    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.9m Views 589 Watching
    • fredo6F
      @oxer said:
      Hi, I updated the Spanish language file for LibFredo6-v8.3a, here the file:
      Thank you very much.
      I included it in LibFredo6 distribution. So it will be part of the next release.
      • fredo6F
        NEW RELEASE: LibFredo6 v8.4a - 20 May 18
        LibFredo6 8.4a is a major release supporting Animator 2.1 (Movement Apparition).
        • fredo6F
          NEW RELEASE: LibFredo6 v8.4c - 21 May 18
          LibFredo6 8.4c is an update to bring adjustments to Animator 2.1 (Movement Apparition, with sliding boundaries).
            RubenB
            Getting the following error message when I open some drawing files but not all. This is with the updated v8.4c
            Error: #<ArgumentError: wrong number of arguments (0 for 1)>
            c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:158:in initialize' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in new'
            c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in show' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:66:in time_for_check?'
            c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:377:in block in after_startup' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:in call'
            c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:in is_online' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:in initialize'
            c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:1054:in new' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:1054:in <main>'
            c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:in eval' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:in require'
            c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:in <main>' C:/PROGRA~1/SketchUp/SKETCH~3/Tools/extensions.rb:197:in eval'
            C:/PROGRA~1/SketchUp/SKETCH~3/Tools/extensions.rb:197:in require' C:/PROGRA~1/SketchUp/SKETCH~3/Tools/extensions.rb:197:in load'
            C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/su_dynamiccomponents.rb:47:in register_extension' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/su_dynamiccomponents.rb:47:in <top (required)>'
            Any help would be appreciated
            • fredo6F
              NEW RELEASE: LibFredo6 v8.4d - 21 May 18
              LibFredo6 8.4d fixes a bug in the periodic popup for Check For Update. So the errors happens by default every 15 days.
              By the way, the new popup has changed, replacing the old single Ruby picture window.
              • fredo6F
                @RubenB
                Thanks for signaling. This is a small bug in the periodic popup prompting for a Check for Update.
                This is fixed in v8.4d, just published.
                • P
                  peuluang
                  I use Sketchup 2017.
                  Why LibFredo6 not work.
                    What makes you think it doesn't work?
                    • fredo6F
                      NEW RELEASE: LibFredo6 v8.4e - 28 May 18
                      LibFredo6 8.4e fixes a bug related to text selection in some web dialog boxes
                      • B
                        bharralure
                        Merci Fredo
                        La version v8.4e de Lib Fredo6 corrige effectivement les petits problèmes rencontrés lors de la sélection de texte des outils "volumes Solides" et "Étiqueter les surfaces".
                        • K
                          kejtrin
                          Hi Fredo, please, how to install LibFredo to a different folder? I have installed the AdditionalPluginFolder, created another folder for plugins, but a guess I need .zip file to install LibFredo6 to that folder. I can see only .rbz file in download and I don't know, how to change destination plugin folder in Sketchup 2018 extention manager. Thanx for help!
                          • fredo6F
                            NEW RELEASE: LibFredo6 v8.4f - 29 May 18
                            LibFredo6 8.4f fixes a bug that prevented to launch the video generation in Animator
                            • fredo6F
                              Unfortunately the native Extension Manager of Sketchup does not propose alternate directories.
                              The Sketchucation PluginStore does and should be the solution for your configuration.
                              Otherwise, you have to rename the rbz as .zip, and then extract the file and folder manually in the alternate directory.
                              • G
                                gaetane74
                                Hi Fredo, ou Bonjour Fredo
                                Depuis que j'ai réinstaller Sketchup je ne peux plus installer tes plugins… j'ai ce message à l'ouverture
                                Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                                Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in match' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in block (2 levels) in load_from_config'
                                c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:804:in each' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:804:in block in load_from_config'
                                c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:802:in foreach' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:802:in load_from_config'
                                c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1216:in block in load_all_plugins' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1216:in each'
                                c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1216:in load_all_plugins' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:245:in startup'
                                C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Erreur de chargement du fichier Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                                C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                                C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
                                C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>' Erreur de chargement du fichier Fredo6_RoundCorner.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                                C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in module:Fredo6'
                                C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'
                                Merci de ton aide
                                • fredo6F
                                  Merci de ton aide
                                  The best would be to clean up and reinstall LibFredo6.
                                    jjbrown
                                    Hi everyone. I am new to Fredo. I have been trying to load this all day with no luck. I am running SU on Mac iOS 10.11.06 it downloads finn in my browser but then trys to open in the extension warehouse an just gets stuck ... says ' loading ' an dose nothing. ive eeven tried loading it to SU 2017 with the same result ... PLEASE HELP 😞
                                    • fredo6F
                                      NEW RELEASE: LibFredo6 v8.4g - 10 Jun 18
                                      LibFredo6 8.4g fixes a bug that prevented to locate the program FFmpeg in Animator
                                        jjbrown
                                        hi, ive tried to install libfredo6 a million times with no luck ,,, the Sketchup Extension Manager just keeps saying loading an dose nothing ... im running OSX 10.13.3n
                                        PLEASE HELP
                                          jjbrown
                                          HI, IM HAVING THE SAME ISSUE ,,, DID YIOU RESOLVE THE ISSE ??? ANY ADVICE WOULD BE MUCH HELP AN appreciated 😄
                                          • fredo6F
                                            @jjbrown,
                                            Where did you get the RBZ from for LibFredo6 ?
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 113
                                            • 114
                                            • 66 / 114
