    Toolbar Icon Size on 4K Monitor
    41 Posts 10 Posters 11.5k Views 10 Watching
      slbaumgartner
      @bob james said:
      Thank you, slbaumgartner
      Would you tell me how to use this for each plugin extension?
      If you're not familiar with Ruby API programming for SketchUp, you might be in over your head as the code needs to be adapted to each specific extension, there is no universal drop-in-place form.
      You need to create the appropriate icon files (svg, pdf, and png) for the extension and put them in the extension's folder. Then you need to find where in the extension's code it creates and populates its toolbar and integrate my snippet with whatever the original code does there, which will almost surely vary from case to case.
      • fredo6F
        For inof, all my plugins can support PNG, SVG and PDF (as everything is managed by LibFredo6).
        I am just missing the icons in SVG / PDF
        That's just a matter to put the SVG / PDF file in:
        • subfolder IMAGES_Standards of the plugin folder (say Fredo6_FredoScale/IMAGES_standard)
        • respecting convention: same name as PNG but removing the trailing _24 (or _16 or _32). So FSC_icon_Scale_24.png would become FSC_icon_Scale.svg
        • PixeroP
          Pixero
          Question. Does the svg/PDF icons need to be made in a special size? (I know they are scaleable just wondering if the dokument size should be anything special.)
            slbaumgartner
            You can draw the icon artwork at whatever size you wish. The view of the contents will be scaled to fit the available space in the toolbar button, so the physical size you drew is irrelevant. But you do need to verify that you haven't put details into the artwork that won't be visible when scaled to a typical toolbar button on a particular size display. Since you probably don't have a lot of different displays available to test, the best practice is to keep your icons fairly simple.
            One precaution though: Whatever size you draw, you should keep the drawing canvas square. Otherwise SketchUp will scale it based on the larger dimension and it won't fill the full button in the other direction.
            • Bob JamesB
              Bob James
              Awesome!!
              Do I have to re-draw them? Can't I just continue converting them from jpg/png to svg?
                slbaumgartner
                You can convert png or jpg to svg or pdf, but since the content is a raster image it most likely won't look good when scaled. The contents need to be vector to scale cleanly.
                • Paul RussamP
                  Paul Russam
                  PNG and JPG are raster images whilst SVG is a vector, Whilst you can save a raster image as an SVG its a complete waste of time as it will remain a raster image but it'll be encoded in XML and be substantially larger (file size) than the original.
                  To create proper SVG's you need a vector app such as Adobe Illustrator, Affinity Designer etc. Photoshop (raster app) will NOT create proper SVG's
                  SVG's are size independent, they will look no better or worse if you create them on a 10000x10000px canvas or a 100x100 one and dpi is irrelevant outside of the paper print industry for any image be it JPG, PNG or especially SVG.
                  I've attached a zip file containing 2 SVG's, one is a logo I did recently (lei-logo-pt1-colour.svg) in Affinity Designer. If you look at it in a text editor you'll see its just a simple set of instructions in XML defining an elements shape/fill/border etc.
                  The other is an SVG I hand wrote for fun (SolarSys-V4.svg), as it's handwritten it's far clearer to see the XML structure ... and it's animated ๐Ÿ˜„
                  TL;DR
                  Don't convert PNG/JPG to SVG, make them from scratch.
                  sample svgs.zip
                  Paul Russam
                  English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                  • dereiD
                    derei
                    Inkscape has a feature to vectorize a bitmap (Trace Bitmap) and it can be used to quickly convert some icons, provided you have a decent quality of the raster image.
                    You can try with small icons, but I doubt there will be enough resolution in them to get a decent result. See attached.
                    However, with a decent quality image, the results can be impressive.
                    DESIGNER AND ARTIST DEREI.UK
                    • Bob JamesB
                      Bob James
                      Miracle ๐Ÿ˜ฎ
                      With the latest Win10 update all icons are now full size!!! Not to look a gift horse in the mouth but now I wish I could make them a bit smaller ๐Ÿ˜Ž
                      Has this happened to anyone else?
                      • Bob JamesB
                        Bob James
                        UPDATE
                        Updated Nvidia driver from 391.35 to 397.31 and all of the non-svg icons went back to tiny. ๐Ÿ˜ž
                        • jujuJ
                          juju
                          @bob james said:
                          UPDATE
                          Are you sure the screen resolution was set correctly by the previous driver when you did that update?
                          • Bob JamesB
                            Bob James
                            No way to know now unless I go back to 391.35. Resolution is set at its recommended value.
                            • Bob JamesB
                              Bob James
                              UPDATE
                              I re-loaded the latest Nvidia driver and that fixed the problem: all the icons are full size. But, as I said before, they are actually too large and would really like some way to scale them down, Change the screen scale??
                              • PixeroP
                                Pixero
                                I've just updated my 3pt Window and 3pt Rectangle scripts with vector icons.
                                • Bob JamesB
                                  Bob James
                                  Thank you Pixero
                                  • 2 / 3
