    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v8.1h - 06 Apr 18
      LibFredo6 8.1h is a maintenance release fixing a bug in Scaling flat shapes in Animator.
        mgfranz
        Well, I believe I have some insight into the problems I have been having with loading .rbe files. Unfortunately my hard drive boot sector failed horribly, so I was forced to replace the disk in my laptop. With a fresh install of Windows 10 including all updates, I installed nothing to the system except SU 2016 as Administrator. I downloaded the latest version of Fredo6, Animator, RoundCorner and installed them using Windows>Preferences, restarted SU and all plug-ins loaded perfectly. So there was something seriously wrong with my system somewhere. In the process of reinstalling all necessary programs and will be restarting SU after each install to verify that nothing screws up SU.
        "If you like what you do, it will never be work..."
        In memory of Sam Maloof, 1916-2009
        • fredo6F Offline
          Glad this now works for you.
          • olfactifO Offline
            olfactif
            Hello and thank you for your work.
            recently, no more of your plugin works. the tools appear but have no effect.
            I updated, uninstalled and reinstalled libfredo6, but it still does not work.
            I downloaded other plugin not coming from you and they work perfectly.
            I tested on SU 2016 and 2017.
            if anyone has a solution I am interested.
            thank you
            • fredo6F Offline
              thank you
              Could you open the Ruby console and see if there are error messages when you launch a plugin.
              • olfactifO Offline
                olfactif
                yes i have this error message : Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/olf/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
                c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in initialize' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in open'
                c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in write_to_file' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:127:in store'
                c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1219:in usage_use' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1207:in command_invoke'
                c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1190:in block (2 levels) in build_config_commands' c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1339:in call'
                c:/users/olf/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1339:in block in add_command' SketchUp:1:in call'
                thanks
                  The error relates to permissions for writing to a data file:
                  To me this suggests that you might have installed SketchUp incorrectly.
                  For the avoidance of doubt here is the only proper way [you probably don't need to uninstall and reinstall...]
                  Close SketchUp.
                  Whilst logged in as your normal user-account [olf ?], find the v2017 SketchUp installer exe file.
                  It's probably in your Downloads folder ?
                  Select its icon, right-click > context-menu > "Run as administrator"
                  When offered the option choose 'Repair' [on a new installation choose 'Install'].
                  When it completes retry.
                  If the error persists then the permissions are still awry, so try deleting the folder:
                  When SketchUp next loads it should remake the folders and files - hopefully, this time with proper permissions ?
                  • olfactifO Offline
                    olfactif
                    the first solution did not work. but as soon as I removed the folder LIBFREDO6_DATA_Dir I found the functionality of all your plugin.
                    thanks for your help
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v8.3a - 07 May 18
                      LibFredo6 8.3a is a major release supporting Animator 2.0 (look and feel and functionality).
                      • OxerO Offline
                        Oxer
                        Hi, I updated the Spanish language file for LibFredo6-v8.3a, here the file:
                        • fredo6F Offline
                          Thank you very much.
                          I included it in LibFredo6 distribution. So it will be part of the next release.
                          • fredo6F Offline
                            NEW RELEASE: LibFredo6 v8.4a - 20 May 18
                            LibFredo6 8.4a is a major release supporting Animator 2.1 (Movement Apparition).
                            • fredo6F Offline
                              NEW RELEASE: LibFredo6 v8.4c - 21 May 18
                              LibFredo6 8.4c is an update to bring adjustments to Animator 2.1 (Movement Apparition, with sliding boundaries).
                                RubenB
                                Getting the following error message when I open some drawing files but not all. This is with the updated v8.4c
                                Error: #<ArgumentError: wrong number of arguments (0 for 1)>
                                c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:158:in initialize' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in new'
                                c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in show' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:66:in time_for_check?'
                                c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:377:in block in after_startup' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:in call'
                                c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:in is_online' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:175:in initialize'
                                c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:1054:in new' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbe:1054:in <main>'
                                c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:in eval' c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:in require'
                                c:/users/user/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/su_dynamiccomponents/ruby/dcloader.rbe:16:in <main>' C:/PROGRA~1/SketchUp/SKETCH~3/Tools/extensions.rb:197:in eval'
                                C:/PROGRA~1/SketchUp/SKETCH~3/Tools/extensions.rb:197:in require' C:/PROGRA~1/SketchUp/SKETCH~3/Tools/extensions.rb:197:in load'
                                C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/su_dynamiccomponents.rb:47:in register_extension' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/su_dynamiccomponents.rb:47:in <top (required)>'
                                Any help would be appreciated
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v8.4d - 21 May 18
                                  LibFredo6 8.4d fixes a bug in the periodic popup for Check For Update. So the errors happens by default every 15 days.
                                  By the way, the new popup has changed, replacing the old single Ruby picture window.
                                  • fredo6F Offline
                                    @RubenB
                                    Thanks for signaling. This is a small bug in the periodic popup prompting for a Check for Update.
                                    This is fixed in v8.4d, just published.
                                      peuluang
                                      I use Sketchup 2017.
                                      Why LibFredo6 not work.
                                        What makes you think it doesn't work?
                                        • fredo6F Offline
                                          NEW RELEASE: LibFredo6 v8.4e - 28 May 18
                                          LibFredo6 8.4e fixes a bug related to text selection in some web dialog boxes
                                            bharralure
                                            Merci Fredo
                                            La version v8.4e de Lib Fredo6 corrige effectivement les petits problèmes rencontrés lors de la sélection de texte des outils "volumes Solides" et "Étiqueter les surfaces".
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 109
                                            • 110
                                            • 57 / 110
