys, about this very problem, which seems to be affecting just a few users, and where a proper installation etc fails to resolve these issues...
      • fredo6F
        I got an answer from thomthom recommending to upgrade to the latest version of SU2016.
          mgfranz
          I'm already running SketchUpPro-2016-1-1449-80430-en-x64.exe, any other ideas?
          "If you like what you do, it will never be work..."
          In memory of Sam Maloof, 1916-2009
          • itcamposI
            itcampos
            Don't know why, but this version just won't work, same error encountered by @mgfranz =\ Only difference is that I'm using SU2017.
            I had to uninstall and reinstall an older version (8.0c, which is the only one not too old I could find).
            Would anybody provide a link with the 8.1c ~ 8.1f versions so I can run a few tests?
            Thx!
              Have you installed or repaired your SketchUp by selecting the installer exe file's icon, and
              right-click > Run as administrator ?
              • itcamposI
                itcampos
                Yes, I uninstalled and deleted every folder from SU2017, then reinstalled as admin (which I know I already did in the first time), but the problem persisted. So far, the only solution I found was using the 8.0c and pray the next release works for me
                  mgfranz
                  Thx!
                  Where did you find a version 8.0c?
                  • itcamposI
                    itcampos
                    Thx!
                    I took me a while, I thought it would be faster to upload it than find it again, so there you go: https://mega.nz/#!k9sHjZaY!EzgYiDAO-1mfHwFd1gpn9ljszYBvgaimWT7rVs3NTcY
                    • fredo6F
                      NEW RELEASE: LibFredo6 v8.1h - 06 Apr 18
                      LibFredo6 8.1h is a maintenance release fixing a bug in Scaling flat shapes in Animator.
                        mgfranz
                        Well, I believe I have some insight into the problems I have been having with loading .rbe files. Unfortunately my hard drive boot sector failed horribly, so I was forced to replace the disk in my laptop. With a fresh install of Windows 10 including all updates, I installed nothing to the system except SU 2016 as Administrator. I downloaded the latest version of Fredo6, Animator, RoundCorner and installed them using Windows>Preferences, restarted SU and all plug-ins loaded perfectly. So there was something seriously wrong with my system somewhere. In the process of reinstalling all necessary programs and will be restarting SU after each install to verify that nothing screws up SU.
                        • fredo6F
                          Glad this now works for you.
                          • olfactifO
                            olfactif
                            Hello and thank you for your work.
                            recently, no more of your plugin works. the tools appear but have no effect.
                            I updated, uninstalled and reinstalled libfredo6, but it still does not work.
                            I downloaded other plugin not coming from you and they work perfectly.
                            I tested on SU 2016 and 2017.
                            if anyone has a solution I am interested.
                            thank you
                            • fredo6F
                              thank you
                              Could you open the Ruby console and see if there are error messages when you launch a plugin.
                              • olfactifO
                                olfactif
                                yes i have this error message : Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/olf/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
                                c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in initialize' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in open'
                                c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in write_to_file' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:127:in store'
                                c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1219:in usage_use' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1207:in command_invoke'
                                c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1190:in block (2 levels) in build_config_commands' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1339:in call'
                                c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1339:in block in add_command' SketchUp:1:in call'
                                thanks
                                  The error relates to permissions for writing to a data file:
                                  To me this suggests that you might have installed SketchUp incorrectly.
                                  For the avoidance of doubt here is the only proper way [you probably don't need to uninstall and reinstall...]
                                  Close SketchUp.
                                  Whilst logged in as your normal user-account [olf ?], find the v2017 SketchUp installer exe file.
                                  It's probably in your Downloads folder ?
                                  Select its icon, right-click > context-menu > "Run as administrator"
                                  When offered the option choose 'Repair' [on a new installation choose 'Install'].
                                  When it completes retry.
                                  If the error persists then the permissions are still awry, so try deleting the folder:
                                  When SketchUp next loads it should remake the folders and files - hopefully, this time with proper permissions ?
                                  • olfactifO
                                    olfactif
                                    the first solution did not work. but as soon as I removed the folder LIBFREDO6_DATA_Dir I found the functionality of all your plugin.
                                    thanks for your help
                                    • fredo6F
                                      NEW RELEASE: LibFredo6 v8.3a - 07 May 18
                                      LibFredo6 8.3a is a major release supporting Animator 2.0 (look and feel and functionality).
                                      • OxerO
                                        Oxer
                                        Hi, I updated the Spanish language file for LibFredo6-v8.3a, here the file:
                                        • fredo6F
                                          Thank you very much.
                                          I included it in LibFredo6 distribution. So it will be part of the next release.
                                          • fredo6F
                                            NEW RELEASE: LibFredo6 v8.4a - 20 May 18
                                            LibFredo6 8.4a is a major release supporting Animator 2.1 (Movement Apparition).
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 113
                                            • 114
                                            • 65 / 114
